Loxberry stürzte ab
    Loxberry stürzte ab
    I just tried to make a backup copy on Loxberry, and the site is now gone
    , the method "vars" can not apply to an undefined value in /opt/loxberry/webfrontend/htmlauth/system/index.cgi line 59, <FH> line 8 will be called.
    I can ssh into it, all ideas on how it brings back without rebooting and running and what I should test before restarting. Thank you.
    I always keep the Loxberry up to date and it runs in a RPi3 I hope that has come in order, because I had to use Google Translater.
    Zuletzt geändert von Gast; 06.01.2019, 11:38.
    • 11225
    was genau hast du durchgeführt?
    Es kann die general.cfg, die Haupt-Konfigurationsdatei, nicht gelesen werden.
    Christian
    PS: If you prefer English -> that’s no problem.
      I was doing a back to a USB stick using the Loxberry backup plugin. The pi's red light is on, the green light flashes every now and then and there is a network connection as I've log in through SSH
        • 11225
        Can you check the file /opt/loxberry/config/system/general.cfg if it is available, and readable, from the console.
          This is all I get:
          GNU nano 2.7.4 File: general.cfg
          q����y
          �Ck�^A>^U^\Z_�@ޒ,!�^K'm^T�����t�^K�A��Q��G�4^\��{� <�`Dc$
          �NW�[{�C뿃��*����C^N'��r^?~6�T��2��M�s�;.�V��J�vU�̮�ƣ�-^��^Z�^P^A^Q��3���3�W�Gl�k�ePz�^@^A+9����q��Q�`Z?� ^H^�?�$
          ^Q{�p^C��9����^Nz^L���^A^G��^_�Kߞ^O^W+$�^]{{�^W^A^Ww{�t$
          ��S?��l^F���~�-���@��U^E,^G�^_�^R$�^\^N�æp^Z5�^K}�у���>$
          ^R��3���^P^P}�x窀�͜�!q��
          -��^^�J�^L����q�S`�Ps
          q����y
          �Ck�^A>^U^\Z_�@ޒ,!�^K'm^T�����t�^K�A��Q��G�4^\��{� <�`Dc���^D^^i�?�^U^]Ȧ��r�t^?� �7�1^^^C,����4��ሿ�^\֕�NW�[{�C뿃��*����C^N'��r^?~6�T��2��M�s�;.�V��J�vU�̮�ƣ�-^Tp^\ڦ�U��^F;�j+�^P��w�^UuSq��y}^Gx��^]����^P���^Z�^P^A^Q��3���3�W�Gl�k�ePz�^@^A+9����q�� Q�`Z?�^H^�?��^G�"����ti���^[^W��Q���
          ^G Get Help ^O Write Out ^W Where Is ^K Cut Text ^J Justify ^C Cur Pos ^Y Prev Page
          ^X Exit^R Read File ^\ Replace ^U Uncut Text ^T To Spell ^_ Go To Line ^V Next Page
          q����y
          ^Q{�p^C��9����^Nz^L���^A^G��^_�Kߞ^O^W+$�^]{{�^W^A^Ww{�t��+C^?v�ց^Y^Z8|�L������}_�^A�MoH���w+ 3跩���~^$��S?��l^F���~�-���@��U^E,^G�^_�^R$�^\^N�æp^Z5�^K}�у���>7����9��^Q ����^[?�^?�^)^B^O���^\^E�\:k��/�vr�$^R��3���^P^P}�x窀�͜�!q��
          q����y
          q����y
            Just had this via email :
            /etc/cron.hourly/logrotate:
            error: bad top line in state file /var/lib/logrotate/status
            run-parts: /etc/cron.hourly/logrotate exited with return code 1
              • 11225
              It seems that your file system has died :-(
              You did a backup before - had it finished?
              Are you on Raspberry hardware?
                Yes I am on a raspberry pi 3. Ive removed the USB and there is a file called loxberry-ddz-backup-20190106-091550.img.gz on it which is 2.5gb in size so it may have completed the back up.
                ​​​​​​​Shall I reboot the pi? can it be done from the command line or should I do it through a power recycle?
                  • 11225
                  It doesn’t matter, but may not work anymore through WebIf.
                  You may extract the gz file, and rewrite it to the SD (or a second SD), trying to boot up with it.
                  Hopefully, your backup is valid...!
                    I carried out a sudo reboot and its come back to life and working now
                      • 11225
                      Crazy 😜
                      Keep the backup!
                        Will do, thank you so much for you help this morning, much appreciated.
