LoxBerry V3.0.0.0 RELEASE
  • cdrescher
    • 152
    #91
    Preparing to unpack .../nodejs_12.22.12-deb-1nodesource1_armhf.deb ...
    Unpacking nodejs (12.22.12-deb-1nodesource1) over (12.19.0-1nodesource1) ...
    hatte ähnliche Probleme. Bin wieder auf die letzte Version zurück gestiegen.
    Zuletzt geändert von Prof.Mobilux; 26.04.2023, 22:27. Grund: Vollquote gelöscht
    • badmage
      • 22.01.2019
      • 22
      #92
      evtl. hilft ja das Update Log weiter...
      <LOGSTART> 27.04.2023 10:53:36 TASK STARTED
      <LOGSTART> Update from v2.2.2.2 to v3.0.0.5
      10:53:36.385 <INFO> LoxBerry Version 2.2.2.2 ( is_raspberry.cfg )
      10:53:36.385 <INFO> Loglevel: 7
      10:53:36.390 <INFO>    Version     : v3.0.0.5
      10:53:36.390 <INFO>    Name        : V3.0.0 Major Release
      10:53:36.390 <INFO>    Description : See what's new: https://wiki.loxberry.de/installation_von_loxberry/die_versionen_des_loxberry/whats_new_in_v300
      NEVER EVER install this upgrade if you do not have a WORKING BACKUP of your installation! WE ARE NOT KIDDING! Especially all plugins based on Python2 or 3 may have problems after this big release! Expect some (a lot of) trouble after upgrading...
      KNOWN ISSUES
      - 1-Wire-NG: MQTT Data sending may not work anymore after upgrade. Solution: Upgrade the plugin to the latest plugin version.
      - CamStream4Lox: Will not work anymore in LoxBerry 3.0! Solution: Switch over to the MotionEye Plugin or do not upgrade. WONT FIX!
      - DNSMASQ: DNSMasq will not start after upgrade to LoxBerry 3.0. Solution: Wait for new Release of DNSMasq Plugin before upgrade
      - GPIO 2.0: Will not work in LoxBerry 3.0. Solution: Do not Upgrade to LoxBerry 3.0 until a new version of the plugin is released
      - HaBridge: Could not be installed anymore on LoxBerry 3.0. Solution: ?
      - LabCom / PoolLab: MQTT Data sending will not work anymore after upgrade. Solution: Upgrade the plugin to the latest plugin version.
      - LoxMatic: Older versions prior to 1.0.0 do not work anymore after upgrade. Solution: Upgrade the plugin to the latest plugin version.
      - Nuki: MQTT Data sending may not work anymore after upgrade. Solution: Upgrade the plugin to the latest plugin version.
      - Zigbee2Mqtt: Will not work anymore after upgrade. Solution: Upgrade the plugin to the latest plugin version.
      10:53:36.391 <INFO>    Published   : 2023-04-17T11:42:43Z
      10:53:36.391 <INFO>    Releasetype : Release
      10:53:36.391 <INFO> Checking if another update is running...
      10:53:36.415 <OK> No other update running.
      10:53:36.415 <OK> Update auf v3.0.0.5 gestartet. Im LoxBerry Update Verlauf findest du die Logdatei mit Details.
      10:53:36.415 <INFO> Update auf v3.0.0.5 gestartet. Im LoxBerry Update Verlauf findest du die Logdatei mit Details.
      10:53:36.415 <INFO> JSON: {"release_name":"V3.0.0 Major Release","max_version":"v3.99.99","releasetype":"release","keepupdatefiles":null,"release_new":"1","release_body":"See what's new: https://wiki.loxberry.de/installation_von_loxberry/die_versionen_des_loxberry/whats_new_in_v300\r\n\r\nNEVER EVER install this upgrade if you do not have a WORKING BACKUP of your installation! WE ARE NOT KIDDING! Especially all plugins based on Python2 or 3 may have problems after this big release! Expect some (a lot of) trouble after upgrading...\r\n\r\nKNOWN ISSUES\r\n\r\n- 1-Wire-NG: MQTT Data sending may not work anymore after upgrade. Solution: Upgrade the plugin to the latest plugin version.\r\n- CamStream4Lox: Will not work anymore in LoxBerry 3.0! Solution: Switch over to the MotionEye Plugin or do not upgrade. WONT FIX!\r\n- DNSMASQ: DNSMasq will not start after upgrade to LoxBerry 3.0. Solution: Wait for new Release of DNSMasq Plugin before upgrade\r\n- GPIO 2.0: Will not work in LoxBerry 3.0. Solution: Do not Upgrade to LoxBerry 3.0 until a new version of the plugin is released\r\n- HaBridge: Could not be installed anymore on LoxBerry 3.0. Solution: ?\r\n- LabCom / PoolLab: MQTT Data sending will not work anymore after upgrade. Solution: Upgrade the plugin to the latest plugin version.\r\n- LoxMatic: Older versions prior to 1.0.0 do not work anymore after upgrade. Solution: Upgrade the plugin to the latest plugin version.\r\n- Nuki: MQTT Data sending may not work anymore after upgrade. Solution: Upgrade the plugin to the latest plugin version.\r\n- Zigbee2Mqtt: Will not work anymore after upgrade. Solution: Upgrade the plugin to the latest plugin version.","published_at":"2023-04-17T11:42:43Z","dryrun":null,"max_version_next":"v3.99.99","info":"Update auf v3.0.0.5 gestartet. Im LoxBerry Update Verlauf findest du die Logdatei mit Details.","branch":null,"min_version":"v1.0.0","keepinstallfiles":"0","release_version":"v3.0.0.5","release_zipurl":"https://api.github.com/repos/mschlenstedt/Loxberry/zipball/3.0.0.5","logfile":"/opt/loxberry/log/system/loxberryupdate/20230427_105336_378_update.log"}
      10:53:36.416 <INFO> Starting download procedure for /tmp/loxberry.v3.0.0.5.zip...
      10:53:36.416 <INFO>    Download preparing. URL: https://api.github.com/repos/mschlenstedt/Loxberry/zipball/3.0.0.5 Filename: /tmp/loxberry.v3.0.0.5.zip
      10:53:36.417 <INFO>    Try 1: Download of release... (27.04.2023 10:53:36)
      10:53:37.870 <OK> Download saved successfully in /tmp/loxberry.v3.0.0.5.zip
      10:53:37.872 <OK> Download successfully stored in /tmp/loxberry.v3.0.0.5.zip.
      10:53:37.872 <INFO> Starting unzip procedure for /tmp/loxberry.v3.0.0.5.zip...
      10:53:37.872 <INFO>    Running unzip
      10:53:37.872 <INFO>    Extracting ZIP file /tmp/loxberry.v3.0.0.5.zip to folder /tmp/loxberryupdate...
      10:53:38.585 <OK>    Unzipping was successful.
      10:53:38.585 <INFO> Deleting zipfile after unzip was successful
      10:53:38.590 <INFO> Starting prepare update procedure...
      10:53:38.591 <INFO> Seeking for unzipped sub-directory in /tmp/loxberryupdate...
      10:53:38.591 <OK> Update directory is /tmp/loxberryupdate/mschlenstedt-Loxberry-fb575c0
      10:53:38.591 <INFO> LoxBerry Update programs are updated from the release to your LoxBerry...
      10:53:38.594 <INFO> Copying new file exlude list from release to your LoxBerry
      10:53:38.602 <OK> Update checked and prepared successfully.
      10:53:38.602 <OK> Prepare update successful.
      10:53:38.602 <INFO> Forking loxberryupdate...
      10:53:38.607 <INFO> Executing LoxBerry Update forked...
      <LOGEND> 27.04.2023 10:53:38 TASK FINISHED
      10:53:39.399 <OK> Update handed over from LoxBerry Update Check to LoxBerry Update
      10:53:39.400 <INFO> Executing user of loxberryupdate is root
      10:53:39.400 <OK> This update was manually triggered.
      10:53:39.400 <INFO> Locking lbupdate - return immediately if lock stat is not secure...
      10:53:39.466 <OK> Lock successfully set.
      10:53:39.494 <INFO> Version parameter 'v3.0.0.5' was given, destination version is v3.0.0.5.
      10:53:39.495 <INFO> Current LoxBerry version is v2.2.2.2
      10:53:39.495 <INFO> Changing the owner of the update files to loxberry:loxberry...
      10:53:39.542 <OK> Changing owner was successful.
      10:53:39.543 <INFO> Pre-Changing the owner of special files in updatedir to root:root...
      10:53:39.553 <OK> Pre-Changing owner was successful.
      10:53:39.553 <INFO> Searching and preparing Update Pre-Check script...
      10:53:39.554 <INFO>       Running Update Pre-Check script for v3.0.0...
      10:53:39.555 <INFO> Executing /tmp/loxberryupdate/mschlenstedt-Loxberry-fb575c0/sbin/loxberryupdate/updateprecheck_v3.0.0.pl release=v3.0.0.5 logfilename=/opt/loxberry/log/system/loxberryupdate/20230427_105336_378_update.log cron= updatedir=/tmp/loxberryupdate/mschlenstedt-Loxberry-fb575c0
      <OK> Update script /tmp/loxberryupdate/mschlenstedt-Loxberry-fb575c0/sbin/loxberryupdate/updateprecheck_v3.0.0.pl started.
      <INFO> Cleaning up and updating apt databases...
      <OK> Configuring dpkg successfully.
      <INFO> Clean up apt-databases and update
      <OK> Eventually broken Apt packages installed successfully.
      <OK> Apt packages autoremoved successfully.
      <OK> Apt database updated successfully.
      <OK> Apt cache cleaned successfully.
      10:54:07.489 <INFO> exec_perl_script /tmp/loxberryupdate/mschlenstedt-Loxberry-fb575c0/sbin/loxberryupdate/updateprecheck_v3.0.0.pl release=v3.0.0.5 logfilename=/opt/loxberry/log/system/loxberryupdate/20230427_105336_378_update.log cron= updatedir=/tmp/loxberryupdate/mschlenstedt-Loxberry-fb575c0 with user  - errcode 0
      10:54:07.489 <OK> Update Pre-Check passed.
      10:54:07.489 <INFO> Running rsync command...
      2023/04/27 10:54:07 [3191] building file list
      2023/04/27 10:54:07 [3191] *deleting   raspiBackup.log
      2023/04/27 10:54:07 [3191] .d..t...... ./
      2023/04/27 10:54:07 [3191] >fcst...... README.md
      2023/04/27 10:54:07 [3191] >fcst...... packages.txt
      2023/04/27 10:54:08 [3191] *deleting   libs/perllib/LoxBerry/testing/test_VIHTTP_template.cgi
      2023/04/27 10:54:08 [3191] *deleting   libs/phplib/testing/test_loxonetemplatebuilder.php
      2023/04/27 10:54:08 [3191] *deleting   sbin/setloxberrypasswdsmb.exp
      2023/04/27 10:54:08 [3191] *deleting   sbin/setloxberrypasswd.exp
      2023/04/27 10:54:08 [3191] *deleting   sbin/setenvironment.sh
      2023/04/27 10:54:08 [3191] *deleting   sbin/installpackages.pl
      2023/04/27 10:54:08 [3191] *deleting   sbin/files_analyzer debian libs.txt
      2023/04/27 10:54:08 [3191] *deleting   sbin/activate_i2c.sh
      2023/04/27 10:54:08 [3191] *deleting   templates/system/wizard/welcome.html
      2023/04/27 10:54:08 [3191] *deleting   templates/system/wizard/finish.html
      2023/04/27 10:54:08 [3191] *deleting   templates/system/nl/success.html
      2023/04/27 10:54:08 [3191] *deleting   templates/system/nl/header.html
      2023/04/27 10:54:08 [3191] *deleting   templates/system/nl/footer.html
      2023/04/27 10:54:08 [3191] *deleting   templates/system/nl/error.html
      2023/04/27 10:54:08 [3191] *deleting   templates/system/cs/success.html
      2023/04/27 10:54:08 [3191] *deleting   templates/system/cs/header.html
      2023/04/27 10:54:08 [3191] *deleting   templates/system/cs/footer.html
      2023/04/27 10:54:08 [3191] *deleting   templates/system/cs/error.html
      2023/04/27 10:54:08 [3191] *deleting   templates/system/mqttfinder.html
      2023/04/27 10:54:08 [3191] *deleting   templates/system/de/success.html
      2023/04/27 10:54:08 [3191] *deleting   templates/system/de/header.html
      2023/04/27 10:54:08 [3191] *deleting   templates/system/de/footer.html
      2023/04/27 10:54:08 [3191] *deleting   templates/system/de/error.html
      2023/04/27 10:54:08 [3191] *deleting   templates/system/en/success.html
      2023/04/27 10:54:08 [3191] *deleting   templates/system/en/header.html
      2023/04/27 10:54:08 [3191] *deleting   templates/system/en/footer.html
      2023/04/27 10:54:08 [3191] *deleting   templates/system/en/error.html
      2023/04/27 10:54:08 [3191] *deleting   templates/system/es/success.html
      2023/04/27 10:54:08 [3191] *deleting   templates/system/es/header.html
      2023/04/27 10:54:08 [3191] *deleting   templates/system/es/footer.html
      2023/04/27 10:54:08 [3191] *deleting   templates/system/es/error.html
      2023/04/27 10:54:08 [3191] *deleting   webfrontend/html/system/scripts/vue3/vue.global.prod.js
      2023/04/27 10:54:08 [3191] *deleting   webfrontend/html/system/scripts/vue3/vue.global.js
      2023/04/27 10:54:08 [3191] *deleting   webfrontend/htmlauth/system/wizard.cgi
      2023/04/27 10:54:08 [3191] *deleting   webfrontend/htmlauth/system/tools/mqttfinder.cgi
      2023/04/27 10:54:08 [3191] *deleting   webfrontend/htmlauth/system/tools/ajax-storage-handler.cgi
      2023/04/27 10:54:08 [3191] *deleting   webfrontend/htmlauth/system/tools/ajax-notification-handler.cgi
      2023/04/27 10:54:08 [3191] *deleting   webfrontend/htmlauth/system/tools/ajax-mqttfinder.php
      2023/04/27 10:54:08 [3191] *deleting   webfrontend/htmlauth/system/tools/ajax-footer-icons-handler.php
      2023/04/27 10:54:08 [3191] *deleting   webfrontend/htmlauth/system/tools/ajax-fileanalyzer.cgi
      2023/04/27 10:54:08 [3191] *deleting   webfrontend/htmlauth/system/tools/ajax-download-handler.cgi
      2023/04/27 10:54:08 [3191] *deleting   webfrontend/htmlauth/system/tools/ajax-config-handler.cgi
      2023/04/27 10:54:08 [3191] *deleting   webfrontend/htmlauth/system/tools/ajax-check-miniserver.cgi
      2023/04/27 10:54:08 [3191] .d..t...... bin/
      2023/04/27 10:54:08 [3191] cd+++++++++ bin/mqtt/
      2023/04/27 10:54:08 [3191] cd+++++++++ bin/mqtt/transform/
      2023/04/27 10:54:08 [3191] cd+++++++++ bin/mqtt/transform/shipped/
      2023/04/27 10:54:08 [3191] cd+++++++++ bin/mqtt/transform/shipped/udpin/
      2023/04/27 10:54:08 [3191] cd+++++++++ bin/mqtt/transform/shipped/udpin/examples/
      2023/04/27 10:54:08 [3191] >f+++++++++ bin/mqtt/transform/shipped/udpin/examples/php_jsonin_jsonarrayout.php
      2023/04/27 10:54:08 [3191] >f+++++++++ bin/mqtt/transform/shipped/udpin/examples/php_jsonin_jsonout.php
      2023/04/27 10:54:08 [3191] >f+++++++++ bin/mqtt/transform/shipped/udpin/examples/php_textin_textout.php
      2023/04/27 10:54:08 [3191] cd+++++++++ bin/mqtt/transform/shipped/udpin/generic/
      2023/04/27 10:54:08 [3191] >f+++++++++ bin/mqtt/transform/shipped/udpin/generic/http2mqtt.php
      2023/04/27 10:54:08 [3191] >f+++++++++ bin/mqtt/transform/shipped/udpin/generic/moving_minmaxavg.php
      2023/04/27 10:54:08 [3191] >f+++++++++ bin/mqtt/transform/shipped/udpin/generic/sort.php
      2023/04/27 10:54:08 [3191] cd+++++++++ bin/mqtt/transform/shipped/udpin/shelly/
      2023/04/27 10:54:08 [3191] >f+++++++++ bin/mqtt/transform/shipped/udpin/shelly/shelly_rgb&w.php
      2023/04/27 10:54:08 [3191] .d..t...... config/
      2023/04/27 10:54:08 [3191] .d..t...... config/system/
      2023/04/27 10:54:08 [3191] >f+++++++++ config/system/ca.cnf
      2023/04/27 10:54:08 [3191] >fc.tp..... config/system/general.cfg.default
      2023/04/27 10:54:08 [3191] >fcstp..... config/system/general.json.default
      2023/04/27 10:54:08 [3191] .d..t...... libs/
      2023/04/27 10:54:08 [3191] .d..t...... libs/bashlib/
      2023/04/27 10:54:08 [3191] >fcstp..... libs/bashlib/iniparser.sh
      2023/04/27 10:54:08 [3191] >fcstp..... libs/bashlib/notify.sh
      2023/04/27 10:54:08 [3191] .d..t...... libs/bashlib/testing/
      2023/04/27 10:54:08 [3191] .d..t...... libs/perllib/
      2023/04/27 10:54:08 [3191] .d..t...... libs/perllib/Data/
      2023/04/27 10:54:08 [3191] .d..t...... libs/perllib/Embed/
      2023/04/27 10:54:08 [3191] .d..t...... libs/perllib/File/
      2023/04/27 10:54:08 [3191] .d..t...... libs/perllib/Hash/
      2023/04/27 10:54:08 [3191] .d..t...... libs/perllib/LoxBerry/
      2023/04/27 10:54:08 [3191] >fcst...... libs/perllib/LoxBerry/IO.pm
      2023/04/27 10:54:08 [3191] >fcst...... libs/perllib/LoxBerry/Log.pm
      2023/04/27 10:54:08 [3191] >f+++++++++ libs/perllib/LoxBerry/PIDController.pm
      2023/04/27 10:54:08 [3191] >fcst...... libs/perllib/LoxBerry/Storage.pm
      2023/04/27 10:54:08 [3191] >fcst...... libs/perllib/LoxBerry/System.pm
      2023/04/27 10:54:08 [3191] >fcst...... libs/perllib/LoxBerry/System_v1.pm
      2023/04/27 10:54:08 [3191] >fcst...... libs/perllib/LoxBerry/Update.pm
      2023/04/27 10:54:08 [3191] >fcst...... libs/perllib/LoxBerry/Web.pm
      2023/04/27 10:54:08 [3191] cd+++++++++ libs/perllib/LoxBerry/MQTTGateway/
      2023/04/27 10:54:08 [3191] >f+++++++++ libs/perllib/LoxBerry/MQTTGateway/IO.pm
      2023/04/27 10:54:08 [3191] .d..t...... libs/perllib/LoxBerry/System/
      2023/04/27 10:54:08 [3191] .d..t...... libs/perllib/LoxBerry/examples/
      2023/04/27 10:54:08 [3191] >fcstp..... libs/perllib/LoxBerry/examples/mqtt_publish_via_udp.pl
      2023/04/27 10:54:08 [3191] .d..t...... libs/perllib/LoxBerry/testing/
      2023/04/27 10:54:08 [3191] >f+++++++++ libs/perllib/LoxBerry/testing/get_notification_count.pl
      2023/04/27 10:54:08 [3191] >f+++++++++ libs/perllib/LoxBerry/testing/ipv6_localhost.pl
      2023/04/27 10:54:08 [3191] >f+++++++++ libs/perllib/LoxBerry/testing/json_writeonclose.pl
      2023/04/27 10:54:08 [3191] >fcstp..... libs/perllib/LoxBerry/testing/mshttp_call.pl
      2023/04/27 10:54:08 [3191] >fcstp..... libs/perllib/LoxBerry/testing/mshttp_get.pl
      2023/04/27 10:54:08 [3191] >f+++++++++ libs/perllib/LoxBerry/testing/test_templatebuilder_http.cgi
      2023/04/27 10:54:08 [3191] >f+++++++++ libs/perllib/LoxBerry/testing/test_templatebuilder_udp.cgi
      2023/04/27 10:54:08 [3191] >f+++++++++ libs/perllib/LoxBerry/testing/testio_loxappversion3.pl
      2023/04/27 10:54:08 [3191] >fcstp..... libs/perllib/LoxBerry/testing/testnotify.pl
      2023/04/27 10:54:08 [3191] >fcstp..... libs/perllib/LoxBerry/testing/teststorage.cgi
      2023/04/27 10:54:08 [3191] .d..t...... libs/perllib/Net/
      2023/04/27 10:54:08 [3191] .d..t...... libs/perllib/Net/MQTT/
      2023/04/27 10:54:08 [3191] .d..t...... libs/perllib/Net/MQTT/Simple/
      2023/04/27 10:54:08 [3191] cd+++++++++ libs/perllib/Proc/
      2023/04/27 10:54:08 [3191] >f+++++++++ libs/perllib/Proc/CPUUsage.pm
      2023/04/27 10:54:08 [3191] .d..t...... libs/perllib/Unix/
      2023/04/27 10:54:08 [3191] .d..t...... libs/perllib/Unix/Lsof/
      2023/04/27 10:54:08 [3191] .d..t...... libs/phplib/
      2023/04/27 10:54:08 [3191] >fcstp..... libs/phplib/loxberry_io.php
      2023/04/27 10:54:08 [3191] >fcst...... libs/phplib/loxberry_log.php
      2023/04/27 10:54:08 [3191] >fcstp..... libs/phplib/loxberry_loxonetemplatebuilder.php
      2023/04/27 10:54:08 [3191] >fcstp..... libs/phplib/loxberry_storage.php
      2023/04/27 10:54:08 [3191] >fcstp..... libs/phplib/loxberry_web.php
      2023/04/27 10:54:08 [3191] .d..t...... libs/phplib/Config/
      2023/04/27 10:54:08 [3191] .d..t...... libs/phplib/Config/Lite/
      2023/04/27 10:54:08 [3191] .d..t...... libs/phplib/Config/Lite/Exception/
      2023/04/27 10:54:08 [3191] .d..t...... libs/phplib/Datto/
      2023/04/27 10:54:08 [3191] .d..t...... libs/phplib/Datto/JsonRpc/
      2023/04/27 10:54:08 [3191] .d..t...... libs/phplib/Datto/JsonRpc/Exceptions/
      2023/04/27 10:54:08 [3191] .d..t...... libs/phplib/LoxBerry/
      2023/04/27 10:54:08 [3191] .d..t...... libs/phplib/XL/
      2023/04/27 10:54:08 [3191] .d..t...... libs/phplib/phpMQTT/
      2023/04/27 10:54:08 [3191] .d..t...... libs/phplib/phpMQTT/examples/
      2023/04/27 10:54:08 [3191] .d..t...... libs/phplib/suncalc/
      2023/04/27 10:54:08 [3191] .d..t...... libs/phplib/testing/
      2023/04/27 10:54:08 [3191] >f+++++++++ libs/phplib/testing/test_loxonetemplatebuilder_http.php
      2023/04/27 10:54:08 [3191] >f+++++++++ libs/phplib/testing/test_loxonetemplatebuilder_udp.php
      2023/04/27 10:54:08 [3191] .d..t...... libs/phplib/testing/xl/
      2023/04/27 10:54:08 [3191] cd+++++++++ libs/pythonlib/
      2023/04/27 10:54:08 [3191] cd+++++++++ libs/pythonlib/sample_code/
      2023/04/27 10:54:08 [3191] >f+++++++++ libs/pythonlib/sample_code/mqtt_credentials.py
      2023/04/27 10:54:08 [3191] .d..t.og... sbin/
      2023/04/27 10:54:08 [3191] >f+++++++++ sbin/CA.pl
      2023/04/27 10:54:08 [3191] >fcst.og... sbin/changehostname.sh
      2023/04/27 10:54:08 [3191] >f+++++++++ sbin/checkcerts.sh
      2023/04/27 10:54:08 [3191] >fcst.og... sbin/clone_sd.pl
      2023/04/27 10:54:08 [3191] >fcst.og... sbin/clone_sd_cron.pl
      2023/04/27 10:54:08 [3191] >f+++++++++ sbin/createcert.sh
      2023/04/27 10:54:08 [3191] >fcst.og... sbin/createtmpfsfoldersinit.sh
      2023/04/27 10:54:08 [3191] >fcst.og... sbin/credentialshandler.pl
      2023/04/27 10:54:08 [3191] >f+++++++++ sbin/format_device.pl
      2023/04/27 10:54:08 [3191] >fcst.og... sbin/healthcheck.pl
      2023/04/27 10:54:08 [3191] >fcst.og... sbin/log_maint.pl
      2023/04/27 10:54:08 [3191] >fcst.og... sbin/loxberryinit.sh
      2023/04/27 10:54:08 [3191] >f+++++++++ sbin/makewwwcert.sh
      2023/04/27 10:54:08 [3191] >f+++++++++ sbin/mqtt-handler.pl
      2023/04/27 10:54:08 [3191] >fcst.og... sbin/mqttfinder.pl
      2023/04/27 10:54:08 [3191] >f+++++++++ sbin/mqttgateway.pl
      2023/04/27 10:54:09 [3191] >fcst.og... sbin/plugininstall.pl
      2023/04/27 10:54:09 [3191] >fcst.og... sbin/pluginsupdate.pl
      2023/04/27 10:54:09 [3191] >fcst.og... sbin/prepare_rpi-update.sh
      2023/04/27 10:54:09 [3191] >f+++++++++ sbin/pythonmoduleupgrade.sh
      2023/04/27 10:54:09 [3191] >f+++++++++ sbin/remoteconnect.pl
      2023/04/27 10:54:09 [3191] >fcst.og... sbin/resetpermissions.sh
      2023/04/27 10:54:09 [3191] >f+++++++++ sbin/revokewwwcert.sh
      2023/04/27 10:54:09 [3191] >fcst.og... sbin/serviceshelper
      2023/04/27 10:54:09 [3191] >fcst.og... sbin/sethosts.sh
      2023/04/27 10:54:09 [3191] >fcst.og... sbin/setloxberryid.pl
      2023/04/27 10:54:09 [3191] >fcst.og... sbin/setswap.pl
      2023/04/27 10:54:09 [3191] >fcst.og... sbin/ssdpd
      2023/04/27 10:54:09 [3191] >f+++++++++ sbin/test_clouddns.sh
      2023/04/27 10:54:09 [3191] >fcst.og... sbin/updaterebootwebserver.pl
      2023/04/27 10:54:09 [3191] >fcst.og... sbin/usb-mount.sh
      2023/04/27 10:54:09 [3191] .d..t.og... sbin/loxberryupdate/
      2023/04/27 10:54:09 [3191] >f+++++++++ sbin/loxberryupdate/mqtt_migration.pl
      2023/04/27 10:54:09 [3191] >fcst.og... sbin/loxberryupdate/update_v2.2.2.0.pl
      2023/04/27 10:54:09 [3191] >f+++++++++ sbin/loxberryupdate/update_v3.0.0.1.pl
      2023/04/27 10:54:09 [3191] >f+++++++++ sbin/loxberryupdate/update_v3.0.0.2.pl
      2023/04/27 10:54:09 [3191] >f+++++++++ sbin/loxberryupdate/update_v3.0.0.3.pl
      2023/04/27 10:54:09 [3191] >f+++++++++ sbin/loxberryupdate/update_v3.0.0.4.pl
      2023/04/27 10:54:09 [3191] >f+++++++++ sbin/loxberryupdate/update_v3.0.0.5.pl
      2023/04/27 10:54:09 [3191] >fcst.og... sbin/loxberryupdate/update_v3.0.0.pl
      2023/04/27 10:54:09 [3191] >f+++++++++ sbin/loxberryupdate/updateprecheck_v3.0.0.pl
      2023/04/27 10:54:09 [3191] >fcst.og... sbin/loxberryupdate/updatereboot_v3.0.0.pl
      2023/04/27 10:54:09 [3191] .d..t.og... sbin/notifyproviders/
      2023/04/27 10:54:09 [3191] .d..t...... templates/
      2023/04/27 10:54:09 [3191] .d..t...... templates/system/
      2023/04/27 10:54:09 [3191] >fcst...... templates/system/admin.html
      2023/04/27 10:54:09 [3191] >fcst...... templates/system/backup.html
      2023/04/27 10:54:09 [3191] >fcst...... templates/system/donate.html
      2023/04/27 10:54:09 [3191] >fcst...... templates/system/fileanalyzer.html
      2023/04/27 10:54:09 [3191] >f+++++++++ templates/system/format_device.html
      2023/04/27 10:54:09 [3191] >fcst...... templates/system/get_notification_html.html
      2023/04/27 10:54:09 [3191] >fcst...... templates/system/head.html
      2023/04/27 10:54:09 [3191] >fcst...... templates/system/index.html
      2023/04/27 10:54:09 [3191] >fcst...... templates/system/mailserver.html
      2023/04/27 10:54:09 [3191] >f+++++++++ templates/system/menu_mqtt.json
      2023/04/27 10:54:09 [3191] >fcst...... templates/system/miniserver.html
      2023/04/27 10:54:09 [3191] >f+++++++++ templates/system/mqtt-finder.html
      2023/04/27 10:54:09 [3191] >f+++++++++ templates/system/mqtt-gateway.html
      2023/04/27 10:54:09 [3191] >f+++++++++ templates/system/mqtt-quickpublisher.html
      2023/04/27 10:54:09 [3191] >f+++++++++ templates/system/mqtt.html
      2023/04/27 10:54:09 [3191] >fcst...... templates/system/myloxberry.html
      2023/04/27 10:54:09 [3191] >fcst...... templates/system/pageend.html
      2023/04/27 10:54:09 [3191] >fcst...... templates/system/pagestart.html
      2023/04/27 10:54:09 [3191] >f+++++++++ templates/system/pagestart_alternative.html
      2023/04/27 10:54:09 [3191] >fcst...... templates/system/plugininstall.html
      2023/04/27 10:54:09 [3191] >fcst...... templates/system/plugininstall_log.html
      2023/04/27 10:54:09 [3191] >fcst...... templates/system/power.html
      2023/04/27 10:54:09 [3191] >fcst...... templates/system/reboot_updaterunning.html
      2023/04/27 10:54:09 [3191] >fcst...... templates/system/remote.html
      2023/04/27 10:54:09 [3191] >fcst...... templates/system/services_timeserver.html
      2023/04/27 10:54:09 [3191] >f+++++++++ templates/system/temporary-footer.html
      2023/04/27 10:54:09 [3191] >f+++++++++ templates/system/temporary-header.html
      2023/04/27 10:54:09 [3191] >fcst...... templates/system/updates.html
      2023/04/27 10:54:09 [3191] >fcst...... templates/system/usbstorage.html
      2023/04/27 10:54:09 [3191] >f+++++++++ templates/system/vuenavbar.html
      2023/04/27 10:54:09 [3191] .d..t...... templates/system/countries/
      2023/04/27 10:54:09 [3191] .d..t...... templates/system/countries/ar/
      2023/04/27 10:54:09 [3191] .d..t...... templates/system/countries/cs/
      2023/04/27 10:54:09 [3191] .d..t...... templates/system/countries/da/
      2023/04/27 10:54:09 [3191] .d..t...... templates/system/countries/de/
      2023/04/27 10:54:09 [3191] .d..t...... templates/system/countries/ee/
      2023/04/27 10:54:09 [3191] .d..t...... templates/system/countries/el/
      2023/04/27 10:54:09 [3191] .d..t...... templates/system/countries/en/
      2023/04/27 10:54:09 [3191] .d..t...... templates/system/countries/es/
      2023/04/27 10:54:09 [3191] .d..t...... templates/system/countries/eu/
      2023/04/27 10:54:09 [3191] .d..t...... templates/system/countries/fr/
      2023/04/27 10:54:09 [3191] .d..t...... templates/system/countries/hu/
      2023/04/27 10:54:09 [3191] .d..t...... templates/system/countries/it/
      2023/04/27 10:54:09 [3191] .d..t...... templates/system/countries/ja/
      2023/04/27 10:54:09 [3191] .d..t...... templates/system/countries/ko/
      2023/04/27 10:54:09 [3191] .d..t...... templates/system/countries/lt/
      2023/04/27 10:54:09 [3191] .d..t...... templates/system/countries/nl/
      2023/04/27 10:54:09 [3191] .d..t...... templates/system/countries/no/
      2023/04/27 10:54:09 [3191] .d..t...... templates/system/countries/pl/
      2023/04/27 10:54:09 [3191] .d..t...... templates/system/countries/pt/
      2023/04/27 10:54:09 [3191] .d..t...... templates/system/countries/ro/
      2023/04/27 10:54:09 [3191] .d..t...... templates/system/countries/ru/
      2023/04/27 10:54:09 [3191] .d..t...... templates/system/countries/sk/
      2023/04/27 10:54:09 [3191] .d..t...... templates/system/countries/sv/
      2023/04/27 10:54:09 [3191] .d..t...... templates/system/countries/th/
      2023/04/27 10:54:09 [3191] .d..t...... templates/system/countries/uk/
      2023/04/27 10:54:09 [3191] .d..t...... templates/system/countries/zh-tw/
      2023/04/27 10:54:09 [3191] .d..t...... templates/system/countries/zh/
      2023/04/27 10:54:09 [3191] .d..t...... templates/system/de/
      2023/04/27 10:54:09 [3191] .d..t...... templates/system/en/
      2023/04/27 10:54:09 [3191] .d..t...... templates/system/es/
      2023/04/27 10:54:09 [3191] .d..t...... templates/system/help/
      2023/04/27 10:54:09 [3191] >fcst...... templates/system/help/help_myloxberry.html
      2023/04/27 10:54:09 [3191] >fcst...... templates/system/help/help_usbstorage.html
      2023/04/27 10:54:09 [3191] .d..t...... templates/system/lang/
      2023/04/27 10:54:09 [3191] >fcst...... templates/system/lang/help_mailserver_en.ini
      2023/04/27 10:54:09 [3191] >fcst...... templates/system/lang/help_plugininstall_de.ini
      2023/04/27 10:54:09 [3191] >fcst...... templates/system/lang/help_plugininstall_en.ini
      2023/04/27 10:54:09 [3191] >fcst...... templates/system/lang/help_plugininstall_nl.ini
      2023/04/27 10:54:09 [3191] >fcst...... templates/system/lang/help_usbstorage_de.ini
      2023/04/27 10:54:09 [3191] >fcst...... templates/system/lang/help_usbstorage_en.ini
      2023/04/27 10:54:09 [3191] >fcst...... templates/system/lang/language_de.ini
      2023/04/27 10:54:09 [3191] >fcst...... templates/system/lang/language_en.ini
      2023/04/27 10:54:09 [3191] >fcst...... templates/system/lang/language_es.ini
      2023/04/27 10:54:09 [3191] >fcst...... templates/system/lang/language_nl.ini
      2023/04/27 10:54:09 [3191] .d..t...... templates/system/network/
      2023/04/27 10:54:09 [3191] .d..t...... templates/system/notifyproviders/
      2023/04/27 10:54:09 [3191] .d..t...... webfrontend/
      2023/04/27 10:54:09 [3191] .d..t...... webfrontend/html/
      2023/04/27 10:54:09 [3191] .d..tp..... webfrontend/html/XL/
      2023/04/27 10:54:09 [3191] .d..tp..... webfrontend/html/XL/examples/
      2023/04/27 10:54:09 [3191] >f+++++++++ webfrontend/html/XL/examples/synology_chat.php
      2023/04/27 10:54:09 [3191] .d..t...... webfrontend/html/system/
      2023/04/27 10:54:09 [3191] cL+++++++++ webfrontend/html/system/cacert.cer -> ../../../data/system/LoxBerryCA/cacert.pem
      2023/04/27 10:54:09 [3191] >fcst...... webfrontend/html/system/ssdpdesc.php
      2023/04/27 10:54:09 [3191] .d..t...... webfrontend/html/system/css/
      2023/04/27 10:54:09 [3191] >fcst...... webfrontend/html/system/css/main.css
      2023/04/27 10:54:09 [3191] >f+++++++++ webfrontend/html/system/css/primeicons.css
      2023/04/27 10:54:09 [3191] cd+++++++++ webfrontend/html/system/css/fonts/
      2023/04/27 10:54:09 [3191] >f+++++++++ webfrontend/html/system/css/fonts/primeicons.eot
      2023/04/27 10:54:10 [3191] >f+++++++++ webfrontend/html/system/css/fonts/primeicons.svg
      2023/04/27 10:54:10 [3191] >f+++++++++ webfrontend/html/system/css/fonts/primeicons.ttf
      2023/04/27 10:54:10 [3191] >f+++++++++ webfrontend/html/system/css/fonts/primeicons.woff
      2023/04/27 10:54:10 [3191] .d..t...... webfrontend/html/system/error/
      2023/04/27 10:54:10 [3191] .d..t...... webfrontend/html/system/images/
      2023/04/27 10:54:10 [3191] >f+++++++++ webfrontend/html/system/images/LB_64.png
      2023/04/27 10:54:10 [3191] >f+++++++++ webfrontend/html/system/images/dice_30_30.png
      2023/04/27 10:54:10 [3191] >f+++++++++ webfrontend/html/system/images/icon-check.png
      2023/04/27 10:54:10 [3191] >f+++++++++ webfrontend/html/system/images/icon-filtered.png
      2023/04/27 10:54:10 [3191] >f+++++++++ webfrontend/html/system/images/icon-locked.png
      2023/04/27 10:54:10 [3191] >f+++++++++ webfrontend/html/system/images/icon-notfound.png
      2023/04/27 10:54:10 [3191] >f+++++++++ webfrontend/html/system/images/icon-question.png
      2023/04/27 10:54:10 [3191] >f+++++++++ webfrontend/html/system/images/icon-trash.png
      2023/04/27 10:54:10 [3191] >f+++++++++ webfrontend/html/system/images/loxberry_noberry.svg
      2023/04/27 10:54:10 [3191] .d..t...... webfrontend/html/system/images/icons/
      2023/04/27 10:54:10 [3191] >f+++++++++ webfrontend/html/system/images/icons/main_terminal.svg
      2023/04/27 10:54:10 [3191] .d..t...... webfrontend/html/system/scripts/
      2023/04/27 10:54:10 [3191] .d..t...... webfrontend/html/system/scripts/form-validator/
      2023/04/27 10:54:10 [3191] .d..t...... webfrontend/html/system/scripts/form-validator/lang/
      2023/04/27 10:54:10 [3191] .d..t...... webfrontend/html/system/scripts/form-validator/src/
      2023/04/27 10:54:10 [3191] .d..t...... webfrontend/html/system/scripts/jquery/
      2023/04/27 10:54:10 [3191] .d..t...... webfrontend/html/system/scripts/jquery/css/
      2023/04/27 10:54:10 [3191] .d..t...... webfrontend/html/system/scripts/jquery/js/
      2023/04/27 10:54:10 [3191] .d..t...... webfrontend/html/system/scripts/jquery/themes/
      2023/04/27 10:54:10 [3191] .d..t...... webfrontend/html/system/scripts/jquery/themes/main/
      2023/04/27 10:54:10 [3191] >fc.t...... webfrontend/html/system/scripts/jquery/themes/main/loxberry.css
      2023/04/27 10:54:10 [3191] >fc.t...... webfrontend/html/system/scripts/jquery/themes/main/loxberry.min.css
      2023/04/27 10:54:10 [3191] .d..t...... webfrontend/html/system/scripts/jquery/themes/main/images/
      2023/04/27 10:54:10 [3191] .d..t...... webfrontend/html/system/scripts/jquery/themes/main/images/icons-png/
      2023/04/27 10:54:10 [3191] .d..t...... webfrontend/html/system/scripts/vue3/
      2023/04/27 10:54:10 [3191] >f+++++++++ webfrontend/html/system/scripts/vue3/vue3.js
      2023/04/27 10:54:10 [3191] .d..t...... webfrontend/html/system/splash/
      2023/04/27 10:54:10 [3191] .d..t...... webfrontend/html/system/tools/
      2023/04/27 10:54:10 [3191] cd+++++++++ webfrontend/html/system/tools/mqtt/
      2023/04/27 10:54:10 [3191] >f+++++++++ webfrontend/html/system/tools/mqtt/receive.php
      2023/04/27 10:54:10 [3191] >f+++++++++ webfrontend/html/system/tools/mqtt/receive_pub.php
      2023/04/27 10:54:10 [3191] .d..t...... webfrontend/html/tmp/
      2023/04/27 10:54:10 [3191] .d..t...... webfrontend/htmlauth/
      2023/04/27 10:54:10 [3191] >fcst...... webfrontend/htmlauth/.htaccess
      2023/04/27 10:54:10 [3191] .d..t...... webfrontend/htmlauth/system/
      2023/04/27 10:54:10 [3191] >fcst...... webfrontend/htmlauth/system/admin.cgi
      2023/04/27 10:54:10 [3191] >fcst...... webfrontend/htmlauth/system/backup.cgi
      2023/04/27 10:54:10 [3191] >fcst...... webfrontend/htmlauth/system/donate.cgi
      2023/04/27 10:54:10 [3191] >fcst...... webfrontend/htmlauth/system/healthcheck.cgi
      2023/04/27 10:54:10 [3191] >fcst...... webfrontend/htmlauth/system/index.cgi
      2023/04/27 10:54:10 [3191] >fcst...... webfrontend/htmlauth/system/logmanager.cgi
      2023/04/27 10:54:10 [3191] >fcst...... webfrontend/htmlauth/system/mailserver.cgi
      2023/04/27 10:54:10 [3191] >fcst...... webfrontend/htmlauth/system/miniserver.cgi
      2023/04/27 10:54:10 [3191] >f+++++++++ webfrontend/htmlauth/system/mqtt-finder.cgi
      2023/04/27 10:54:10 [3191] >f+++++++++ webfrontend/htmlauth/system/mqtt-gateway.cgi
      2023/04/27 10:54:10 [3191] >f+++++++++ webfrontend/htmlauth/system/mqtt-quickpublisher.cgi
      2023/04/27 10:54:10 [3191] >f+++++++++ webfrontend/htmlauth/system/mqtt.cgi
      2023/04/27 10:54:10 [3191] >fcst...... webfrontend/htmlauth/system/myloxberry.cgi
      2023/04/27 10:54:10 [3191] >fcst...... webfrontend/htmlauth/system/netshares.cgi
      2023/04/27 10:54:10 [3191] >fcst...... webfrontend/htmlauth/system/network.cgi
      2023/04/27 10:54:10 [3191] >fcst...... webfrontend/htmlauth/system/plugininstall.cgi
      2023/04/27 10:54:10 [3191] >fcst...... webfrontend/htmlauth/system/power.cgi
      2023/04/27 10:54:10 [3191] >fcst...... webfrontend/htmlauth/system/remote.cgi
      2023/04/27 10:54:10 [3191] >fcst...... webfrontend/htmlauth/system/services.php
      2023/04/27 10:54:10 [3191] >fcst...... webfrontend/htmlauth/system/services_samba.cgi
      2023/04/27 10:54:10 [3191] >fcst...... webfrontend/htmlauth/system/services_timeserver.cgi
      2023/04/27 10:54:10 [3191] >fcst...... webfrontend/htmlauth/system/services_watchdog.cgi
      2023/04/27 10:54:10 [3191] >fcst...... webfrontend/htmlauth/system/testenv.php
      2023/04/27 10:54:10 [3191] >fcst...... webfrontend/htmlauth/system/translate.cgi
      2023/04/27 10:54:10 [3191] >fcst...... webfrontend/htmlauth/system/updates.cgi
      2023/04/27 10:54:10 [3191] >fcst...... webfrontend/htmlauth/system/usbstorage.cgi
      2023/04/27 10:54:10 [3191] .d..t...... webfrontend/htmlauth/system/ajax/
      2023/04/27 10:54:10 [3191] >fcst...... webfrontend/htmlauth/system/ajax/ajax-backup.cgi
      2023/04/27 10:54:10 [3191] >f+++++++++ webfrontend/htmlauth/system/ajax/ajax-check-miniserver.cgi
      2023/04/27 10:54:10 [3191] >f+++++++++ webfrontend/htmlauth/system/ajax/ajax-config-handler.cgi
      2023/04/27 10:54:10 [3191] >f+++++++++ webfrontend/htmlauth/system/ajax/ajax-download-handler.cgi
      2023/04/27 10:54:10 [3191] >f+++++++++ webfrontend/htmlauth/system/ajax/ajax-fileanalyzer.cgi
      2023/04/27 10:54:10 [3191] >f+++++++++ webfrontend/htmlauth/system/ajax/ajax-format_devices.cgi
      2023/04/27 10:54:10 [3191] >f+++++++++ webfrontend/htmlauth/system/ajax/ajax-generic.php
      2023/04/27 10:54:10 [3191] >f+++++++++ webfrontend/htmlauth/system/ajax/ajax-generic2.php
      2023/04/27 10:54:10 [3191] >f+++++++++ webfrontend/htmlauth/system/ajax/ajax-main-icons-handler.php
      2023/04/27 10:54:10 [3191] >f+++++++++ webfrontend/htmlauth/system/ajax/ajax-mqtt.php
      2023/04/27 10:54:10 [3191] >f+++++++++ webfrontend/htmlauth/system/ajax/ajax-notification-handler.cgi
      2023/04/27 10:54:10 [3191] >f+++++++++ webfrontend/htmlauth/system/ajax/ajax-remote.cgi
      2023/04/27 10:54:10 [3191] >f+++++++++ webfrontend/htmlauth/system/ajax/ajax-storage-handler.cgi
      2023/04/27 10:54:10 [3191] >f+++++++++ webfrontend/htmlauth/system/ajax/ajax_template.cgi
      2023/04/27 10:54:10 [3191] .d..t...... webfrontend/htmlauth/system/testing/
      2023/04/27 10:54:10 [3191] >fcst...... webfrontend/htmlauth/system/testing/csstest.php
      2023/04/27 10:54:10 [3191] >fcst...... webfrontend/htmlauth/system/testing/header_footer.php
      2023/04/27 10:54:10 [3191] >fcstp..... webfrontend/htmlauth/system/testing/teststorage.cgi
      2023/04/27 10:54:10 [3191] >fcst...... webfrontend/htmlauth/system/testing/teststorage.php
      2023/04/27 10:54:10 [3191] >fcstp..... webfrontend/htmlauth/system/testing/teststorage2.cgi
      2023/04/27 10:54:10 [3191] .d..t...... webfrontend/htmlauth/system/testing/nodejs-jsonrpc/
      2023/04/27 10:54:10 [3191] >fcst...... webfrontend/htmlauth/system/testing/nodejs-jsonrpc/node-rpc.cgi
      2023/04/27 10:54:10 [3191] .d..t...... webfrontend/htmlauth/system/testing/python3-jsonrpc/
      2023/04/27 10:54:10 [3191] .d..t...... webfrontend/htmlauth/system/tools/
      2023/04/27 10:54:10 [3191] >fcst...... webfrontend/htmlauth/system/tools/fileanalyzer.cgi
      2023/04/27 10:54:10 [3191] >f+++++++++ webfrontend/htmlauth/system/tools/format_device.cgi
      2023/04/27 10:54:10 [3191] >fcst...... webfrontend/htmlauth/system/tools/logfile.cgi
      2023/04/27 10:54:10 [3191] >f+++++++++ webfrontend/htmlauth/system/tools/mqtt.php
      2023/04/27 10:54:10 [3191] >fcst...... webfrontend/htmlauth/system/tools/netscan.cgi
      2023/04/27 10:54:10 [3191] >fcst...... webfrontend/htmlauth/system/tools/showalllogs_old.cgi
      2023/04/27 10:54:10 [3191] >fcst...... webfrontend/htmlauth/system/tools/showallnotifications.cgi
      2023/04/27 10:54:10 [3191] >fcst...... webfrontend/htmlauth/system/tools/showallnotifications.php
      2023/04/27 10:54:10 [3191] >fcst...... webfrontend/htmlauth/system/tools/showrawlogs.cgi
      2023/04/27 10:54:10 [3191] >fcst...... webfrontend/htmlauth/system/tools/showrawnotifications.cgi
      2023/04/27 10:54:10 [3191] >fcst...... webfrontend/htmlauth/system/tools/smtptest.cgi
      2023/04/27 10:54:10 [3191] .d..t...... webfrontend/htmlauth/system/tools/filemanager/
      2023/04/27 10:54:10 [3191] >fcst...... webfrontend/htmlauth/system/tools/filemanager/filemanager.php
      2023/04/27 10:54:10 [3191] .d..t...... webfrontend/htmlauth/system/tools/filemanager/src/
      2023/04/27 10:54:10 [3191] .d..t...... webfrontend/htmlauth/system/tools/linfo/
      2023/04/27 10:54:10 [3191] .d..t...... webfrontend/htmlauth/system/tools/linfo/cache/
      2023/04/27 10:54:10 [3191] >fcst...... webfrontend/htmlauth/system/tools/linfo/cache/ids_cache_3fc718a66e.json
      2023/04/27 10:54:10 [3191] .d..t...... webfrontend/htmlauth/system/tools/linfo/layout/
      2023/04/27 10:54:10 [3191] .d..t...... webfrontend/htmlauth/system/tools/linfo/layout/icons/
      2023/04/27 10:54:10 [3191] .d..t...... webfrontend/htmlauth/system/tools/linfo/layout/sass/
      2023/04/27 10:54:10 [3191] .d..t...... webfrontend/htmlauth/system/tools/linfo/src/
      2023/04/27 10:54:10 [3191] .d..t...... webfrontend/htmlauth/system/tools/linfo/src/Linfo/
      2023/04/27 10:54:10 [3191] .d..t...... webfrontend/htmlauth/system/tools/linfo/src/Linfo/Exceptions/
      2023/04/27 10:54:10 [3191] .d..t...... webfrontend/htmlauth/system/tools/linfo/src/Linfo/Extension/
      2023/04/27 10:54:10 [3191] .d..t...... webfrontend/htmlauth/system/tools/linfo/src/Linfo/Lang/
      2023/04/27 10:54:10 [3191] .d..t...... webfrontend/htmlauth/system/tools/linfo/src/Linfo/Meta/
      2023/04/27 10:54:10 [3191] .d..t...... webfrontend/htmlauth/system/tools/linfo/src/Linfo/OS/
      2023/04/27 10:54:10 [3191] .d..t...... webfrontend/htmlauth/system/tools/linfo/src/Linfo/Output/
      2023/04/27 10:54:10 [3191] .d..t...... webfrontend/htmlauth/system/tools/linfo/src/Linfo/Parsers/
      2023/04/27 10:54:10 [3191] .d..t...... webfrontend/htmlauth/system/tools/linfo/tests/
      2023/04/27 10:54:10 [3191] .d..t...... webfrontend/htmlauth/system/tools/linfo/tests/files/
      2023/04/27 10:54:10 [3191] .d..t...... webfrontend/htmlauth/system/tools/linfo/tests/files/linux/
      2023/04/27 10:54:10 [3191] .d..t...... webfrontend/htmlauth/system/tools/linfo/tests/files/linux/generic_distro/
      2023/04/27 10:54:10 [3191] .d..t...... webfrontend/htmlauth/system/tools/linfo/tests/files/linux/generic_distro/etc/
      2023/04/27 10:54:10 [3191] .d..t...... webfrontend/htmlauth/system/tools/linfo/tests/files/linux/generic_distro/proc/
      2023/04/27 10:54:10 [3191] .d..t...... webfrontend/htmlauth/system/tools/linfo/tests/files/linux/generic_distro/proc/asound/
      2023/04/27 10:54:10 [3191] .d..t...... webfrontend/htmlauth/system/tools/linfo/tests/files/linux/generic_distro/proc/sys/
      2023/04/27 10:54:10 [3191] .d..t...... webfrontend/htmlauth/system/tools/linfo/tests/files/linux/generic_distro/proc/sys/kernel/
      2023/04/27 10:54:10 [3191] .d..t...... webfrontend/htmlauth/system/tools/linfo/tests/files/linux/generic_distro/sys/
      2023/04/27 10:54:10 [3191] .d..t...... webfrontend/htmlauth/system/tools/linfo/tests/files/linux/generic_distro/sys/devices/
      2023/04/27 10:54:10 [3191] .d..t...... webfrontend/htmlauth/system/tools/linfo/tests/files/linux/generic_distro/sys/devices/virtual/
      2023/04/27 10:54:10 [3191] .d..t...... webfrontend/htmlauth/system/tools/linfo/tests/files/linux/generic_distro/sys/devices/virtual/dmi/
      2023/04/27 10:54:10 [3191] .d..t...... webfrontend/htmlauth/system/tools/linfo/tests/files/linux/generic_distro/sys/devices/virtual/dmi/id/
      2023/04/27 10:54:10 [3191] .d..t...... webfrontend/htmlauth/system/tools/linfo/tests/linfo/
      2023/04/27 10:54:10 [3191] .d..t...... webfrontend/htmlauth/system/tools/linfo/tests/os/
      2023/04/27 10:54:10 [3191] .d..t...... webfrontend/htmlauth/system/tools/linfo/tests/os/Darwin/
      2023/04/27 10:54:10 [3191] .d..t...... webfrontend/htmlauth/system/tools/linfo/tests/os/FreeBSD/
      2023/04/27 10:54:10 [3191] .d..t...... webfrontend/htmlauth/system/tools/linfo/tests/os/Linux/
      2023/04/27 10:54:10 [3191] sent 3.11M bytes  received 8.77K bytes  891.57K bytes/sec
      2023/04/27 10:54:10 [3191] total size is 11.60M  speedup is 3.72
      10:54:10.879 <OK> rsync finished successful.
      10:54:10.879 <INFO> Restoring permissions of /opt/loxberry of your LoxBerry...
      LoxBerry home directory is /opt/loxberry
      chmod loxberry:loxberry: 1765 files changed
      changed ownership of '/opt/loxberry/system/dphys-swapfile/dphys-swapfile.md5' from loxberry:loxberry to root:root
      changed ownership of '/opt/loxberry/system/dphys-swapfile/dphys-swapfile' from loxberry:loxberry to root:root
      changed ownership of '/opt/loxberry/system/dphys-swapfile/97-swappiness.conf' from loxberry:loxberry to root:root
      changed ownership of '/opt/loxberry/system/dphys-swapfile/97-swappiness.conf.md5' from loxberry:loxberry to root:root
      changed ownership of '/opt/loxberry/system/dphys-swapfile' from loxberry:loxberry to root:root
      changed ownership of '/opt/loxberry/system/daemons/plugins/mqttgateway' from loxberry:loxberry to root:root
      changed ownership of '/opt/loxberry/system/daemons/plugins/RPi-Monitor' from loxberry:loxberry to root:root
      changed ownership of '/opt/loxberry/system/daemons/plugins/.dummy' from loxberry:loxberry to root:root
      changed ownership of '/opt/loxberry/system/daemons/plugins/weather4lox' from loxberry:loxberry to root:root
      changed ownership of '/opt/loxberry/system/daemons/plugins' from loxberry:loxberry to root:root
      changed ownership of '/opt/loxberry/system/daemons' from loxberry:loxberry to root:root
      changed ownership of '/opt/loxberry/system/cron/cron.d/lbdefaults' from loxberry:loxberry to root:root
      changed ownership of '/opt/loxberry/system/cron/cron.d/.dummy' from loxberry:loxberry to root:root
      changed ownership of '/opt/loxberry/system/cron/cron.d/setloxberryid' from loxberry:loxberry to root:root
      changed ownership of '/opt/loxberry/system/cron/cron.d/lbclonesd' from loxberry:loxberry to root:root
      changed ownership of '/opt/loxberry/system/cron/cron.d/miniserverbackup' from loxberry:loxberry to root:root
      changed ownership of '/opt/loxberry/system/cron/cron.d/lbbackup' from loxberry:loxberry to root:root
      changed ownership of '/opt/loxberry/system/cron/cron.d/rpimonitor' from loxberry:loxberry to root:root
      changed ownership of '/opt/loxberry/system/cron/cron.d' from loxberry:loxberry to root:root
      changed ownership of '/opt/loxberry/sbin/remoteconnect.pl' from loxberry:loxberry to root:root
      changed ownership of '/opt/loxberry/sbin/pythonmoduleupgrade.sh' from loxberry:loxberry to root:root
      changed ownership of '/opt/loxberry/sbin/credentialshandler.pl' from loxberry:loxberry to root:root
      changed ownership of '/opt/loxberry/sbin/CA.pl' from loxberry:loxberry to root:root
      changed ownership of '/opt/loxberry/sbin/serviceshelper' from loxberry:loxberry to root:root
      changed ownership of '/opt/loxberry/sbin/openvpn' from loxberry:loxberry to root:root
      changed ownership of '/opt/loxberry/sbin/revokewwwcert.sh' from loxberry:loxberry to root:root
      changed ownership of '/opt/loxberry/sbin/files_analyzer.pl' from loxberry:loxberry to root:root
      changed ownership of '/opt/loxberry/sbin/testram.sh' from loxberry:loxberry to root:root
      changed ownership of '/opt/loxberry/sbin/setdatetime.pl' from loxberry:loxberry to root:root
      changed ownership of '/opt/loxberry/sbin/prepare_rpi-update.sh' from loxberry:loxberry to root:root
      changed ownership of '/opt/loxberry/sbin/makewwwcert.sh' from loxberry:loxberry to root:root
      changed ownership of '/opt/loxberry/sbin/plugininstall.pl' from loxberry:loxberry to root:root
      changed ownership of '/opt/loxberry/sbin/setmail' from loxberry:loxberry to root:root
      changed ownership of '/opt/loxberry/sbin/setloxberryid.pl' from loxberry:loxberry to root:root
      changed ownership of '/opt/loxberry/sbin/mqtt-handler.pl' from loxberry:loxberry to root:root
      changed ownership of '/opt/loxberry/sbin/ssdpd' from loxberry:loxberry to root:root
      changed ownership of '/opt/loxberry/sbin/openvpn-ip' from loxberry:loxberry to root:root
      changed ownership of '/opt/loxberry/sbin/watchdog_cron.pl' from loxberry:loxberry to root:root
      changed ownership of '/opt/loxberry/sbin/notifyproviders/email.pl' from loxberry:loxberry to root:root
      changed ownership of '/opt/loxberry/sbin/notifyproviders' from loxberry:loxberry to root:root
      changed ownership of '/opt/loxberry/sbin/healthcheck.pl' from loxberry:loxberry to root:root
      changed ownership of '/opt/loxberry/sbin/loxberryupdate_cron.sh' from loxberry:loxberry to root:root
      changed ownership of '/opt/loxberry/sbin/setrootpasswd.exp' from loxberry:loxberry to root:root
      changed ownership of '/opt/loxberry/sbin/loxberryupdate/update_v0.3.5.4.pl' from loxberry:loxberry to root:root
      changed ownership of '/opt/loxberry/sbin/loxberryupdate/update_v0.3.3.3.pl' from loxberry:loxberry to root:root
      changed ownership of '/opt/loxberry/sbin/loxberryupdate/update_v1.4.pl' from loxberry:loxberry to root:root
      changed ownership of '/opt/loxberry/sbin/loxberryupdate/update_v2.2.2.0.pl' from loxberry:loxberry to root:root
      changed ownership of '/opt/loxberry/sbin/loxberryupdate/update_v0.3.3.4.pl' from loxberry:loxberry to root:root
      changed ownership of '/opt/loxberry/sbin/loxberryupdate/update_v0.9.9.1.pl' from loxberry:loxberry to root:root
      changed ownership of '/opt/loxberry/sbin/loxberryupdate/update_v1.0.1.pl' from loxberry:loxberry to root:root
      changed ownership of '/opt/loxberry/sbin/loxberryupdate/updatereboot_v2.0.0.pl' from loxberry:loxberry to root:root
      changed ownership of '/opt/loxberry/sbin/loxberryupdate/update_v1.2.5.pl' from loxberry:loxberry to root:root
      changed ownership of '/opt/loxberry/sbin/loxberryupdate/update_v1.2.0.pl' from loxberry:loxberry to root:root
      changed ownership of '/opt/loxberry/sbin/loxberryupdate/update_v3.0.0.4.pl' from loxberry:loxberry to root:root
      changed ownership of '/opt/loxberry/sbin/loxberryupdate/update_v0.3.5.7.pl' from loxberry:loxberry to root:root
      changed ownership of '/opt/loxberry/sbin/loxberryupdate/update_v1.0.2.pl' from loxberry:loxberry to root:root
      changed ownership of '/opt/loxberry/sbin/loxberryupdate/updatereboot_v1.2.0.pl' from loxberry:loxberry to root:root
      changed ownership of '/opt/loxberry/sbin/loxberryupdate/update_v1.4.1.pl' from loxberry:loxberry to root:root
      changed ownership of '/opt/loxberry/sbin/loxberryupdate/update_v2.0.2.1.pl' from loxberry:loxberry to root:root
      changed ownership of '/opt/loxberry/sbin/loxberryupdate/update_v2.2.1.2.pl' from loxberry:loxberry to root:root
      changed ownership of '/opt/loxberry/sbin/loxberryupdate/update_v0.3.3.5.pl' from loxberry:loxberry to root:root
      changed ownership of '/opt/loxberry/sbin/loxberryupdate/update_v3.0.0.pl' from loxberry:loxberry to root:root
      changed ownership of '/opt/loxberry/sbin/loxberryupdate/update_v3.0.0.3.pl' from loxberry:loxberry to root:root
      changed ownership of '/opt/loxberry/sbin/loxberryupdate/update_v2.2.1.1.pl' from loxberry:loxberry to root:root
      changed ownership of '/opt/loxberry/sbin/loxberryupdate/update_v2.0.0.4.pl' from loxberry:loxberry to root:root
      changed ownership of '/opt/loxberry/sbin/loxberryupdate/update_v2.2.0.pl' from loxberry:loxberry to root:root
      changed ownership of '/opt/loxberry/sbin/loxberryupdate/update_v1.2.2.pl' from loxberry:loxberry to root:root
      changed ownership of '/opt/loxberry/sbin/loxberryupdate/update_v1.2.4.1.pl' from loxberry:loxberry to root:root
      changed ownership of '/opt/loxberry/sbin/loxberryupdate/updatereboot_v2.2.0.pl' from loxberry:loxberry to root:root
      changed ownership of '/opt/loxberry/sbin/loxberryupdate/update_v1.4.0.3.pl' from loxberry:loxberry to root:root
      changed ownership of '/opt/loxberry/sbin/loxberryupdate/update_v1.2.0.3.pl' from loxberry:loxberry to root:root
      changed ownership of '/opt/loxberry/sbin/loxberryupdate/update_v3.0.0.2.pl' from loxberry:loxberry to root:root
      changed ownership of '/opt/loxberry/sbin/loxberryupdate/update_v1.2.1.2.pl' from loxberry:loxberry to root:root
      changed ownership of '/opt/loxberry/sbin/loxberryupdate/update_v0.3.5.6.pl' from loxberry:loxberry to root:root
      changed ownership of '/opt/loxberry/sbin/loxberryupdate/update_v1.2.3.pl' from loxberry:loxberry to root:root
      changed ownership of '/opt/loxberry/sbin/loxberryupdate/.dummy' from loxberry:loxberry to root:root
      changed ownership of '/opt/loxberry/sbin/loxberryupdate/update_v3.0.0.1.pl' from loxberry:loxberry to root:root
      changed ownership of '/opt/loxberry/sbin/loxberryupdate/update_v1.2.4.2.pl' from loxberry:loxberry to root:root
      changed ownership of '/opt/loxberry/sbin/loxberryupdate/update_v1.0.4.1.pl' from loxberry:loxberry to root:root
      changed ownership of '/opt/loxberry/sbin/loxberryupdate/update_v2.2.0.5.pl' from loxberry:loxberry to root:root
      changed ownership of '/opt/loxberry/sbin/loxberryupdate/update_v1.2.1.pl' from loxberry:loxberry to root:root
      changed ownership of '/opt/loxberry/sbin/loxberryupdate/update_v1.2.5.3.pl' from loxberry:loxberry to root:root
      changed ownership of '/opt/loxberry/sbin/loxberryupdate/update_v1.0.4.pl' from loxberry:loxberry to root:root
      changed ownership of '/opt/loxberry/sbin/loxberryupdate/update_v2.0.1.pl' from loxberry:loxberry to root:root
      changed ownership of '/opt/loxberry/sbin/loxberryupdate/updatereboot_v1.4.0.pl' from loxberry:loxberry to root:root
      changed ownership of '/opt/loxberry/sbin/loxberryupdate/update_v1.0.3.pl' from loxberry:loxberry to root:root
      changed ownership of '/opt/loxberry/sbin/loxberryupdate/update_v1.2.2.2.pl' from loxberry:loxberry to root:root
      changed ownership of '/opt/loxberry/sbin/loxberryupdate/update_v0.3.3.1.pl' from loxberry:loxberry to root:root
      changed ownership of '/opt/loxberry/sbin/loxberryupdate/update_v2.0.0.2.pl' from loxberry:loxberry to root:root
      changed ownership of '/opt/loxberry/sbin/loxberryupdate/update_v1.2.0.1.pl' from loxberry:loxberry to root:root
      changed ownership of '/opt/loxberry/sbin/loxberryupdate/updatereboot_v3.0.0.pl' from loxberry:loxberry to root:root
      changed ownership of '/opt/loxberry/sbin/loxberryupdate/update_v2.0.2.2.pl' from loxberry:loxberry to root:root
      changed ownership of '/opt/loxberry/sbin/loxberryupdate/update_v1.4.2.pl' from loxberry:loxberry to root:root
      changed ownership of '/opt/loxberry/sbin/loxberryupdate/update_v1.0.3.1.pl' from loxberry:loxberry to root:root
      changed ownership of '/opt/loxberry/sbin/loxberryupdate/update_v3.0.0.5.pl' from loxberry:loxberry to root:root
      changed ownership of '/opt/loxberry/sbin/loxberryupdate/mqtt_migration.pl' from loxberry:loxberry to root:root
      changed ownership of '/opt/loxberry/sbin/loxberryupdate/update_v0.3.5.3.pl' from loxberry:loxberry to root:root
      changed ownership of '/opt/loxberry/sbin/loxberryupdate/update_v2.0.0.pl' from loxberry:loxberry to root:root
      changed ownership of '/opt/loxberry/sbin/loxberryupdate/update_v0.3.5.5.pl' from loxberry:loxberry to root:root
      changed ownership of '/opt/loxberry/sbin/loxberryupdate/update_v2.0.0.1.pl' from loxberry:loxberry to root:root
      changed ownership of '/opt/loxberry/sbin/loxberryupdate/update_v1.2.4.pl' from loxberry:loxberry to root:root
      changed ownership of '/opt/loxberry/sbin/loxberryupdate/updateprecheck_v3.0.0.pl' from loxberry:loxberry to root:root
      changed ownership of '/opt/loxberry/sbin/loxberryupdate/update_v2.2.0.3.pl' from loxberry:loxberry to root:root
      changed ownership of '/opt/loxberry/sbin/loxberryupdate/update_v2.0.2.pl' from loxberry:loxberry to root:root
      changed ownership of '/opt/loxberry/sbin/loxberryupdate/update_v0.3.1.pl' from loxberry:loxberry to root:root
      changed ownership of '/opt/loxberry/sbin/loxberryupdate' from loxberry:loxberry to root:root
      changed ownership of '/opt/loxberry/sbin/setswap.pl' from loxberry:loxberry to root:root
      changed ownership of '/opt/loxberry/sbin/usb-mount.sh' from loxberry:loxberry to root:root
      changed ownership of '/opt/loxberry/sbin/createpluginfolders.pl' from loxberry:loxberry to root:root
      changed ownership of '/opt/loxberry/sbin/log_maint.pl' from loxberry:loxberry to root:root
      changed ownership of '/opt/loxberry/sbin/loxberryupdatecheck.pl' from loxberry:loxberry to root:root
      changed ownership of '/opt/loxberry/sbin/mqttgateway.pl' from loxberry:loxberry to root:root
      changed ownership of '/opt/loxberry/sbin/pluginsupdate.pl' from loxberry:loxberry to root:root
      changed ownership of '/opt/loxberry/sbin/sethosts.sh' from loxberry:loxberry to root:root
      changed ownership of '/opt/loxberry/sbin/changehostname.sh' from loxberry:loxberry to root:root
      changed ownership of '/opt/loxberry/sbin/checkcerts.sh' from loxberry:loxberry to root:root
      changed ownership of '/opt/loxberry/sbin/createskelfolders.pl' from loxberry:loxberry to root:root
      changed ownership of '/opt/loxberry/sbin/testbashenv.sh' from loxberry:loxberry to root:root
      changed ownership of '/opt/loxberry/sbin/emergencywebserver.pl' from loxberry:loxberry to root:root
      changed ownership of '/opt/loxberry/sbin/clone_sd.pl' from loxberry:loxberry to root:root
      changed ownership of '/opt/loxberry/sbin/clone_sd_cron.pl' from loxberry:loxberry to root:root
      changed ownership of '/opt/loxberry/sbin/resetpermissions.sh' from loxberry:loxberry to root:root
      changed ownership of '/opt/loxberry/sbin/setserial' from loxberry:loxberry to root:root
      changed ownership of '/opt/loxberry/sbin/mqttfinder.pl' from loxberry:loxberry to root:root
      changed ownership of '/opt/loxberry/sbin/loxberryupdate.pl' from loxberry:loxberry to root:root
      changed ownership of '/opt/loxberry/sbin/test_clouddns.sh' from loxberry:loxberry to root:root
      changed ownership of '/opt/loxberry/sbin/resize_rootfs' from loxberry:loxberry to root:root
      changed ownership of '/opt/loxberry/sbin/loxberryinit.sh' from loxberry:loxberry to root:root
      changed ownership of '/opt/loxberry/sbin/format_device.pl' from loxberry:loxberry to root:root
      changed ownership of '/opt/loxberry/sbin/testenvironment.sh' from loxberry:loxberry to root:root
      changed ownership of '/opt/loxberry/sbin/updaterebootwebserver.pl' from loxberry:loxberry to root:root
      changed ownership of '/opt/loxberry/sbin/createcert.sh' from loxberry:loxberry to root:root
      changed ownership of '/opt/loxberry/sbin/createtmpfsfoldersinit.sh' from loxberry:loxberry to root:root
      changed ownership of '/opt/loxberry/sbin/migrate_generalcfg.pl' from loxberry:loxberry to root:root
      changed ownership of '/opt/loxberry/sbin/sleeper.sh' from loxberry:loxberry to root:root
      changed ownership of '/opt/loxberry/sbin/testenvironment.pl' from loxberry:loxberry to root:root
      changed ownership of '/opt/loxberry/sbin/installcrontab.sh' from loxberry:loxberry to root:root
      changed ownership of '/opt/loxberry/sbin' from loxberry:loxberry to root:root
      changed ownership of '/opt/loxberry/system/logrotate/logrotate' from loxberry:loxberry to root:root
      changed ownership of '/opt/loxberry/system/logrotate' from loxberry:loxberry to root:root
      changed ownership of '/opt/loxberry/system/php/loxberry-apache.ini' from loxberry:loxberry to root:root
      changed ownership of '/opt/loxberry/system/php/loxberry-cli.ini' from loxberry:loxberry to root:root
      changed ownership of '/opt/loxberry/system/php' from loxberry:loxberry to root:root
      changed ownership of '/opt/loxberry/config/system/securepin.dat' from loxberry:loxberry to root:root
      changed ownership of '/opt/loxberry/data/system/plugindatabase.json-' from loxberry:loxberry to root:root
      changed ownership of '/opt/loxberry/system/profile/loxberry.sh' from loxberry:loxberry to root:root
      changed ownership of '/opt/loxberry/system/vsftpd/vsftpd.conf' from loxberry:loxberry to root:root
      mode of '/opt/loxberry/config/system/ca.cnf' changed from 0644 (rw-r--r--) to 0600 (rw-------)
      mode of '/opt/loxberry/config/system/general.cfg.default' changed from 0644 (rw-r--r--) to 0600 (rw-------)
      mode of '/opt/loxberry/config/system/general.json' changed from 0644 (rw-r--r--) to 0600 (rw-------)
      mode of '/opt/loxberry/config/system/general.json.default' changed from 0644 (rw-r--r--) to 0600 (rw-------)
      mode of '/opt/loxberry/config/system/htusers.dat.default' changed from 0644 (rw-r--r--) to 0600 (rw-------)
      mode of '/opt/loxberry/config/system/languages.default' changed from 0644 (rw-r--r--) to 0600 (rw-------)
      mode of '/opt/loxberry/config/system/lockfiles.default' changed from 0644 (rw-r--r--) to 0600 (rw-------)
      mode of '/opt/loxberry/config/system/mail.json.default' changed from 0644 (rw-r--r--) to 0600 (rw-------)
      mode of '/opt/loxberry/config/system/securepin.dat' changed from 0644 (rw-r--r--) to 0600 (rw-------)
      mode of '/opt/loxberry/config/system/securepin.dat.default' changed from 0644 (rw-r--r--) to 0600 (rw-------)
      mode of '/opt/loxberry/config/system/update-exclude.system' changed from 0644 (rw-r--r--) to 0600 (rw-------)
      mode of '/opt/loxberry/config/system/securepin.dat' changed from 0600 (rw-------) to 0644 (rw-r--r--)
      mode of '/opt/loxberry/config/system/general.backup_1604314324.cfg' changed from 0600 (rw-------) to 0644 (rw-r--r--)
      mode of '/opt/loxberry/config/system/general.cfg' changed from 0600 (rw-------) to 0644 (rw-r--r--)
      mode of '/opt/loxberry/config/system/general.cfg.default' changed from 0600 (rw-------) to 0644 (rw-r--r--)
      mode of '/opt/loxberry/config/system/general.json' changed from 0600 (rw-------) to 0644 (rw-r--r--)
      mode of '/opt/loxberry/config/system/general.json.default' changed from 0600 (rw-------) to 0644 (rw-r--r--)
      mode of '/opt/loxberry/libs/pythonlib/sample_code/mqtt_credentials.py' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/libs/perllib/Data/Dump.pm' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/libs/perllib/Hash/Flatten.pm' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/libs/perllib/Unix/Lsof/Result.pm' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/libs/perllib/Unix/Lsof.pm' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/libs/perllib/LoxBerry/testing/xmlparse.pl' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/libs/perllib/LoxBerry/testing/testlog.pl' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/libs/perllib/LoxBerry/testing/testlock.pl' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/libs/perllib/LoxBerry/testing/test_htmlmail.pl' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/libs/perllib/LoxBerry/testing/testlogdb.pl' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/libs/perllib/LoxBerry/testing/json_jsblock.cgi' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/libs/perllib/LoxBerry/testing/test_general.pl' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/libs/perllib/LoxBerry/testing/sqlite.pl' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/libs/perllib/LoxBerry/testing/json_flat.pl' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/libs/perllib/LoxBerry/testing/testio_loxappversion3.pl' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/libs/perllib/LoxBerry/testing/mshttp_call.pl' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/libs/perllib/LoxBerry/testing/mshttp_get.pl' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/libs/perllib/LoxBerry/testing/testlog_noobject.pl' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/libs/perllib/LoxBerry/testing/test_plugindb_v2.pl' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/libs/perllib/LoxBerry/testing/testlog_loglevelchange.pl' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/libs/perllib/LoxBerry/testing/mqtt_publish.pl' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/libs/perllib/LoxBerry/testing/json_testing.pl' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/libs/perllib/LoxBerry/testing/testgetminiservers.pl' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/libs/perllib/LoxBerry/testing/teststorage.cgi' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/libs/perllib/LoxBerry/testing/testlock2.pl' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/libs/perllib/LoxBerry/testing/mqtt_rapidpublish.pl' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/libs/perllib/LoxBerry/testing/get_miniservers.pl' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/libs/perllib/LoxBerry/testing/readlang.pl' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/libs/perllib/LoxBerry/testing/lbcountry.pl' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/libs/perllib/LoxBerry/testing/notif.pl' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/libs/perllib/LoxBerry/testing/mqtt_get.pl' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/libs/perllib/LoxBerry/testing/testlock3.pl' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/libs/perllib/LoxBerry/testing/version.pl' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/libs/perllib/LoxBerry/testing/json_param.pl' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/libs/perllib/LoxBerry/testing/test_get_miniservers.pl' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/libs/perllib/LoxBerry/testing/test_plugindb_shadow.pl' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/libs/perllib/LoxBerry/testing/testio_http.pl' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/libs/perllib/LoxBerry/testing/jsontestdata2.json' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/libs/perllib/LoxBerry/testing/test_templatebuilder_http.cgi' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/libs/perllib/LoxBerry/testing/testssl.pl' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/libs/perllib/LoxBerry/testing/testio_udp.pl' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/libs/perllib/LoxBerry/testing/json_encode.pl' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/libs/perllib/LoxBerry/testing/get_notification_count.pl' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/libs/perllib/LoxBerry/testing/sqlite.php' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/libs/perllib/LoxBerry/testing/json_lockexclusive.pl' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/libs/perllib/LoxBerry/testing/test_get_ftpport.pl' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/libs/perllib/LoxBerry/testing/json_param.tmpl' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/libs/perllib/LoxBerry/testing/check_secpin.pl' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/libs/perllib/LoxBerry/testing/testrebootrequired.pl' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/libs/perllib/LoxBerry/testing/test_templatebuilder_udp.cgi' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/libs/perllib/LoxBerry/testing/json_writeonclose.pl' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/libs/perllib/LoxBerry/testing/currtime.pl' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/libs/perllib/LoxBerry/testing/testexecute.pl' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/libs/perllib/LoxBerry/testing/testlog_attentionmessages.pl' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/libs/perllib/LoxBerry/testing/testsystem.pl' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/libs/perllib/LoxBerry/testing/testmqttcred.pl' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/libs/perllib/LoxBerry/testing/testnotify.pl' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/libs/perllib/LoxBerry/testing/ipv6_localhost.pl' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/libs/perllib/LoxBerry/testing/teststoragehtml.cgi' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/libs/perllib/LoxBerry/testing/Lock.pm' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/libs/perllib/LoxBerry/testing/testlog_recreate.pl' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/libs/perllib/LoxBerry/testing/epoch2lox.pl' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/libs/perllib/LoxBerry/examples/mqtt_publish_direct.pl' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/libs/perllib/LoxBerry/examples/mqtt_publish_via_udp.pl' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/libs/perllib/LoxBerry/System/General.pm' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/libs/perllib/LoxBerry/System/PluginDB.pm' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/libs/perllib/LoxBerry/MQTTGateway/IO.pm' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/libs/perllib/Net/MQTT/Simple/SSL.pm' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/libs/perllib/Net/MQTT/Simple.pm' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/libs/perllib/File/Samba.pm' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/libs/perllib/Proc/CPUUsage.pm' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/libs/perllib/Embed/Persistent.pm' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/libs/phplib/testing/xl/test_xl.php' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/libs/phplib/testing/xl/test_xlmqtt.php' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/libs/phplib/testing/xl/test_xl_constants.php' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/libs/phplib/testing/xl/test_xl_suncalc.php' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/libs/phplib/testing/xl/test_xl2.php' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/libs/phplib/testing/epoch2lox.php' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/libs/phplib/testing/testlang.php' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/libs/phplib/testing/mshttp.php' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/libs/phplib/testing/lbcountry.php' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/libs/phplib/testing/testlog_noobject.php' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/libs/phplib/testing/testnotify_ext.php' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/libs/phplib/testing/testscript_loxberry_system.php' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/libs/phplib/testing/test_get_miniservers.php' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/libs/phplib/testing/testlbweb.php' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/libs/phplib/testing/mqtt_connect.php' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/libs/phplib/testing/mqtt_publish.php' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/libs/phplib/testing/currtime.php' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/libs/phplib/testing/xmlparse.php' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/libs/phplib/testing/testgetminiservers.php' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/libs/phplib/testing/testlog.php' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/libs/phplib/testing/testsystem_plugins.php' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/libs/phplib/testing/test_loxberryjson.php' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/libs/phplib/testing/testrebootrequired.php' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/libs/phplib/testing/msudp_send.php' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/libs/phplib/testing/token2.php' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/libs/phplib/testing/testnotify.php' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/libs/phplib/testing/token.php' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/libs/phplib/testing/testlog_attentionmessages.pl' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/libs/phplib/testing/testlog_recreate.php' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/libs/phplib/testing/test_log_changeloglevel.php' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/libs/phplib/testing/jsonrpc-client-test.php' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/libs/phplib/testing/test_loxonetemplatebuilder_http.php' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/libs/phplib/testing/testlog_renew_session.php' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/libs/phplib/testing/test_loxonetemplatebuilder_udp.php' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/libs/phplib/testing/mqtt_connectiondetails.php' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/libs/phplib/phpMQTT/composer.json' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/libs/phplib/phpMQTT/examples/publish.php' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/libs/phplib/phpMQTT/examples/subscribe.php' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/libs/phplib/phpMQTT/examples/README.md' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/libs/phplib/phpMQTT/phpMQTT.php' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/libs/phplib/phpMQTT/LICENSE' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/libs/phplib/phpMQTT/README' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/libs/phplib/XL/waze.php' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/libs/phplib/loxberry_web.php' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/libs/phplib/loxberry_storage.php' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/libs/phplib/Config/Lite/Exception/Runtime.php' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/libs/phplib/Config/Lite/Exception/InvalidArgument.php' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/libs/phplib/Config/Lite/Exception/UnexpectedValue.php' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/libs/phplib/Config/Lite.php' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/libs/phplib/Datto/JsonRpc/Error.php' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/libs/phplib/Datto/JsonRpc/Evaluator.php' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/libs/phplib/Datto/JsonRpc/Client.php' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/libs/phplib/Datto/JsonRpc/Response.php' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/libs/phplib/Datto/JsonRpc/Exceptions/ImplementationException.php' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/libs/phplib/Datto/JsonRpc/Exceptions/Exception.php' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/libs/phplib/Datto/JsonRpc/Exceptions/MethodException.php' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/libs/phplib/Datto/JsonRpc/Exceptions/ApplicationException.php' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/libs/phplib/Datto/JsonRpc/Exceptions/ArgumentException.php' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/libs/phplib/Datto/JsonRpc/Server.php' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/libs/phplib/LoxBerry/JsonRpcApi.php' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/libs/phplib/loxberry_io.php' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/libs/phplib/loxberry_json.php' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/libs/phplib/loxberry_system.php' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/libs/phplib/suncalc/composer.json' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/libs/phplib/suncalc/LICENSE' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/libs/phplib/suncalc/suncalc.php' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/libs/phplib/suncalc/README.md' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/libs/phplib/loxberry_loxonetemplatebuilder.php' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/libs/phplib/loxberry_XL.php' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/libs/bashlib/testing/testnotify.sh' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/libs/bashlib/iniparser.sh' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/libs/bashlib/notify.sh' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/libs/bashlib/initlog_obsolete.pl' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/libs/bashlib/initlog.php' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/sbin/notifyproviders/email.pl' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/sbin/loxberryupdate/.dummy' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/bin/dirtree_md5.pl' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/webfrontend/htmlauth/system/testing/teststorage.cgi' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/webfrontend/htmlauth/system/testing/teststorage2.cgi' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/webfrontend/htmlauth/system/testing/test-interfaces.pl' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
      mode of '/opt/loxberry/webfrontend/html/XL' changed from 0755 (rwxr-xr-x) to 0500 (r-x------)
      mode of '/opt/loxberry/webfrontend/html/XL/examples' changed from 0755 (rwxr-xr-x) to 0500 (r-x------)
      mode of '/opt/loxberry/webfrontend/html/XL/important_info.txt' changed from 0644 (rw-r--r--) to 0500 (r-x------)
      mode of '/opt/loxberry/webfrontend/html/XL/user' changed from 0700 (rwx------) to 0500 (r-x------)
      mode of '/opt/loxberry/webfrontend/html/XL/user' changed from 0500 (r-x------) to 0700 (rwx------)
      mode of '/opt/loxberry/webfrontend/html/XL/examples/austria_covid_bezirk.php' changed from 0644 (rw-r--r--) to 0700 (rwx------)
      mode of '/opt/loxberry/webfrontend/html/XL/examples/austria_ooe_wasserpegel.php' changed from 0644 (rw-r--r--) to 0700 (rwx------)
      mode of '/opt/loxberry/webfrontend/html/XL/examples/de_bundesliga.php' changed from 0644 (rw-r--r--) to 0700 (rwx------)
      mode of '/opt/loxberry/webfrontend/html/XL/examples/empty_template.php' changed from 0644 (rw-r--r--) to 0700 (rwx------)
      mode of '/opt/loxberry/webfrontend/html/XL/examples/gruenland.php' changed from 0644 (rw-r--r--) to 0700 (rwx------)
      mode of '/opt/loxberry/webfrontend/html/XL/examples/synology_chat.php' changed from 0644 (rw-r--r--) to 0700 (rwx------)
      mode of '/opt/loxberry/webfrontend/html/XL/examples/waze_routing.php' changed from 0644 (rw-r--r--) to 0700 (rwx------)
      10:54:11.395 <OK> Restoring permissions was successful.
      10:54:11.396 <INFO> Searching and preparing update scripts...
      10:54:11.405 <INFO> Reading current update script fail state from general configuration...
      10:54:11.412 <OK> All previously executed update scripts were successful.
      10:54:11.412 <INFO> Running update scripts...
      10:54:11.413 <INFO>    Script version: v0.3.1
      10:54:11.413 <INFO>       Skipping. v0.3.1 too old version.
      10:54:11.413 <INFO>    Script version: v0.3.3.1
      10:54:11.413 <INFO>       Skipping. v0.3.3.1 too old version.
      10:54:11.413 <INFO>    Script version: v0.3.3.3
      10:54:11.413 <INFO>       Skipping. v0.3.3.3 too old version.
      10:54:11.414 <INFO>    Script version: v0.3.3.4
      10:54:11.414 <INFO>       Skipping. v0.3.3.4 too old version.
      10:54:11.414 <INFO>    Script version: v0.3.3.5
      10:54:11.414 <INFO>       Skipping. v0.3.3.5 too old version.
      10:54:11.414 <INFO>    Script version: v0.3.5.3
      10:54:11.414 <INFO>       Skipping. v0.3.5.3 too old version.
      10:54:11.415 <INFO>    Script version: v0.3.5.4
      10:54:11.415 <INFO>       Skipping. v0.3.5.4 too old version.
      10:54:11.415 <INFO>    Script version: v0.3.5.5
      10:54:11.415 <INFO>       Skipping. v0.3.5.5 too old version.
      10:54:11.415 <INFO>    Script version: v0.3.5.6
      10:54:11.415 <INFO>       Skipping. v0.3.5.6 too old version.
      10:54:11.415 <INFO>    Script version: v0.3.5.7
      10:54:11.416 <INFO>       Skipping. v0.3.5.7 too old version.
      10:54:11.416 <INFO>    Script version: v0.9.9.1
      10:54:11.416 <INFO>       Skipping. v0.9.9.1 too old version.
      10:54:11.416 <INFO>    Script version: v1.0.1
      10:54:11.416 <INFO>       Skipping. v1.0.1 too old version.
      10:54:11.416 <INFO>    Script version: v1.0.2
      10:54:11.417 <INFO>       Skipping. v1.0.2 too old version.
      10:54:11.417 <INFO>    Script version: v1.0.3
      10:54:11.417 <INFO>       Skipping. v1.0.3 too old version.
      10:54:11.417 <INFO>    Script version: v1.0.3.1
      10:54:11.417 <INFO>       Skipping. v1.0.3.1 too old version.
      10:54:11.417 <INFO>    Script version: v1.0.4
      10:54:11.417 <INFO>       Skipping. v1.0.4 too old version.
      10:54:11.418 <INFO>    Script version: v1.0.4.1
      10:54:11.418 <INFO>       Skipping. v1.0.4.1 too old version.
      10:54:11.418 <INFO>    Script version: v1.2.0
      10:54:11.418 <INFO>       Skipping. v1.2.0 too old version.
      10:54:11.418 <INFO>    Script version: v1.2.0.1
      10:54:11.418 <INFO>       Skipping. v1.2.0.1 too old version.
      10:54:11.419 <INFO>    Script version: v1.2.0.3
      10:54:11.419 <INFO>       Skipping. v1.2.0.3 too old version.
      10:54:11.419 <INFO>    Script version: v1.2.1
      10:54:11.419 <INFO>       Skipping. v1.2.1 too old version.
      10:54:11.419 <INFO>    Script version: v1.2.1.2
      10:54:11.419 <INFO>       Skipping. v1.2.1.2 too old version.
      10:54:11.419 <INFO>    Script version: v1.2.2
      10:54:11.420 <INFO>       Skipping. v1.2.2 too old version.
      10:54:11.420 <INFO>    Script version: v1.2.2.2
      10:54:11.420 <INFO>       Skipping. v1.2.2.2 too old version.
      10:54:11.420 <INFO>    Script version: v1.2.3
      10:54:11.420 <INFO>       Skipping. v1.2.3 too old version.
      10:54:11.420 <INFO>    Script version: v1.2.4
      10:54:11.421 <INFO>       Skipping. v1.2.4 too old version.
      10:54:11.421 <INFO>    Script version: v1.2.4.1
      10:54:11.421 <INFO>       Skipping. v1.2.4.1 too old version.
      10:54:11.421 <INFO>    Script version: v1.2.4.2
      10:54:11.421 <INFO>       Skipping. v1.2.4.2 too old version.
      10:54:11.421 <INFO>    Script version: v1.2.5
      10:54:11.421 <INFO>       Skipping. v1.2.5 too old version.
      10:54:11.422 <INFO>    Script version: v1.2.5.3
      10:54:11.422 <INFO>       Skipping. v1.2.5.3 too old version.
      10:54:11.422 <INFO>    Script version: v1.4
      10:54:11.422 <INFO>       Skipping. v1.4 too old version.
      10:54:11.422 <INFO>    Script version: v1.4.0.3
      10:54:11.422 <INFO>       Skipping. v1.4.0.3 too old version.
      10:54:11.422 <INFO>    Script version: v1.4.1
      10:54:11.423 <INFO>       Skipping. v1.4.1 too old version.
      10:54:11.423 <INFO>    Script version: v1.4.2
      10:54:11.423 <INFO>       Skipping. v1.4.2 too old version.
      10:54:11.423 <INFO>    Script version: v2.0.0
      10:54:11.423 <INFO>       Skipping. v2.0.0 too old version.
      10:54:11.423 <INFO>    Script version: v2.0.0.1
      10:54:11.424 <INFO>       Skipping. v2.0.0.1 too old version.
      10:54:11.424 <INFO>    Script version: v2.0.0.2
      10:54:11.424 <INFO>       Skipping. v2.0.0.2 too old version.
      10:54:11.424 <INFO>    Script version: v2.0.0.4
      10:54:11.424 <INFO>       Skipping. v2.0.0.4 too old version.
      10:54:11.424 <INFO>    Script version: v2.0.1
      10:54:11.424 <INFO>       Skipping. v2.0.1 too old version.
      10:54:11.425 <INFO>    Script version: v2.0.2
      10:54:11.425 <INFO>       Skipping. v2.0.2 too old version.
      10:54:11.425 <INFO>    Script version: v2.0.2.1
      10:54:11.425 <INFO>       Skipping. v2.0.2.1 too old version.
      10:54:11.425 <INFO>    Script version: v2.0.2.2
      10:54:11.425 <INFO>       Skipping. v2.0.2.2 too old version.
      10:54:11.426 <INFO>    Script version: v2.2.0
      10:54:11.426 <INFO>       Skipping. v2.2.0 too old version.
      10:54:11.426 <INFO>    Script version: v2.2.0.3
      10:54:11.426 <INFO>       Skipping. v2.2.0.3 too old version.
      10:54:11.426 <INFO>    Script version: v2.2.0.5
      10:54:11.426 <INFO>       Skipping. v2.2.0.5 too old version.
      10:54:11.426 <INFO>    Script version: v2.2.1.1
      10:54:11.427 <INFO>       Skipping. v2.2.1.1 too old version.
      10:54:11.427 <INFO>    Script version: v2.2.1.2
      10:54:11.427 <INFO>       Skipping. v2.2.1.2 too old version.
      10:54:11.427 <INFO>    Script version: v2.2.2.0
      10:54:11.427 <INFO>       Skipping. v2.2.2.0 too old version.
      10:54:11.427 <INFO>    Script version: v3.0.0
      10:54:11.428 <INFO>       Running update script for v3.0.0...
      10:54:11.462 <INFO> Executing /opt/loxberry/sbin/loxberryupdate/update_v3.0.0.pl release=v3.0.0.5 logfilename=/opt/loxberry/log/system/loxberryupdate/20230427_105336_378_update.log cron= updatedir=/tmp/loxberryupdate/mschlenstedt-Loxberry-fb575c0
      <OK> Update script /opt/loxberry/sbin/loxberryupdate/update_v3.0.0.pl started.
      <INFO> Welcome 3.0 Branch :-) Increasing LoxBerry's Max_Version to 3.99.99.
      <INFO> Repairing apt sources...
      <OK> /system/apt/loxberry.list installed.
      <OK> /opt/loxberry/system/apt/loxberry.list owner changed to root.
      <WARNING> Upgrading system to latest Raspbian release ON NEXT REBOOT.
      <INFO> Disabling Apache2 Service for next reboot...
      <OK> Apache Service disabled successfully.
      <INFO> Disabling Unattended Upgrades Service for next reboot...
      <OK> Unattended Upgrades Service disabled successfully.
      <INFO> Disabling RPI Monitor Service for next reboot...
      <OK> RPI Monitor Service disabled successfully.
      <INFO> Backing up all Python Modules - Will be overwritten by f***cking broken Rasbian upgrade...
      <INFO> Saving list with installed pip2 packages...
      <INFO> Saving list with installed pip3 packages...
      <INFO> The next steps will prepare the Mosquitto MQTT server and MQTT Gateway.
      <OK> /system/sudoers/lbdefaults installed.
      <OK> /opt/loxberry/system/sudoers/lbdefaults owner changed to root.
      <OK> /system/daemons/system/50-mqttgateway installed.
      <OK> /opt/loxberry/system/daemons/system/50-mqttgateway owner changed to root.
      <OK> /system/daemons/system/51-mqttfinder installed.
      <OK> /opt/loxberry/system/daemons/system/51-mqttfinder owner changed to root.
      <INFO> Starting MQTT Gateway migration
      <INFO> Executing command '/opt/loxberry/sbin/loxberryupdate/mqtt_migration.pl logfilename=/opt/loxberry/log/system/loxberryupdate/20230427_105336_378_update.log'...
      <OK> Update script /opt/loxberry/sbin/loxberryupdate/mqtt_migration.pl started.
      <INFO> Executing command 'mkdir --parents /opt/loxberry/bin/mqtt/transform/custom'...
      <OK> Command executed successfully. - Exitcode 0
      <INFO> Executing command 'mkdir --parents /opt/loxberry/bin/mqtt/datastore'...
      <INFO> Executing command 'mkdir --parents /opt/loxberry/config/system/mosquitto'...
      <INFO> Executing command 'mkdir --parents /opt/loxberry/webfrontend/html/system/tools/mqtt'...
      <INFO> Installing new packages
      <INFO> No process is locking apt or dpkg. Fine.
      <INFO> Installing apt packages mosquitto-clients libhash-flatten-perl libfile-monitor-perl libfile-find-rule-perl libbsd-resource-perl libcgi-simple-perl...
      Reading package lists...
      Building dependency tree...
      Reading state information...
      The following NEW packages will be installed:
        libcgi-simple-perl
      0 upgraded, 1 newly installed, 5 reinstalled, 0 to remove and 296 not upgraded.
      Need to get 277 kB of archives.
      After this operation, 242 kB of additional disk space will be used.
      Get:1 http://mirror.de.leaseweb.net/raspbian/raspbian buster/main armhf libbsd-resource-perl armhf 1.2911-1+b2 [33.8 kB]
      Get:2 http://mirror.de.leaseweb.net/raspbian/raspbian buster/main armhf libcgi-simple-perl all 1.115-2 [101 kB]
      Get:3 http://mirror.de.leaseweb.net/raspbian/raspbian buster/main armhf libfile-find-rule-perl all 0.34-1 [30.6 kB]
      Get:4 http://mirror.de.leaseweb.net/raspbian/raspbian buster/main armhf libfile-monitor-perl all 1.00-1 [34.0 kB]
      Get:5 http://mirror.de.leaseweb.net/raspbian/raspbian buster/main armhf libhash-flatten-perl all 1.19-2 [10.7 kB]
      Get:6 http://mirror.de.leaseweb.net/raspbian/raspbian buster/main armhf mosquitto-clients armhf 1.5.7-1+deb10u1 [66.8 kB]
      Fetched 277 kB in 1s (250 kB/s)
      (Reading database ... (Reading database ... 5% (Reading database ... 10% (Reading database ... 15% (Reading database ... 20% (Reading database ... 25% (Reading database ... 30% (Reading database ... 35% (Reading database ... 40% (Reading database ... 45% (Reading database ... 50% (Reading database ... 55% (Reading database ... 60% (Reading database ... 65% (Reading database ... 70% (Reading database ... 75% (Reading database ... 80% (Reading database ... 85% (Reading database ... 90% (Reading database ... 95% (Reading database ... 100% (Reading database ... 88393 files and directories currently installed.)
      Preparing to unpack .../0-libbsd-resource-perl_1.2911-1+b2_armhf.deb ...
      Unpacking libbsd-resource-perl (1.2911-1+b2) over (1.2911-1+b2) ...
      Selecting previously unselected package libcgi-simple-perl.
      Preparing to unpack .../1-libcgi-simple-perl_1.115-2_all.deb ...
      Unpacking libcgi-simple-perl (1.115-2) ...
      Preparing to unpack .../2-libfile-find-rule-perl_0.34-1_all.deb ...
      Unpacking libfile-find-rule-perl (0.34-1) over (0.34-1) ...
      Preparing to unpack .../3-libfile-monitor-perl_1.00-1_all.deb ...
      Unpacking libfile-monitor-perl (1.00-1) over (1.00-1) ...
      Preparing to unpack .../4-libhash-flatten-perl_1.19-2_all.deb ...
      Unpacking libhash-flatten-perl (1.19-2) over (1.19-2) ...
      Preparing to unpack .../5-mosquitto-clients_1.5.7-1+deb10u1_armhf.deb ...
      Unpacking mosquitto-clients (1.5.7-1+deb10u1) over (1.5.7-1+deb10u1) ...
      Setting up libbsd-resource-perl (1.2911-1+b2) ...
      Setting up libhash-flatten-perl (1.19-2) ...
      Setting up mosquitto-clients (1.5.7-1+deb10u1) ...
      Setting up libfile-monitor-perl (1.00-1) ...
      Setting up libfile-find-rule-perl (0.34-1) ...
      Setting up libcgi-simple-perl (1.115-2) ...
      Processing triggers for man-db (2.8.5-2) ...
      <OK> Packages mosquitto-clients libhash-flatten-perl libfile-monitor-perl libfile-find-rule-perl libbsd-resource-perl libcgi-simple-perl successfully installed
      <INFO> Executing command 'APT_LISTCHANGES_FRONTEND=none DEBIAN_FRONTEND=noninteractive apt-get --no-install-recommends -y --allow-unauthenticated --fix-broken --reinstall --allow-downgrades --allow-remove-essential --allow-change-held-packages -o Dpkg::Options::='--force-confask,confnew,confmiss' install mosquitto'...
      0 upgraded, 0 newly installed, 1 reinstalled, 0 to remove and 296 not upgraded.
      Need to get 143 kB of archives.
      After this operation, 0 B of additional disk space will be used.
      Get:1 http://mirror.de.leaseweb.net/raspbian/raspbian buster/main armhf mosquitto armhf 1.5.7-1+deb10u1 [143 kB]
      Fetched 143 kB in 0s (439 kB/s)
      (Reading database ... (Reading database ... 5% (Reading database ... 10% (Reading database ... 15% (Reading database ... 20% (Reading database ... 25% (Reading database ... 30% (Reading database ... 35% (Reading database ... 40% (Reading database ... 45% (Reading database ... 50% (Reading database ... 55% (Reading database ... 60% (Reading database ... 65% (Reading database ... 70% (Reading database ... 75% (Reading database ... 80% (Reading database ... 85% (Reading database ... 90% (Reading database ... 95% (Reading database ... 100% (Reading database ... 88406 files and directories currently installed.)
      Preparing to unpack .../mosquitto_1.5.7-1+deb10u1_armhf.deb ...
      Unpacking mosquitto (1.5.7-1+deb10u1) over (1.5.7-1+deb10u1) ...
      Setting up mosquitto (1.5.7-1+deb10u1) ...
      Processing triggers for systemd (241-7~deb10u4+rpi1) ...
      <INFO> Stopping MQTT Gateway plugin
      <INFO> Executing command 'pkill mqttgateway.pl'...
      <INFO> Creating configuration backup of MQTT Gateway plugin
      <INFO> Executing command 'mkdir --parents /opt/backup.mqttgateway'...
      <INFO> Executing command 'cp /opt/loxberry/config/plugins/mqttgateway/* /opt/backup.mqttgateway/'...
      <OK> Starting migration of MQTT Gateway plugin settings to general.json and mqttgateway.json
      <INFO> Executing command 'cp -f /opt/loxberry/config/plugins/mqttgateway/mqtt.json /opt/loxberry/config/system/mqttgateway.json'...
      <INFO> Open and lock general.json
      <INFO> Open and lock new mqttgateway.json
      <INFO> Open plugin cred.json
      <INFO> Migrating data to general.json
      <INFO> Removing migrated data from old config
      <INFO> Moving Mosquitto plugin configuration to /opt/loxberry/config/system/mosquitto...
      <INFO> Executing command 'cp -f /opt/loxberry/config/plugins/mqttgateway/mosquitto.conf /opt/loxberry/config/system/mosquitto/mosq_mqttgateway.conf'...
      <INFO> Executing command 'cp -f /opt/loxberry/config/plugins/mqttgateway/mosq_passwd /etc/mosquitto/conf.d/'...
      <INFO> Recreating Mosquitto configuration symlink...
      <INFO> Executing command 'unlink /etc/mosquitto/conf.d/mqttgateway.conf'...
      <INFO> Executing command 'ln -f -s /opt/loxberry/config/system/mosquitto/mosq_mqttgateway.conf /etc/mosquitto/conf.d/mosq_mqttgateway.conf'...
      <INFO> Migrating MQTT Gateway user transformers
      <INFO> Executing command 'cp -f -R /opt/loxberry/data/plugins/mqttgateway/transform/custom/* /opt/loxberry/bin/mqtt/transform/custom'...
      <INFO> Executing command 'cp -f -R /opt/loxberry/data/plugins/mqttgateway/transform/datastore/* /opt/loxberry/bin/mqtt/datastore/'...
      <ERROR> ERROR executing command - Exitcode 1
      <OK> Your own MQTT Transformers are now located in /opt/loxberry/bin/mqtt/transform/custom/
      <INFO> Executing command 'rm -R -f /opt/loxberry/bin/plugins/mqttgateway'...
      <INFO> Executing command 'rm -R -f /opt/loxberry/config/plugins/mqttgateway'...
      <INFO> Executing command 'rm -R -f /opt/loxberry/data/plugins/mqttgateway'...
      <INFO> Executing command 'rm -R -f /opt/loxberry/log/plugins/mqttgateway'...
      <INFO> Executing command 'rm -R -f /opt/loxberry/templates/plugins/mqttgateway'...
      <INFO> Executing command 'rm -R -f /opt/loxberry/webfrontend/html/plugins/mqttgateway'...
      <INFO> Executing command 'rm -R -f /opt/loxberry/webfrontend/htmlauth/plugins/mqttgateway'...
      <OK> Removing MQTT Gateway Plugin from Plugindatabase
      <INFO> Executing command 'mkdir --parents /opt/loxberry/webfrontend/html/plugins/mqttgateway'...
      <INFO> Executing command 'ln -f -s /opt/loxberry/webfrontend/html/system/tools/mqtt/receive.php /opt/loxberry/webfrontend/html/plugins/mqttgateway/receive.php'...
      <INFO> Executing command 'ln -f -s /opt/loxberry/webfrontend/html/system/tools/mqtt/receive_pub.php /opt/loxberry/webfrontend/html/plugins/mqttgateway/receive_pub.php'...
      <INFO> Executing command 'mkdir --parents /opt/loxberry/webfrontend/htmlauth/plugins/mqttgateway'...
      <INFO> Executing command 'ln -f -s /opt/loxberry/webfrontend/htmlauth/system/tools/mqtt.php /opt/loxberry/webfrontend/htmlauth/plugins/mqttgateway/mqtt.php'...
      <INFO> Executing command '/opt/loxberry/sbin/mqtt-handler.pl action=updateconfig'...
      <INFO> Executing command 'chown -R loxberry:loxberry /opt/loxberry/bin/mqtt'...
      <INFO> Executing command 'chown -R loxberry:loxberry /opt/loxberry/config/system/mosquitto'...
      <INFO> Executing command 'chown -R loxberry:loxberry /opt/loxberry/config/system/mqttgateway.json'...
      <INFO> Executing command 'chown -R loxberry:loxberry /opt/backup.mqttgateway'...
      <INFO> Executing command 'chown -R loxberry:loxberry /opt/loxberry/webfrontend/htmlauth/plugins/mqttgateway'...
      <INFO> Executing command 'chown -R loxberry:loxberry /opt/loxberry/webfrontend/html/plugins/mqttgateway'...
      <INFO> Executing command 'chown -R loxberry:loxberry /opt/loxberry/config/system/general.json'...
      <INFO> Executing command 'chown -R loxberry:loxberry /opt/loxberry/webfrontend/html/system/tools/mqtt'...
      <INFO> Executing command 'chown -R loxberry:loxberry /opt/loxberry/webfrontend/htmlauth/system/tools'...
      <INFO> Upgrading usb-mount
      <INFO> Add missing Environments in Apache Config
      <INFO> Update service files
      <OK> /system/systemd/createtmpfs.service installed.
      <OK> /opt/loxberry/system/systemd/createtmpfs.service owner changed to root.
      <OK> /system/systemd/loxberry.service installed.
      <OK> /opt/loxberry/system/systemd/loxberry.service owner changed to root.
      <OK> /system/systemd/ssdpd.service installed.
      <OK> /opt/loxberry/system/systemd/ssdpd.service owner changed to root.
      <OK> /system/systemd/usb-mount@.service installed.
      <OK> /opt/loxberry/system/systemd/usb-mount@.service owner changed to root.
      <INFO> Update mosquitto service...
      <OK> /system/systemd/mosquitto.service installed.
      <OK> /opt/loxberry/system/systemd/mosquitto.service owner changed to root.
      <INFO> Disable gzipping of Logs...
      <INFO> Installing new 03-loxberryupdate file...
      <OK> /system/daemons/system/03-loxberryupdate installed.
      <OK> /opt/loxberry/system/daemons/system/03-loxberryupdate owner changed to root.
      <INFO> Installing Shell-In-A-Box...
      <INFO> Installing apt packages shellinabox...
        shellinabox
      0 upgraded, 1 newly installed, 0 to remove and 296 not upgraded.
      Need to get 115 kB of archives.
      After this operation, 496 kB of additional disk space will be used.
      Get:1 http://mirror.de.leaseweb.net/raspbian/raspbian buster/main armhf shellinabox armhf 2.21 [115 kB]
      Fetched 115 kB in 0s (313 kB/s)
      Selecting previously unselected package shellinabox.
      Preparing to unpack .../shellinabox_2.21_armhf.deb ...
      Unpacking shellinabox (2.21) ...
      Setting up shellinabox (2.21) ...
      <OK> Packages shellinabox successfully installed
      <OK> /system/daemons/system/06-shellinabox installed.
      <OK> /opt/loxberry/system/daemons/system/06-shellinabox owner changed to root.
      <OK> /system/apache2/conf-available/shellinabox.conf installed.
      <OK> /opt/loxberry/system/apache2/conf-available/shellinabox.conf owner changed to root.
      <INFO> Executing command 'a2enmod proxy proxy_http'...
      Enabling module proxy.
      Considering dependency proxy for proxy_http:
      Module proxy already enabled
      Enabling module proxy_http.
      To activate the new configuration, you need to run:
        systemctl restart apache2
      <INFO> Executing command 'a2enconf shellinabox'...
      Enabling conf shellinabox.
        systemctl reload apache2
      <INFO> Adding user loxberry to group i2c...
      <INFO> Executing command 'usermod -a -G i2c loxberry'...
      <INFO> Installing new SSL / HTTPS Option for Apache2 Webserver.
      <INFO> Installing apt packages dnsutils...
      The following additional packages will be installed:
        bind9-host libbind9-161 libdns1104 libirs161 libisc1100 libisccc161
        libisccfg163 liblwres161
      Suggested packages:
        rblcheck
        dnsutils libirs161
      The following packages will be upgraded:
        bind9-host libbind9-161 libdns1104 libisc1100 libisccc161 libisccfg163
        liblwres161
      7 upgraded, 2 newly installed, 0 to remove and 289 not upgraded.
      Need to get 3350 kB of archives.
      After this operation, 945 kB of additional disk space will be used.
      Get:1 http://mirror.de.leaseweb.net/raspbian/raspbian buster/main armhf bind9-host armhf 1:9.11.5.P4+dfsg-5.1+deb10u8 [269 kB]
      Get:2 http://mirror.de.leaseweb.net/raspbian/raspbian buster/main armhf libbind9-161 armhf 1:9.11.5.P4+dfsg-5.1+deb10u8 [244 kB]
      Get:3 http://mirror.de.leaseweb.net/raspbian/raspbian buster/main armhf libisccfg163 armhf 1:9.11.5.P4+dfsg-5.1+deb10u8 [259 kB]
      Get:4 http://mirror.de.leaseweb.net/raspbian/raspbian buster/main armhf libisccc161 armhf 1:9.11.5.P4+dfsg-5.1+deb10u8 [234 kB]
      Get:5 http://mirror.de.leaseweb.net/raspbian/raspbian buster/main armhf libdns1104 armhf 1:9.11.5.P4+dfsg-5.1+deb10u8 [1077 kB]
      Get:6 http://mirror.de.leaseweb.net/raspbian/raspbian buster/main armhf libisc1100 armhf 1:9.11.5.P4+dfsg-5.1+deb10u8 [423 kB]
      Get:7 http://mirror.de.leaseweb.net/raspbian/raspbian buster/main armhf liblwres161 armhf 1:9.11.5.P4+dfsg-5.1+deb10u8 [247 kB]
      Get:8 http://mirror.de.leaseweb.net/raspbian/raspbian buster/main armhf libirs161 armhf 1:9.11.5.P4+dfsg-5.1+deb10u8 [236 kB]
      Get:9 http://mirror.de.leaseweb.net/raspbian/raspbian buster/main armhf dnsutils armhf 1:9.11.5.P4+dfsg-5.1+deb10u8 [361 kB]
      Fetched 3350 kB in 2s (2020 kB/s)
      (Reading database ... (Reading database ... 5% (Reading database ... 10% (Reading database ... 15% (Reading database ... 20% (Reading database ... 25% (Reading database ... 30% (Reading database ... 35% (Reading database ... 40% (Reading database ... 45% (Reading database ... 50% (Reading database ... 55% (Reading database ... 60% (Reading database ... 65% (Reading database ... 70% (Reading database ... 75% (Reading database ... 80% (Reading database ... 85% (Reading database ... 90% (Reading database ... 95% (Reading database ... 100% (Reading database ... 88429 files and directories currently installed.)
      Preparing to unpack .../0-bind9-host_1%3a9.11.5.P4+dfsg-5.1+deb10u8_armhf.deb ...
      Unpacking bind9-host (1:9.11.5.P4+dfsg-5.1+deb10u8) over (1:9.11.5.P4+dfsg-5.1+deb10u2) ...
      Preparing to unpack .../1-libbind9-161_1%3a9.11.5.P4+dfsg-5.1+deb10u8_armhf.deb ...
      Unpacking libbind9-161:armhf (1:9.11.5.P4+dfsg-5.1+deb10u8) over (1:9.11.5.P4+dfsg-5.1+deb10u2) ...
      Preparing to unpack .../2-libisccfg163_1%3a9.11.5.P4+dfsg-5.1+deb10u8_armhf.deb ...
      Unpacking libisccfg163:armhf (1:9.11.5.P4+dfsg-5.1+deb10u8) over (1:9.11.5.P4+dfsg-5.1+deb10u2) ...
      Preparing to unpack .../3-libisccc161_1%3a9.11.5.P4+dfsg-5.1+deb10u8_armhf.deb ...
      Unpacking libisccc161:armhf (1:9.11.5.P4+dfsg-5.1+deb10u8) over (1:9.11.5.P4+dfsg-5.1+deb10u2) ...
      Preparing to unpack .../4-libdns1104_1%3a9.11.5.P4+dfsg-5.1+deb10u8_armhf.deb ...
      Unpacking libdns1104:armhf (1:9.11.5.P4+dfsg-5.1+deb10u8) over (1:9.11.5.P4+dfsg-5.1+deb10u2) ...
      Preparing to unpack .../5-libisc1100_1%3a9.11.5.P4+dfsg-5.1+deb10u8_armhf.deb ...
      Unpacking libisc1100:armhf (1:9.11.5.P4+dfsg-5.1+deb10u8) over (1:9.11.5.P4+dfsg-5.1+deb10u2) ...
      Preparing to unpack .../6-liblwres161_1%3a9.11.5.P4+dfsg-5.1+deb10u8_armhf.deb ...
      Unpacking liblwres161:armhf (1:9.11.5.P4+dfsg-5.1+deb10u8) over (1:9.11.5.P4+dfsg-5.1+deb10u2) ...
      Selecting previously unselected package libirs161:armhf.
      Preparing to unpack .../7-libirs161_1%3a9.11.5.P4+dfsg-5.1+deb10u8_armhf.deb ...
      Unpacking libirs161:armhf (1:9.11.5.P4+dfsg-5.1+deb10u8) ...
      Selecting previously unselected package dnsutils.
      Preparing to unpack .../8-dnsutils_1%3a9.11.5.P4+dfsg-5.1+deb10u8_armhf.deb ...
      Unpacking dnsutils (1:9.11.5.P4+dfsg-5.1+deb10u8) ...
      Setting up libisc1100:armhf (1:9.11.5.P4+dfsg-5.1+deb10u8) ...
      Setting up liblwres161:armhf (1:9.11.5.P4+dfsg-5.1+deb10u8) ...
      Setting up libisccc161:armhf (1:9.11.5.P4+dfsg-5.1+deb10u8) ...
      Setting up libdns1104:armhf (1:9.11.5.P4+dfsg-5.1+deb10u8) ...
      Setting up libisccfg163:armhf (1:9.11.5.P4+dfsg-5.1+deb10u8) ...
      Setting up libbind9-161:armhf (1:9.11.5.P4+dfsg-5.1+deb10u8) ...
      Setting up libirs161:armhf (1:9.11.5.P4+dfsg-5.1+deb10u8) ...
      Setting up bind9-host (1:9.11.5.P4+dfsg-5.1+deb10u8) ...
      Setting up dnsutils (1:9.11.5.P4+dfsg-5.1+deb10u8) ...
      Processing triggers for libc-bin (2.28-10+rpi1) ...
      <OK> Packages dnsutils successfully installed
      <OK> /system/apache2/sites-available/001-default-ssl.conf installed.
      <OK> /opt/loxberry/system/apache2/sites-available/001-default-ssl.conf owner changed to root.
      <OK> /system/cron/cron.daily/04-checkcerts installed.
      <OK> /opt/loxberry/system/cron/cron.daily/04-checkcerts owner changed to root.
      <INFO> Executing command 'a2enmod ssl'...
      Considering dependency setenvif for ssl:
      Module setenvif already enabled
      Considering dependency mime for ssl:
      Module mime already enabled
      Considering dependency socache_shmcb for ssl:
      Enabling module socache_shmcb.
      Enabling module ssl.
      See /usr/share/doc/apache2/README.Debian.gz on how to configure SSL and create self-signed certificates.
      <WARNING> Update file /opt/loxberry/sbin/loxberryupdate/update_v3.0.0.pl requests a reboot of LoxBerry. Please reboot your LoxBerry after the installation has finished.
      <OK> Update script /opt/loxberry/sbin/loxberryupdate/update_v3.0.0.pl finished.
      10:56:06.454 <INFO> exec_perl_script /opt/loxberry/sbin/loxberryupdate/update_v3.0.0.pl release=v3.0.0.5 logfilename=/opt/loxberry/log/system/loxberryupdate/20230427_105336_378_update.log cron= updatedir=/tmp/loxberryupdate/mschlenstedt-Loxberry-fb575c0 with user  - errcode 250
      10:56:06.454 <WARNING> Updatescript update_v3.0.0 requests a reboot before LoxBerry can continue the update. Please reboot your LoxBerry, and check for updates again.
      10:56:06.460 <OK> Update scripts executed successful.
      10:56:06.460 <INFO> Migrating configuration settings from default config...
      10:56:06.983 <OK> LoxBerry config settings updated successfully.
      10:56:06.984 <INFO> Updating LoxBerry legacy templates...
      10:56:08.370 <OK> LoxBerry legacy template successfully updated.
      10:56:08.370 <INFO> Updating Skels for Logfolders...
      10:56:08.723 <OK> Skels for Logfolders successfully updated.
      10:56:08.724 <INFO> LoxBerry's config version is updated from v2.2.2.2 to v3.0.0
      10:56:08.734 <INFO> Cleaning up temporary download folder
      10:56:09.018 <INFO> All procedures finished.
      10:56:15.681 <OK> Loxberry Update WAS SUCCESSFUL!
      <LOGEND> LoxBerry Update processing finished.
      <LOGEND> 27.04.2023 10:56:15 TASK FINISHED
      danach kommt ja das Update auf bullseye - da habe ich öffters mal solche Meldungen:
      The following signatures were invalid: EXPKEYSIG 23E7166788B63E1E Yarn Packaging <yarn@dan.cx>
      Get:7 http://raspbian.raspberrypi.org/raspbian bullseye/contrib armhf Packages [60.2 kB]
      Get:8 http://raspbian.raspberrypi.org/raspbian bullseye/non-free armhf Packages [106 kB]
      Get:9 https://deb.nodesource.com/node_12.x bullseye/main armhf Packages [781 B]
      Get:10 http://raspbian.raspberrypi.org/raspbian bullseye/rpi armhf Packages [1,360 B]
      Get:11 http://debian.fhem.de/nightly InRelease [1,912 B]
      Err:11 http://debian.fhem.de/nightly InRelease
      The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 95D737016F529CF1
      Update rpimonitor Packages Status
      Update rpimonitor Packages Status​
      wie gesagt - nun läuft wieder das js Update - mal sehen ob es nun weiter geht ?!
      [edit]
      sieht so aus als wenn ich nun in einer Endlosschleife hänge
      Fetched 19.0 kB in 3s (6,381 B/s)
      W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: http://debian.fhem.de/nightly InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 95D737016F529CF1
      W: Failed to fetch http://debian.fhem.de/nightly/InRelease The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 95D737016F529CF1
      W: Some index files failed to download. They have been ignored, or old ones used instead.
      <OK> Apt database updated successfully.
      Preparing to unpack .../nodejs_18.16.0-deb-1nodesource1_armhf.deb ...
      Unpacking nodejs (18.16.0-deb-1nodesource1) over (18.16.0-deb-1nodesource1) ...
      Get:319 http://mirror.de.leaseweb.net/raspbian/raspbian bullseye/main armhf gcc armhf 4:10.2.1-1+rpi1 [5,196 B]
      Get:320 http://mirror.de.leaseweb.net/raspbian/raspbian bullseye/main armhf cpp armhf 4:10.2.1-1+rpi1 [19.9 kB]
      Get:321 http://mirror.de.leaseweb.net/raspbian/raspbian bullseye/main armhf libfdt1 armhf 1.6.0-1 [17.9 kB]
      Get:322 http://mirror.de.leaseweb.net/raspbian/raspbian bullseye/main armhf libyaml-0-2 armhf 0.2.2-1 [40.0 kB]
      Get:323 http://mirror.de.leaseweb.net/raspbian/raspbian bullseye/main armhf device-tree-compiler armhf 1.6.0-1 [216 kB]
      Get:324 http://mirror.de.leaseweb.net/raspbian/raspbian bullseye/main armhf fonts-urw-base35 all 20200910-1 [6,367 kB]
      E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
      <CRITICAL> Error dist-upgrading - Error 100
      <INFO> Cleaning up and updating apt databases...
      <INFO> Starting dpkg --configure...
      <OK> Configuring dpkg successfully.
      <INFO> Clean up apt-databases and update
      <OK> Apt packages autoremoved successfully.
      Get:1 http://debian.fhem.de/nightly InRelease [1,912 B]
      Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
      Get:3 https://dl.yarnpkg.com/debian stable InRelease [17.1 kB]
      Hit:4 https://deb.nodesource.com/node_18.x buster InRelease
      Hit:5 https://download.docker.com/linux/raspbian bullseye InRelease
      Err:1 http://debian.fhem.de/nightly InRelease
      Get:560 http://mirror.de.leaseweb.net/raspbian/raspbian bullseye/main armhf gcc armhf 4:10.2.1-1+rpi1 [5,196 B]
      Get:561 http://mirror.de.leaseweb.net/raspbian/raspbian bullseye/main armhf cpp armhf 4:10.2.1-1+rpi1 [19.9 kB]
      Get:562 http://mirror.de.leaseweb.net/raspbian/raspbian bullseye/main armhf wireless-regdb all 2022.04.08-2~deb11u1 [15.1 kB]
      Get:563 http://mirror.de.leaseweb.net/raspbian/raspbian bullseye/main armhf iw armhf 5.9-3 [82.3 kB]
      Get:564 http://mirror.de.leaseweb.net/raspbian/raspbian bullseye/main armhf crda armhf 4.14+git20191112.9856751-1 [63.1 kB]
      Get:565 http://mirror.de.leaseweb.net/raspbian/raspbian bullseye/main armhf debian-keyring all 2021.07.26 [31.1 MB]
      <CRITICAL> Error full-upgrading - Error 100
      Reading state information...​
      ich habe immer mal wieder von dem durchlaufenden logfile Stücke raus kopiert und speziell auf denn gcc geachtet... und siehe da der ist zweimal in der gleichen Version aufgetaucht ... was mache ich nun? Ich denke ich kann an der Stelle nun erstmal abbrechen oder?
      Vielen Dank & viele Grüße
      • badmage
        • 22.01.2019
        • 22
        #93
        man kann es eigentlich nicht glauben - aber er hat es dann doch irgendwann auf die aktuellste Version geschafft - aber es gibt viele "rote" Meldungen
        kann ich dagegen nun noch was machen - oder welche Aktionen sind in dem Fall erforderlich?
        irgendwie scheint der key abgelaufen zu sein?
        root@loxberry:~# apt-get update --fix-missing
        Get:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease [15.0 kB]
        Get:2 http://debian.fhem.de/nightly  InRelease [1,912 B]
        Hit:3 https://deb.nodesource.com/node_18.x buster InRelease
        Hit:4 https://download.docker.com/linux/raspbian bullseye InRelease
        Get:5 https://dl.yarnpkg.com/debian stable InRelease [17.1 kB]
        Err:2 http://debian.fhem.de/nightly  InRelease
        Fetched 34.0 kB in 2s (15.8 kB/s)
        Reading package lists... Done
        root@loxberry:~#
Ansichten: 706
Größe: 311,1 KB
          Das Problem mit FHEM steht hier schon gefühlte 100x. Suche benutzen.
      • badmage
        • 22.01.2019
        • 22
        #94
        habt ihr auch soo viele kept back packages?
        root@loxberry:~# apt-get upgrade
        Building dependency tree... Done
        Reading state information... Done
        Calculating upgrade... Done
        The following packages have been kept back:
          alsa-utils aptitude aptitude-common bind9-host bsdmainutils bsdutils default-mysql-client device-tree-compiler dnsutils docker-ce-cli e2fsprogs e2fsprogs-l10n ghostscript gtk-update-icon-cache iproute2 iptables isc-dhcp-client
          libalgorithm-diff-xs-perl libasound2 libasound2-data libauthen-pam-perl libb-hooks-op-check-perl libbind9-161 libbluray2 libbsd-resource-perl libbsd0 libclass-c3-xs-perl libclass-xsaccessor-perl libcommon-sense-perl libcryptsetup12
          libdata-uuid-perl libdatetime-perl libdbd-mysql-perl libdbd-pg-perl libdbd-sqlite3-perl libdbi-perl libdevel-callchecker-perl libdevel-caller-perl libdevel-lexalias-perl libdevice-serialport-perl libdvdnav4 libemail-address-xs-perl
          libemail-mime-contenttype-perl libemail-mime-perl libext2fs2 libfcgi-perl libfile-fcntllock-perl libgail-common libgail18 libgd-perl libgdk-pixbuf2.0-0 libgdk-pixbuf2.0-bin libgdk-pixbuf2.0-common libgl1-mesa-dri libgs9 libgs9-common
          libgsasl7 libgtk-3-0 libgtk-3-bin libgtk2.0-0 libgtk2.0-bin libhtml-parser-perl libhttp-message-perl libimage-librsvg-perl libio-interface-perl libio-socket-multicast-perl libipc-sharelite-perl libiptc0 libirs161 libisccc161
          libisccfg163 libjson-xs-perl liblist-moreutils-perl liblist-someutils-perl liblocale-gettext-perl liblwres161 libmagickcore-6.q16-6 libmagickcore-6.q16-6-extra libmagickwand-6.q16-6 libmm-glib0 libnet-dbus-perl libnet-libidn-perl
          libnet-ssleay-perl libnetaddr-ip-perl libnotify4 libnss-systemd libpackage-stash-xs-perl libpadwalker-perl libpam-systemd libparams-classify-perl libparams-util-perl libparams-validate-perl libpci3 libpod-markdown-perl libqt5core5a
          libqt5dbus5 libqt5gui5 libqt5network5 libqt5positioning5 libqt5printsupport5 libqt5qml5 libqt5quick5 libqt5sensors5 libqt5svg5 libqt5webchannel5 libqt5webkit5 libqt5widgets5 libref-util-xs-perl librrds-perl librsvg2-2 librsvg2-common
          libscalar-list-utils-perl libsocket6-perl libspecio-perl libsub-identify-perl libsub-name-perl libsystemd0 libterm-readkey-perl libtext-charwidth-perl libtext-csv-xs-perl libtext-iconv-perl libtext-soundex-perl libtiff5
          libtype-tiny-perl libtype-tiny-xs-perl libunicode-utf8-perl libvariable-magic-perl libxcb-image0 libxml-libxml-perl libxml-parser-perl libxtables12 libzmq5 lshw mesa-va-drivers mesa-vdpau-drivers mime-support modemmanager mpg123
          msmtp msmtp-mta nfs-common nftables pciutils perl perl-base php-tcpdf plymouth procps python-pip-whl python3-pip qt5-gtk-platformtheme rsyslog systemd usb-modeswitch x11-utils
        0 upgraded, 0 newly installed, 0 to remove and 155 not upgraded.
        root@loxberry:~#
        • germany1989
          • 13.08.2019
          • 1
          #95
          Guten Morgen zusammen,
          ich versuche gerade ein neus Loxberry (3.0.0.6) aufzusetzen analog der Anleitung im Wiki. Die Installation von LoxBerry [LoxBerry Wiki - BEYOND THE LIMITS]
          Installation des DietPi funktioniert problemlos - Ausführen des folgenden Befehls via Putty startet die Installation des Loxberrys.
          wget https://raw.githubusercontent.com/ms...ain/install.sh && bash install.sh | tee /boot/loxberry_install.log
          Nach einiger Laufzeit bekomme ich aber die folgende Fehlermeldung:
          Settings up systemwide environments...
          awk: cmd. line:1: (FILENAME=/etc/environment FNR=5) fatal: cannot redirect to `/etc/environment': Read-only file system
          sed: can't read /opt/loxberry/system/apache2/envvars: Input/output error
          [FAILED ] .... Could not set systemwide environments.
          Hat jemand eine idee woran das liegen könnte?
          Danke schon einmal im Voraus.
            • 4742
            #96
            SDKarte kaputt. Oder das Filesystem wenn es eine VM ist.
            • germany1989
              germany1989 kommentierte
              Vielen Dank! - daran lags tatsächlich.
              Zuletzt geändert von germany1989; 04.05.2023, 12:20.
          • criccric
            • 22.01.2017
            • 9
            #97
            Hi.
            Leider versuche ich den ganzen Abend erfolglos ein Update auf die v3. Musste erst mit Backup und Restore auf eine neue SD Karte die Boot Partition auf 256MB bringen, daher habe ich mich erst heute an das Update gesetzt.
            Bekomme lauter APT Fehler, die am Ende in diesen Fehler münden: (meine Internet Verbindung funktioniert 1A)
            <ERROR> Error updating apt database. All servers give an error. Internet connection available? Giving up.
            Habe mal das Log angehangen. Bei FHEM kommt "File has unexpected size" und für Grafana und Influx kommen auch lauter APT Fehler.
            Folgendes bringt mich leider auch nicht weiter:
            loxberry@loxberry:~ $ [B]sudo apt-get update --allow-releaseinfo-change[/B]
            Get:1 https://repos.influxdata.com/debian bullseye InRelease [7,031 B]
            Get:2 https://packages.grafana.com/oss/deb stable InRelease [5,984 B]
            Err:1 https://repos.influxdata.com/debian bullseye InRelease
              The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
            Err:2 https://packages.grafana.com/oss/deb stable InRelease
              The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 9E439B102CF3C0C6
            Get:4 http://debian.fhem.de/nightly  InRelease [1,912 B]
            Hit:5 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian bullseye InRelease
            Err:4 http://debian.fhem.de/nightly  InRelease
            W: GPG error: https://repos.influxdata.com/debian bullseye InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
            E: The repository 'https://repos.influxdata.com/debian bullseye InRelease' is not signed.
            N: Updating from such a repository can't be done securely, and is therefore disabled by default.
            N: See apt-secure(8) manpage for repository creation and user configuration details.
            W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://packages.grafana.com/oss/deb stable InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 9E439B102CF3C0C6
            W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: http://debian.fhem.de/nightly  InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 95D737016F529CF1​
            Soll ich die problematischen Mirrors deaktivieren? Was passiert dann aber mit dem Update - wird es inkonsistent?
            Da ich einiges über MQTT laufen habe, werde ich nun wohl oder übel die alte Karte mit 2.2.2.2 wieder booten.
            Gruß, Christian
            MSv2, MSv1, 4 Relay, 3 Extension, DimmV2, Tree, Air, 1Wire, viele 24V Dimm + Tree Geräte & ein LoxBerry
            Im wesentlichen dank Loxberry, -wiki, & -forum erfolgreich eingebunden: Helios KWL, Hörmann Torantrieb, NUKI Schloss/Bridge, Netatmo Weather, Roborock, 2x KEBA Wallbox mit Lastmgt., PV: Fronius WR + Smartmeter, paar Shelly Geräte, HomeConnect, DoorBird, Pooldigital Procon.IP Poolsteuerung
            In Planung: BSB-LAN für Gastherme (LMS15 Steuerung)
            Bisher leider erfolglos: Judo i-soft safe, Stihl iMOW
              Stats4Lox updaten, das aktualisiert die kaputten Mirrors von Influx und Grafana. Oder entfernen geht auch. FHEM Mirror entfernen.
          • Gerrit
            • 940
            #98
            Ich hatte auch kleinere Problem beim Update. Einige Debian Pakete konnten nicht konfiguriert werden (systemd war das Ursprungsproblem) und dadurch funktionierte auch u.a. die SMB NetShare Connection nicht richtig
            Folgender Thread gab die Lösung:
            Das Root Verzeichnis gehörte dem User "loxberry", aber es muss wohl zwingend root sein: su root -> chown root /
            Danach dann dpkg --reconfigure -a bzw. eventuell noch Nachinstallation fehlender Pakete
            Zuletzt geändert von Gerrit; 15.05.2023, 19:10.
            • woawoa17
              • 23.02.2020
              • 5
              #99
              Hallo zusammen
              Ich habe einen Raspberry Pi 4 4GB mit Loxberry 2.2.2.2 laufen.
              Als Speicher verwende ich keine SD Karte sondern habe eine externe SSD an den USB-Port angeschlossen.
              Nun möchte ich auf die neue Loxberry Version v3 updaten.
              Wie muss ich vorgehen, damit es mit der externen SSD funktioniert?
              Habe das Update schon vor ca. 2 Wochen versucht, aber es hat nicht funktioniert.
              Konnte dann mit dem vorher erstellten Backup ohne Probleme auf die alte Version zurückkehren.
              Jetzt möchte ich einfach alles im Voraus klären und euch um Hilfe bitten.​
                Bei einem Raspi und laufender Installation sollte das kein Problem sein. Meist liegt es an anderen installierten Dingen.
                Hier jetzt einfach nur zu sagen es hat nicht funktioniert ist lesen aus dem Kaffeesatz. So kann Dir niemand helfen.
            • FRECH
              • 07.08.2017
              • 263
              #100
              Ich wollte jetzt auch auf von 2.2.2.2 auf 3.x umsteigen...
              Aso: https://wiki.loxberry.de/haufig_gest...tion_too_small
              USB Stick (8GB) reingesteckt (4.3 GB werden benötigt und start...dann kam das:
Ansichten: 517
Größe: 261,1 KB
              Bin ein wenig ratlos was ich jetzt probieren soll...
              Hatte schon jemand das Problem? (in der Suche fand ich nichts)
              • FRECH
                FRECH kommentierte
                USB Stick war FAT....jetzt glaub ich geht es
            • Jans89
              • 14.05.2020
              • 41
              #101
              mein Update eines älteren Loxberrys mit der Version 2.2.2.2 ist wie bei anderen auch nach einer langen Endlosschleife irgendwann durchgelaufen, aber fehlerhaft.
              Es scheint auch das Problem mit dem FHEM APT Server zu sein.
              Als Lösung wird von euch geschrieben, man müsse den FHEM APT Server aus /etc/apt/ als Quelle entfernen.
              Sorry, da stehe ich ein bisschen auf dem Schlauch. Wie bekomme ich das hin?
              Jans
                Backup zurückspielen. Dann als Root auf der Konsole folgende Befehle ausführen -> https://wiki.loxberry.de/haufig_gest..._shellzugriff:
                rm /etc/apt/sources.list.d/fhem*
                apt-get update
                Dann das LoxBerry Update starten.
              • Jans89
                Jans89 kommentierte
                Danke! Da wäre ich alleine nicht drauf gekommen
                Werde ich ausprobieren!
            • Jans89
              • 14.05.2020
              • 41
              #102
              Das Update scheint jetzt funktioniert zu haben. Wenn ich auf die Startseite des Loxberry gehe, erscheint jedoch immer dieses Fenster:
              ​​​ Klicke auf die Grafik für eine vergrößerte Ansicht
Ansichten: 509
Größe: 201,1 KB
              Danach springt er sofort rüber zum "Loxberry Update Verlauf".
              Aus den Meldungen des Loxberrys bekomme ich keine Hinweise, dass beim Update etwas Größeres schief gegangen ist.
Ansichten: 448
Größe: 299,9 KB
Ansichten: 457
Größe: 123,6 KB
              Hat jemand eine Idee?
                • 11237
                #103
                Shift-Aktualisieren zum Refreshen des Browser-Caches.
                • Jans89
                  Jans89 kommentierte
                  So einfach...
                  Danke!
              • meisterjäger
                • 15.06.2019
                • 73
                #104
                Hallo Freunde irgendwie wird mein NTFS formatierter USB Stick nicht gemountet. Unter USB Storage steht kein USB Datenträger gefunden. Unter formatieren taucht er aber auf. Und natürlich wird der Stick auch beim Backup nicht angezeigt als mögliche Option für den Speicherpfad. Hat jemand eine Idee? Loxberry Version 3.0.0.6. vielen Dank
                • JoeLox
                  • 10.08.2017
                  • 51
                  #105
                  Upgrade von 2.2.2.2 auf 3.0.0.6 gelungen und läuft. Keine Fehlermeldungen.
                  Auf diesem Loxberry war aber auch "nur" mqtt und der Squeezelite Player.
                  Nun wollte ich mich mal etwas im dietpi System umschauen.
                  root@kellerlox:~# dietpi-software
                  -bash: dietpi-software: command not found
                  ​Ist ein Upgrade kein echtes oder vollständiges Dietpi, sondern hat noch zu viele Wurzeln im alten System?
                  Oder sitzt das Problem vor dem Bildschirm?
                  Über einen kurzen Hinweis würde ich mich freuen.
                    Wer hat denn jemals gesagt, dass ein Raspbian nach einem Upgrade ein DietPi ist? Wie soll das wohl gehen?
