Loxberry hat nach Update keine Version mehr
  • neonnt
    • 28.08.2016
    • 166
    ich habe gerade ein Update von 1.43 auf 1.44 auf 2.0 gemacht und wollte dann weiter hoch, dabei ist beim installieren von Python-pip was schief gelaufen und jetzt hat das loxberry keine Version mehr.
    ERROR: Update script /opt/loxberry/sbin/loxberryupdate/update_v2.0.0.1.pl finished with errors.
    23:35:11.404 INFO: exec_perl_script /opt/loxberry/sbin/loxberryupdate/update_v2.0.0.1.pl release=v2.2.1.2 logfilename=/opt/loxberry/log/system/loxberryupdate/20220207_231611_515_update.log cron= updatedir=/tmp/loxberryupdate/mschlenstedt-Loxberry-d9db9fb with user - errcode 1
    23:35:11.406 ERROR: Update-Script update_v2.0.0.1 returned errorcode 1. Despite errors loxberryupdate.pl will continue.
    23:35:11.415 INFO: Setting update script update_v2.0.0.1 as failed in general configuration.
    23:35:11.416 INFO: Updating update script fail state in general configuration...
    23:35:11.420 WARNING: LoxBerry Update was SUCCESSFULL, but skipped at least 1 warnings or errors. Check the log.
    23:35:11.421 CRITICAL: LoxBerry Update exited or terminated with an error. Errorcode: 1
    07.02.2022 23:46:26 TASK STARTED
    LoxBerry Update Check
    INFO: LoxBerry Version ( is_raspberry.cfg )
    INFO: Loglevel: 7
    INFO: Version of loxberryupdatecheck.pl is 2.0.2.3
    INFO: LoxBerry::System::General does not exist - run in general.cfg legacy mode
    INFO: Reading general.cfg
    INFO: Executing user of loxberryupdatecheck is root
    INFO: Locking lbupdate to check if an update is running...
    OK: No update seems to be running currently
    OK: Parameters/settings of this update:
    INFO: querytype: latest
    INFO: cron:
    INFO: keepupdatefiles:
    INFO: dryrun:
    INFO: output: 1
    ERROR: Cannot read current version. Is this a real version string? Exiting.
    INFO: JSON: {"logfile":"/opt/loxberry/log/system_tmpfs/loxberryupdate/20220207_234626_478_check.log","branch":null,"keep updatefiles":null,"dryrun":null,"keepinstallfiles" :"0","error":"Cannot read current version. Is this a real version string? Exiting."}
    CRITICAL: Cannot read current version. Is this a real version string? Exiting.
    CRITICAL: LoxBerry Updatecheck exited or terminated with an error. Errorcode: 1
    bekomme ich die Version wieder irgendwo rein gefummelt um das zu fixen ?
    Zuletzt geändert von neonnt; 07.02.2022, 23:00.
    neonnt
    MS, 2 Extensions, Tree-Extension, 1-Wire Extension, Enocean Extension, S0 Zähler, Home Assistant, DS1400 + Netatmo Wetterstation, HomePods, Hue Bridge v2, VU+ Solo2 und noch einige RPi + Arduino
    • 11237
    Schau mal, ob es in /opt/loxberry/config/system/ ein Backup der general.cfg und general.json gibt.
    • neonnt
      • 28.08.2016
      • 166
      Da liegt noch jeweils eine .default drin mit 2.2.1.2 als Version. Aber bin ich denn schon komplett auf 2.2.1.2 oder fehlt mir da noch eine Version dazwischen?
      neonnt
        • 11237
        Die .default nützen dir nichts, das ist die Standardconfig wenn's keine Config gibt.
        Hast du ein Backup, dann stell die beiden Dateien aus dem Backup wieder her. Alle Backup-Typen von LoxBerry Backup lassen sich mit 7-Zip öffnen, ebenso auch IMG-Dateien.
        • neonnt
          • 28.08.2016
          • 166
          ok, probiere ich mal :-)
          neonnt
          • neonnt
            • 28.08.2016
            • 166
            so wie es aussieht scheint es wieder zu funktionieren. danke dir nochmal :-)
            neonnt
              Da haben wir wieder mal 🐷 gehabt!
