VNC to Loxberry
    VNC to Loxberry
    Hello,
    This may seem like a simple question but I searched without finding an answer. Is it possible to VNC to the Loxberry from outside my home network?
    Hallo, Das mag wie eine einfache Frage erscheinen, aber ich habe gesucht, ohne eine Antwort zu finden. Ist es möglich, VNC von außerhalb meines Heimnetzwerks an das Loxberry zu senden?
    • 11238
    as LoxBerry does not provide a local, graphical user interface, a VNC session makes no sense.
    You can create an SSH forward of port 22 on your router to access the shell, or port 80 to access the web interface.
    Security risks may apply ;-)
    Regards, Christian
      Christian, of course, thanks very much I can access the interface via port 80. I was actually hoping to transfer your TP LInk smart plug files to it (I have nothing to do at work) so opening 22 on the router should allow me to do that?
    • 6320
    Loxberry also provide a samba(Windows)-share. You can use this.
      • 11238
      Opening port 22 will do, and pscp to copy the file.
      If you are already in the network (VPN or so), there’s the file share Sven mentioned.
      If you can open the SSH port on your router directly from work, this IS a security risk at all!
        Thanks for all the help and suggestions. I opened port 22 and managed to get in using Cyberduck (I'm on a mac) after 5 or 6 attempts using the same login details. I then closed port 22, if anyone is interested I am using Google WiFi so can open/close ports from my phone.
      • 6320
      You have to use loxberry as user and the password that you‘ve given at first setup.
        Hört sich nicht so schlecht an.
        Svethi, I could understand it very well although I am using Google translate permanently on this page to go from German to English. This does look a little odd when I first post as I usually post in English then German out of politeness, the German then gets translated back at me automatically when the post appears.... Anyway, I mentioned that it took a few goes to logon on successfully because I thought it odd that the correct logon details didn't work first time, I tried 'root' as user then went back to the correct details which worked just as I was about to give up and wait until I got home.
        ‚root‘ does not work because it’s forbidden. You have to use ‘loxberry’ as user and his password. Not the user that you have created at the first setup.
