Der Fehler steht trotzdem noch an.
loxberry@loxberry2:~ $ df -h
Filesystem Size Used Avail Use% Mounted on
/dev/root 29G 4.9G 23G 18% /
devtmpfs 459M 0 459M 0% /dev
tmpfs 464M 0 464M 0% /dev/shm
tmpfs 464M 7.4M 456M 2% /run
tmpfs 5.0M 0 5.0M 0% /run/lock
tmpfs 464M 0 464M 0% /sys/fs/cgroup
/dev/zram0 386M 916K 357M 1% /opt/loxberry/log/ramlog
/dev/mmcblk0p1 41M 40M 1.4M 97% /boot
tmpfs 93M 0 93M 0% /run/user/1001
CRITICAL: One of your configuration files (general.cfg, mail.json, installpin.dat, securepin.dat) exists but have zero size. LoxBerry is not working in this condition. Please check if your SD card is full. If you have fixed the issue, delete all of the mentioned files that have 0 Bytes so LoxBerry can re-create them, or restore them from a backup. Sorry for any troubles. We love you!
Ist bei der Hostnamen Änderung etwas schief gegangen.
