Loxberry Update
  • max83
    • 26.11.2016
    • 7
    Loxberry Update
    Liebe Loxberry Gemeinde,
    ich bekomme beim Updatecheck folgende Fehlermeldung:
    12.05.2021 07:50: LoxBerry Updatecheck: Es trat ein Fehler während der Prüfung auf neue Updates auf. Bitte prüfe das Update-Prüfungs-Log.
    Habe Loxberry bereits neu Installiert
    Danach war das erste Update erfolgreich!
    Nach der Installation aller Plugins wieder dieser Fehler.
    Hat jemand eine Idee an was das liegen, bzw. wie ich den Fehler beheben kann?
    Logfile:
    Log Viewer - /system_tmpfs/loxberryupdate/20210512_074843_277_check.log
    12.05.2021 07:48:43 TASK STARTED
    LoxBerry Update Check
    INFO: LoxBerry Version 2.2.0.4 ( is_raspberry.cfg )
    INFO: Loglevel: 7
    INFO: Version of loxberryupdatecheck.pl is 2.0.2.3
    INFO: Executing user of loxberryupdatecheck is root
    INFO: Locking lbupdate to check if an update is running...
    OK: No update seems to be running currently
    OK: Parameters/settings of this update:
    INFO: querytype: release
    INFO: cron: 1
    INFO: keepupdatefiles:
    INFO: dryrun:
    INFO: output:
    INFO: Current LoxBerry version: v2.2.0.4
    INFO: max_version v2.99.99 calculated from current version
    INFO: Updates limited from : v1.0.0
    INFO: Updates limited to : v2.99.99
    INFO: Start checking releases...
    INFO: Checking for releases from https://api.github.com/repos/mschlen...berry/releases
    INFO: Requesting release list from GitHub...
    INFO: Try 1: Getting release list... (12.05.2021 07:48:43)
    WARNING: API call try 1 has failed. (12.05.2021 07:49:03) HTTP 500 Can't connect to api.github.com:443 (Temporary failure in name resolution)
    INFO: Try 2: Getting release list... (12.05.2021 07:49:03)
    WARNING: API call try 2 has failed. (12.05.2021 07:49:23) HTTP 500 Can't connect to api.github.com:443 (Temporary failure in name resolution)
    INFO: Try 3: Getting release list... (12.05.2021 07:49:23)
    WARNING: API call try 3 has failed. (12.05.2021 07:49:43) HTTP 500 Can't connect to api.github.com:443 (Temporary failure in name resolution)
    INFO: Try 4: Getting release list... (12.05.2021 07:49:44)
    WARNING: API call try 4 has failed. (12.05.2021 07:50:04) HTTP 500 Can't connect to api.github.com:443 (Temporary failure in name resolution)
    INFO: Try 5: Getting release list... (12.05.2021 07:50:04)
    WARNING: API call try 5 has failed. (12.05.2021 07:50:24) HTTP 500 Can't connect to api.github.com:443 (Temporary failure in name resolution)
    ERROR: Abrufen der Release-Liste ist fehlgeschlagen: 500 Can't connect to api.github.com:443 (Temporary failure in name resolution)
    CRITICAL: Abrufen der Release-Liste ist fehlgeschlagen: 500 Can't connect to api.github.com:443 (Temporary failure in name resolution)
    CRITICAL: LoxBerry Updatecheck exited or terminated with an error. Errorcode: 1
    12.05.2021 07:50:24 TASK FINISHED
    Folgende Plugins sind Installiert:
Ansichten: 565
Größe: 52,0 KB
    Schon mal Danke für eure Mühe....
    • 4742
    Du hast ein Problem mit Deinen Netzwerkeinstellungen (Nameserver):
      • 6318
      Genauso ist es. Du hast Dir DNS Masq installiert. Dann musst Du auch eine entsprechende, Korrekte Konfiguration dafür anlegen
      • max83
        • 26.11.2016
        • 7
        Vielen Dank für die Schnelle Hilfe!
        Kämpfe gerade noch mit der richtigen Konfiguration, aber das wird schon klappen.....
          • 6318
          Warum hast Du Dir DNSMasq installiert, wenn Du mit der Konfiguration kämpfst? Normal installiert man sowas weil man die spezielle Funktion möchte
          • max83
            • 26.11.2016
            • 7
            Habe DNSMasq installiert um den Wetterservice im Loxone zu emulieren.
            Die Konfig habe ich mitlerweile aber hinbekommen. Jetzt läuft alles, Danke.
              Brauchst Du doch gar nicht. Bringt Weather4Lox alles fix und fertig mit. Steht auch so im Wiki...
              Zuletzt geändert von Prof.Mobilux; 13.05.2021, 13:49.
              Das war genau auch meine Vermutung. Und wenn man richtig lesen würde wie Michael schon sagte, hätte man sich die ganze Konfiguration sparen können.
          • Davidmei
            • 06.02.2017
            • 569
            ichg bekomme folgenden Fehler beim Update:
Ansichten: 106
Größe: 16,5 KB
