Loxberry compatibility to Raspberry pi 4B?
  • belisarius
    • 05.02.2024
    • 10
    is Loxberry compatibility to Raspberry pi 4B? And if so, what other requirments do i need to have once installing the loxberry into raspberry pi and connect it to loxone (any loxone extensions)?
    • 2554
    Sure, it is. Just install DietPi and then loxberry.
    Works flawlessly.
     DietPi v9.0.2 : Update available
     - Device model : RPi 4 Model B (aarch64)
     - CPU temp : 55 °C / 131 °F : Running warm, but safe
     - LAN IP : 10.99.99.7 (eth0)
     - MOTD : DietPi v9.1 has been released. Check out all changes:
              https://dietpi.com/docs/releases/v9_1/
     DietPi Team     : https://github.com/MichaIng/DietPi#the-dietpi-project-team
     Patreon Legends : Chris Gelatt, ADSB.im
     Website         : https://dietpi.com/ | https://twitter.com/DietPi_
     Contribute      : https://dietpi.com/contribute.html
     Web Hosting by  : https://myvirtualserver.com
     dietpi-update   : Run now to update DietPi from v9.0.2 to v9.1.1
     dietpi-launcher : All the DietPi programs in one place
     dietpi-config   : Feature rich configuration tool for your device
     dietpi-software : Select optimised software for installation
     htop            : Resource monitor
     cpu             : Shows CPU information and stats
    root@loxberry:~#​
    You should use an admin Account at Loxone to connect anything you want.
    • belisarius
      • 05.02.2024
      • 10
      Works flawlessly.
      root@loxberry:~#​
      i understand thank you, is there a detailed manual or help section on how to install diet pie then loxberry and finally connect to loxone?
        • 4761
        Not in english I am afraid. But maybe Google translate will do its job:
