ich bekomme beim Updatecheck folgende Fehlermeldung:
12.05.2021 07:50: LoxBerry Updatecheck: Es trat ein Fehler während der Prüfung auf neue Updates auf. Bitte prüfe das Update-Prüfungs-Log.
Habe Loxberry bereits neu Installiert
Danach war das erste Update erfolgreich!
Nach der Installation aller Plugins wieder dieser Fehler.
Hat jemand eine Idee an was das liegen, bzw. wie ich den Fehler beheben kann?
Logfile:
Log Viewer - /system_tmpfs/loxberryupdate/20210512_074843_277_check.log
12.05.2021 07:48:43 TASK STARTED
LoxBerry Update Check
INFO: LoxBerry Version 2.2.0.4 ( is_raspberry.cfg )
INFO: Loglevel: 7
INFO: Version of loxberryupdatecheck.pl is 2.0.2.3
INFO: Executing user of loxberryupdatecheck is root
INFO: Locking lbupdate to check if an update is running...
OK: No update seems to be running currently
OK: Parameters/settings of this update:
INFO: querytype: release
INFO: cron: 1
INFO: keepupdatefiles:
INFO: dryrun:
INFO: output:
INFO: Current LoxBerry version: v2.2.0.4
INFO: max_version v2.99.99 calculated from current version
INFO: Updates limited from : v1.0.0
INFO: Updates limited to : v2.99.99
INFO: Start checking releases...
INFO: Checking for releases from https://api.github.com/repos/mschlen...berry/releases
INFO: Requesting release list from GitHub...
INFO: Try 1: Getting release list... (12.05.2021 07:48:43)
WARNING: API call try 1 has failed. (12.05.2021 07:49:03) HTTP 500 Can't connect to api.github.com:443 (Temporary failure in name resolution)
INFO: Try 2: Getting release list... (12.05.2021 07:49:03)
WARNING: API call try 2 has failed. (12.05.2021 07:49:23) HTTP 500 Can't connect to api.github.com:443 (Temporary failure in name resolution)
INFO: Try 3: Getting release list... (12.05.2021 07:49:23)
WARNING: API call try 3 has failed. (12.05.2021 07:49:43) HTTP 500 Can't connect to api.github.com:443 (Temporary failure in name resolution)
INFO: Try 4: Getting release list... (12.05.2021 07:49:44)
WARNING: API call try 4 has failed. (12.05.2021 07:50:04) HTTP 500 Can't connect to api.github.com:443 (Temporary failure in name resolution)
INFO: Try 5: Getting release list... (12.05.2021 07:50:04)
WARNING: API call try 5 has failed. (12.05.2021 07:50:24) HTTP 500 Can't connect to api.github.com:443 (Temporary failure in name resolution)
ERROR: Abrufen der Release-Liste ist fehlgeschlagen: 500 Can't connect to api.github.com:443 (Temporary failure in name resolution)
CRITICAL: Abrufen der Release-Liste ist fehlgeschlagen: 500 Can't connect to api.github.com:443 (Temporary failure in name resolution)
CRITICAL: LoxBerry Updatecheck exited or terminated with an error. Errorcode: 1
12.05.2021 07:50:24 TASK FINISHED
Folgende Plugins sind Installiert:
Schon mal Danke für eure Mühe....
