New house planning
  • loucasz
    • 15.03.2022
    • 5
    New house planning
    Hello all,
    I am planning my house set up
    Actuators:
    1 * AKS-2416.03
    1 * AKS-2016.03
    1 * JAL-0810.02
    2 * BE-08000.02
    2 * SCN-P360E3.03
    Switches:
    3 * BE-GT20W.01
    2 * BE-GTL4TW.01
    2 * BE-GTL2TW.C1
    Visualization:
    Loxone server gen 1
    So far I have configured the devices in the ETS and have set up the wall switches to turn on/off the lights.
    Now is time to configure the loxone server and I am really stuck.
    I have viewed the below tutorial
    Do I have to change the whole concept for the switches? I have to set up a new address group for every parameter in the switch and when a button is pressed on the switch send it to loxone and the loxone to the AKS actuator?
    Any help is welcome
    Thanks.
  • Iksi
    • 1111
    This would be the better way, I think.
    You can let it as it is. But then you have to use the EIB switch in Loxone Config. There you can connect a feedback from the devices, so loxone recognizes when you switch the light via the wall switch.
    You can't use the light controller for example with this setting. So I would recommend to set it up the other way, that everything is switched via loxone. The disadvantage is of course, that if the miniserver does not work, no light would be available....
    • loucasz
      • 15.03.2022
      • 5
      Thanks for your answer,
      With "light controller" do you mean the below?
      Function block for the control and operation of all types of lighting
      So if I want to use the SCN-P360E3.03 (presence detector) to turn on a specific light, I have to program everything to goes to Loxone and after to KNX?
      The one presence will be in the guest toilet, and there is no button to turn on/off the light. Only the presence sensor.
      The other presence sensor will be in the garage and the specific light will be programmed to turn on/off from the wall switch and from the presence detector.
      Zuletzt geändert von loucasz; 20.03.2022, 20:34.
      • Pawlkerson
        • 11.05.2023
        • 1
        I hope your planning goes well and your house setup turns out great. As for configuring your Loxone server, it's understandable to feel stuck. Have you tried reaching out to Loxone's customer support? They can guide you or point you in the right direction. You could also check out online forums or groups discussing home automation and Loxone specifically. Best of luck to you in your project!
        Also, if you're looking for a Mortgage Broker in Wirral, you may want to check out Liverpoolmoneyman. They may be able to help you with your mortgage needs.
        Zuletzt geändert von Pawlkerson; 16.05.2023, 12:46.
        • RogerTrock
          • 10.08.2023
          • 1
          Thanks a bunch for the good vibes and well wishes for the house setup. It's all a bit of a puzzle, right? Speaking of puzzles, configuring tech stuff like a Loxone server can be a real head-scratcher.Thanks a bunch for the good vibes and well wishes for the house setup. It's all a bit of a puzzle, right? Speaking of puzzles, configuring tech stuff like a Loxone server can be a real head-scratcher. Reaching out to their customer support sounds like a solid plan – sometimes a little expert guidance can make all the difference. And those online forums? A goldmine of tips and tricks, for sure!
          Oh, and if you're diving into the world of mortgages, ever thought about connecting with a Mortgage Broker in Bridgend? They're like the navigation system for all things mortgage-related. And that mention of Liverpoolmoneyman for Wirral? Score!​
          Zuletzt geändert von RogerTrock; 11.08.2023, 12:07.
          • lordcaliente6
            • 01.05.2023
            • 5
            I understand the struggle. I also had to refer to tutorials and seek help from forums. It can be complex, especially when dealing with specific devices like the MDT Glastaster. Sometimes, you might need to adjust the concept for the switches and create new address groups for different parameters.In my experience, reaching out to the Loxone community or support can be really helpful. They often have insights and tips that can make the process smoother. Keep at it, and don't hesitate to ask for help when you need it. You're on the right track, and soon everything will be up and running just the way you want it. Also, if you're still hunting for info, you might find some useful insights from cash house buyers. Check out this link for more details: https://www.thepropertybuyingcompany...-house-buyers/
            Zuletzt geändert von lordcaliente6; 29.04.2024, 17:48.
            • tammmy
              • 07.02.2022
              • 2
              Yeah, I’ve been through a similar setup with Loxone and KNX, and it took me a while to get the communication between devices working the way I wanted.
              • Mephisto487
                • 22.04.2018
                • 5
                The learning curve is steep, especially when you’re trying to bring everything through Loxone for full control automation. I ended up redoing some of my group addresses too, so I get what you're saying—it can feel like a lot of rework. I also found it easier to have Loxone handle all the logic, including from presence sensors, even though it meant more initial setup.
                • tammmy
                  • 07.02.2022
                  • 2
                  I’ve used Amuli for a small real estate site I built a few months ago, and it worked out really well. Super easy to customize, and the layout looks clean even if you don’t tweak much. The property listings section was my favorite part; made it simple to display units with good visuals. If you’re using the theme for showcasing properties you rent or manage, you might also want to look into cost segregation in real estate. It helped me lower taxable income on my rentals last year, which freed up more budget for site upgrades.
