Loxberry 3.0.1.2 update - MQTT Gateway not running
  • logol01
    • 03.03.2018
    • 837
    habe von der letzten Version Loxberry 2.xxx auf Loxberry 3.0.1.2 upgedatet.
    Hat ewig gedauert...
    Nun habe ich aber ein massives Probelm mit meinem MQTT Gateway.
    Selbsttest: ERROR --> MQTT --> MQTT Gateway not running (no PID). Last known status: MQTT Server state: Connected and subscribed to MQTT Server. Config state: Configfile present. UDP-IN state: UDP-IN socket connected.
    Wenn ich auf MQTT Gatway "Gateway Settings" gehe steht unten: "MQTT Gateway not running | Mosquitto running (PID3500)"
    in meinem Log steht folgendes..... was kann ich hier machen - bin ein wenig "aufgeschmissen".....eway started
    11:19:30.529 INFO: LoxBerry Version 3.0.1.2 ( is_arch_armv7l.cfg is_raspberry.cfg )
    11:19:30.529 INFO: Loglevel: 7
    11:19:30.549 INFO: KEEP IN MIND: LoxBerry MQTT only sends CHANGED values to the Miniserver.
    11:19:30.549 INFO: If you use UDP Monitor, you have to take actions that changes are pushed.
    11:19:30.560 Reading plugin configs
    11:19:30.561 Watching plugindir /opt/loxberry/config/plugins/camstream4lox/
    11:19:30.561 Watching plugindir /opt/loxberry/config/plugins/easee_home/
    11:19:30.561 Watching plugindir /opt/loxberry/config/plugins/fhem/
    11:19:30.562 Watching plugindir /opt/loxberry/config/plugins/foshkplugin/
    11:19:30.562 Watching plugindir /opt/loxberry/config/plugins/fritzlox/
    11:19:30.562 Watching plugindir /opt/loxberry/config/plugins/lbbackup/
    11:19:30.562 Watching plugindir /opt/loxberry/config/plugins/mirobot2lox-ng/
    11:19:30.563 Watching plugindir /opt/loxberry/config/plugins/motioneye/
    11:19:30.563 Watching plugindir /opt/loxberry/config/plugins/nukismartlock/
    11:19:30.563 Watching plugindir /opt/loxberry/config/plugins/smartmeter/
    11:19:30.563 Watching plugindir /opt/loxberry/config/plugins/sonos4lox/
    11:19:30.564 Watching plugindir /opt/loxberry/config/plugins/text2sip/
    11:19:30.564 Watching plugindir /opt/loxberry/config/plugins/weather4lox/
    11:19:30.564 trans_reread_directories
    11:19:30.566 Trans_Name php_textin_textout: /opt/loxberry/bin/mqtt/transform/shipped/udpin/examples/php_textin_textout.php
    11:19:30.645 Trans_Name php_jsonin_jsonout: /opt/loxberry/bin/mqtt/transform/shipped/udpin/examples/php_jsonin_jsonout.php
    11:19:30.723 Trans_Name php_jsonin_jsonarrayout: /opt/loxberry/bin/mqtt/transform/shipped/udpin/examples/php_jsonin_jsonarrayout.php
    11:19:30.800 Trans_Name http2mqtt: /opt/loxberry/bin/mqtt/transform/shipped/udpin/generic/http2mqtt.php
    11:19:30.884 Trans_Name moving_minmaxavg: /opt/loxberry/bin/mqtt/transform/shipped/udpin/generic/moving_minmaxavg.php
    11:19:30.965 Trans_Name sort: /opt/loxberry/bin/mqtt/transform/shipped/udpin/generic/sort.php
    11:19:31.049 Trans_Name shelly_rgb&w: /opt/loxberry/bin/mqtt/transform/shipped/udpin/shelly/shelly_rgb&w.php
    11:19:31.143 OK: Reading config changes
    11:19:31.146 OK: MQTT Gateway topic base is loxberry/mqttgateway/
    MQTT Gateway exited
    24.05.2024 11:19:31 TASK FINISHED
    Öffne bitte eine Shell als loxberry, und starte manuell
    /opt/loxberry/sbin/mqttgateway.pl
    Gibt es eine Exception?
    Vielleicht können danach ggf. die Kollegen weiterhelfen, ich bin die nächsten beiden Wochen unterwegs 🏍️🇦🇱
    Lg, Christian
    • logol01
      • 03.03.2018
      • 837
      Hi Christian,
      schonmal herzlichen Dank für Deine Hilfe...
      Wenn ich Deinen Vorschlag befolge, passiert folgendes:
      loxberry@loxberry:~/bin $ /opt/loxberry/sbin/mqttgateway.pl
      Configfile: /opt/loxberry/config/system/general.json
      <LOGSTART> 24.05.2024 14:34:08 TASK STARTED
      <LOGSTART> MQTT Gateway started
      14:34:08.397 <INFO> LoxBerry Version 3.0.1.2 ( is_arch_armv7l.cfg is_raspberry.c fg )
      14:34:08.397 <INFO> Loglevel: 7
      14:34:08.418 <INFO> KEEP IN MIND: LoxBerry MQTT only sends CHANGED values to the Miniserver.
      14:34:08.419 <INFO> If you use UDP Monitor, you have to take actions that change s are pushed.
      Setting timeouts for socket to 192.168.178.245:6666
      14:34:08.429 Reading plugin configs
      14:34:08.430 Watching plugindir /opt/loxberry/config/plugins/camstream4lox/
      14:34:08.431 Watching plugindir /opt/loxberry/config/plugins/easee_home/
      14:34:08.431 Watching plugindir /opt/loxberry/config/plugins/fhem/
      14:34:08.431 Watching plugindir /opt/loxberry/config/plugins/foshkplugin/
      14:34:08.431 Watching plugindir /opt/loxberry/config/plugins/fritzlox/
      14:34:08.432 Watching plugindir /opt/loxberry/config/plugins/lbbackup/
      14:34:08.432 Watching plugindir /opt/loxberry/config/plugins/mirobot2lox-ng/
      14:34:08.432 Watching plugindir /opt/loxberry/config/plugins/motioneye/
      14:34:08.433 Watching plugindir /opt/loxberry/config/plugins/nukismartlock/
      14:34:08.433 Watching plugindir /opt/loxberry/config/plugins/smartmeter/
      14:34:08.433 Watching plugindir /opt/loxberry/config/plugins/sonos4lox/
      14:34:08.433 Watching plugindir /opt/loxberry/config/plugins/text2sip/
      14:34:08.434 Watching plugindir /opt/loxberry/config/plugins/weather4lox/
      14:34:08.434 trans_reread_directories
      14:34:08.436 Trans_Name php_textin_textout: /opt/loxberry/bin/mqtt/transform/shi pped/udpin/examples/php_textin_textout.php
      14:34:08.520 Trans_Name php_jsonin_jsonout: /opt/loxberry/bin/mqtt/transform/shi pped/udpin/examples/php_jsonin_jsonout.php
      14:34:08.599 Trans_Name php_jsonin_jsonarrayout: /opt/loxberry/bin/mqtt/transfor m/shipped/udpin/examples/php_jsonin_jsonarrayout.php
      14:34:08.677 Trans_Name http2mqtt: /opt/loxberry/bin/mqtt/transform/shipped/udpi n/generic/http2mqtt.php
      14:34:08.758 Trans_Name moving_minmaxavg: /opt/loxberry/bin/mqtt/transform/shipp ed/udpin/generic/moving_minmaxavg.php
      14:34:08.877 Trans_Name sort: /opt/loxberry/bin/mqtt/transform/shipped/udpin/gen eric/sort.php
      14:34:08.958 Trans_Name shelly_rgb&w: /opt/loxberry/bin/mqtt/transform/shipped/u dpin/shelly/shelly_rgb&w.php
      14:34:09.049 <OK> Reading config changes
      14:34:09.052 <OK> MQTT Gateway topic base is loxberry/mqttgateway/
      Not a HASH reference at /opt/loxberry/sbin/mqttgateway.pl line 841.
      <LOGEND> MQTT Gateway exited
      <LOGEND> 24.05.2024 14:34:09 TASK FINISHED
      • logol01
        • 03.03.2018
        • 837
        anbei mal meine mqttgteway.pl Datei...
        Diese scheint den Fehler auszugeben....
          Schau mal in deine mqttgateway.json, was bei Main / msno steht. Da sollte 1 stehen.
          lg Christian
          • logol01
            • 03.03.2018
            • 837
            Hallo Christian Fenzl meine mqttgateway.json Datei unter /opt/loxberry/config/system ist quasi nicht existent und hat 2byte
            Hier im Anhang....
            Zuletzt geändert von logol01; 29.05.2024, 07:44.
            • logol01
              • 03.03.2018
              • 837
              ich wollte mich nochmals in Erinnerung rufen.
              Ich bekomme es nicht hin - ich bekommen das MQTT Gateway nicht zum laufen.
              Gibt es jemandem der mir hier heflen kann?
              Würde mich unfassbar freuen.
              Logol01
              • dieter_v
                • 28.03.2016
                • 95
                Ich habe auch erst versucht von der 2er auf die 3er upzudaten.
                Das hat aber letztendlich nur viel Zeit gekostet und nichts gebracht.
                Deshalb mein Tipp: RasPi mit DietPi (64Bit) neu aufsetzen, Plugins installieren und alles ist gut.
                Mach die Screenshots von den Einstellungen, das hilft beim Neuaufsetzen.
                Viel Erfolg
                LG Dieter
