kann mir jemand kurz erklären wie ich Loxberry über den Virtual Machine Manager auf einer Synology NAS installieren kann?
Ich versuche das jetzt einige Zeit aber ich komme nicht wirklich weiter.
Vielen Dank!
================================================================================ <LOGSTART> 05.06.2023 22:12:36 TASK STARTED <LOGSTART> Update Reboot script /opt/loxberry/sbin/loxberryupdate/updatereboot_v3.0.0.pl started. <INFO> LoxBerry Version 3.0.0.6 ( is_arch_x86_64.cfg is_vmware.cfg is_x64.cfg ) <INFO> Loglevel: 7 <INFO> Message : Doing system upgrade (envoked from upgrade to V3.0.0) <INFO> This script already started 4 times. <INFO> Try to reach loxberry.de <OK> loxberry.de is reachable, so network seems to be up. <INFO> Stopping Apache2... <INFO> Stopping unattended-upgrades... <INFO> Stopping rpimonitor... <INFO> Starting simple update webserver... <OK> Started simple webserver successfully. <INFO> Change owner of /var/log to root:root... <INFO> Change permissions of /tmp to 1777... <INFO> (Re-)Set current date/time to make sure communication with apt-servers will be ok - seems to be a problem on VMs sometimes... <INFO> Checking Boot Partition... <INFO> Seems this is not a Raspberry - fine, everything should be fine. <INFO> Preparing Guru Meditation... <INFO> This will take some time now. We suggest getting a coffee or a beer. <INFO> We are now moving the Debian Distribution from Buster to Bullseye. <INFO> Cleaning up and updating apt databases... <INFO> No process is locking apt or dpkg. Fine. <INFO> Starting dpkg --configure... Setting up linux-image-5.10.0-23-amd64 (5.10.179-1) ... /etc/kernel/postinst.d/dkms: dkms: running auto installation service for kernel 5.10.0-23-amd64:. /etc/kernel/postinst.d/initramfs-tools: update-initramfs: Generating /boot/initrd.img-5.10.0-23-amd64 cpio: write error: No space left on device E: mkinitramfs failure cpio 2 update-initramfs: failed for /boot/initrd.img-5.10.0-23-amd64 with 1. run-parts: /etc/kernel/postinst.d/initramfs-tools exited with return code 1 dpkg: error processing package linux-image-5.10.0-23-amd64 (--configure): installed linux-image-5.10.0-23-amd64 package post-installation script subprocess returned error exit status 1 dpkg: dependency problems prevent configuration of linux-image-amd64: linux-image-amd64 depends on linux-image-5.10.0-23-amd64 (= 5.10.179-1); however: Package linux-image-5.10.0-23-amd64 is not configured yet. dpkg: error processing package linux-image-amd64 (--configure): dependency problems - leaving unconfigured Errors were encountered while processing: linux-image-5.10.0-23-amd64 linux-image-amd64 <ERROR> Error configuring dkpg with /usr/bin/dpkg --configure -a - Error 1 <INFO> Clean up apt-databases and update
root@loxberry:~# df -h Filesystem Size Used Avail Use% Mounted on udev 1.5G 0 1.5G 0% /dev tmpfs 299M 6.0M 293M 2% /run /dev/sda1 33G 11G 21G 34% / tmpfs 1.5G 128K 1.5G 1% /dev/shm tmpfs 5.0M 0 5.0M 0% /run/lock /dev/zram1 386M 1.3M 356M 1% /opt/loxberry/log/ramlog tmpfs 299M 8.0K 299M 1% /run/user/1001 tmpfs 299M 8.0K 299M 1% /run/user/0
root@loxberry:~# ls /boot/ cmdline.txt config.txt config-5.10.0-21-amd64 config-5.10.0-23-amd64 grub initrd.img-5.10.0-21-amd64 rebootupdatescript rootfsresized System.map-5.10.0-21-amd64 System.map-5.10.0-23-amd64 vmlinuz-5.10.0-21-amd64 vmlinuz-5.10.0-23-amd64
