shell-init: error retrieving current directory
  • Aleq
    • 04.05.2016
    • 53
    Hi guys,
    does anyone have an idea, what could cause error:
    shell-init: error retrieving current directory: getcwd: cannot access parent directories: No such file or directory
    I'm getting this in my log of a plugin I'm working on. The plugin has a daemon script, which executes Python script. This Python script then executes bash script from time to time using:
     output = subprocess.check_output(cmd, startupinfo=None)
    • It happens only after installation/upgrade of the plugin. If LoxBerry is restarted, the error isn't appearing
    • It appears with every bash script call
    • It appears in the log before the bash script output is received (possibly during)
    • Everything seems to be working despite the error
    • the content of bash script doesn't seem to the reason, it happens even with
    #!/bin/bash
    whoami
    Ani tips are welcome.
    Thanks, Best regards,
    Aleq
    • 11238
    I'm not in Python, but could find this: https://github.com/alcatraz/Alcatraz...ment-117986201
    During Plugin upgrade, all the plugin folders are deleted and then recreated - if your python script still keeps running, this might cause the message as the script looses it's working directory.
    Best regards,
    Christian
    • Aleq
      • 04.05.2016
      • 53
      Yes!
      PWD was /tmp/....
      Corrected by inserting
      cd $pluginbindir
      in front of the python script execution in daemon file.
      Thank you!
      Aleq
