Global symbol "$lbslogdir" requires explicit package name (did you forget to declare "my $lbslogdir"?) at /opt/loxberry/libs/perllib/LoxBerry/Web.pm line 45. Compilation failed in require at /opt/loxberry/webfrontend/htmlauth/system/index.cgi line 21. BEGIN failed--compilation aborted at /opt/loxberry/webfrontend/htmlauth/system/index.cgi line 21.
Wenn das geht einmal den Healthcheck ausführen und die Ausgabe hier posten (Text im Putty-Fenster markieren kopiert ihn automatisch in die Zwischenablage): https://www.loxwiki.eu/display/LOXBERRY/Healthcheck
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
Last login: Tue May 4 16:03:34 2021 from 192.168.178.64
loxberry@loxberry:~ $ /opt/loxberry/sbin/healthcheck.pl
Sub: check_lbversion
Title: LoxBerry Version
Status: OK (code 5)
Desc: Checks the LoxBerry Version
Result: Current Version: 2.2.0.5 / No newer Release available.
Logfile:
URL: https://www.loxwiki.eu/x/b4WdAQ
Sub: check_kernel
Title: Linux Kernel
Status: Info (code 6)
Desc: Checks the current installed Linux Kernel
Result: Linux loxberry 4.19.118-v7+ #1311 SMP Mon Apr 27 14:21:24 BST 2020 armv7l GNU/Linux
Logfile:
URL:
Sub: check_arch
Title: System Architecture
Desc: Checks the system architecture
Result: ARM / Raspberry Pi 3 Model B Rev 1.2^@
Logfile:
URL:
Sub: check_cputemp
Title: CPU Temperature
Status: OK (code 5)
Desc: Checks maximum CPU Temperature
Result: Current CPU Temperature is 47.8°C. Since last reboot the cpu never reached Raspberry's soft or critical temperature limit. This is fine.
Logfile:
URL:
Sub: check_voltage
Title: Voltage
Status: ERROR (code 3)
Desc: Checks the voltage of the power supply
Result: (0) Currently under-voltage detected! (2) Currently system is throttled! This is NOT fine. Check your power supply.
Logfile:
URL: https://www.loxwiki.eu/display/LOXBE...dware-Netzteil
Sub: check_readonlyrootfs
Title: RootFS
Status: OK (code 5)
Desc: Checks if the RootFS is mounted correctly
Result: RootFS is mounted ReadWrite. This is fine.
Logfile:
URL:
Sub: check_rootfssize
Title: RootFS free space
Status: OK (code 5)
Desc: Checks the rootfs for available space
Result: LoxBerry's RootFS has more than 10% free discspace (AVAL 8.6GB/SIZE 14.5GB).
Logfile:
URL:
Sub: check_tmpfssize
Title: RAMDiscs free space
Status: OK (code 5)
Desc: Checks the ramdiscs for available space
Result: All ramdiscs have more than 25% free discspace.
Logfile:
URL: https://www.loxwiki.eu/x/QINYAg
Sub: check_systemload
Title: System Load
Status: OK (code 5)
Desc: Checks the system load
Result: The system load is: 0.27 0.11 0.08 1/146 16771. Your system has 4 CPUs installed. The load is fine - maybe LoxBerry is even bored :-)
Logfile:
URL: http://www.brendangregg.com/blog/201...-averages.html
Sub: check_logdb
Title: Log Database
Status: OK (code 5)
Desc: Checks the consistence of the Logfile Database
Result: Init logfile database is ok. 452 log sessions with 6411 attributes stored. 237 logfiles are managed. Database size is 440.0KB.
Logfile:
URL: https://www.loxwiki.eu/x/oIMKAw
Sub: check_notifydb
Title: Notification Database
Status: OK (code 5)
Desc: Checks the consistence of the Notification Database
Result: Init notification database is ok. 42 notifications with 127 attributes stored. It contains 12 info and 29 error notifications.Database size is 44.0KB.
Logfile:
URL:
Sub: check_miniservers
Title: Miniserver Access
Status: OK (code 5)
Desc: Checks access to your Miniservers
Result: Home OK (admin user).
Logfile:
URL: https://www.loxwiki.eu/x/QYgKAw
Sub: check_reboot_required
Title: Reboot required
Status: OK (code 5)
Desc: Checks if LoxBerry or a plugin requests a reboot
Result: LoxBerry and plugins do not require a reboot of your LoxBerry.
Logfile:
URL: https://www.loxwiki.eu/x/fogKAw
Sub: check_loglevels
Title: Plugin Loglevels
Status: WARNING (code 4)
Desc: Checks for debug loglevel
Result: Plugins in DEBUG loglevel: Sonos. DEBUG loglevel leads to excessive logging/performance impact. Use only during troubleshooting.
Logfile:
URL:
Can't use string ("") as a HASH ref while "strict refs" in use at /opt/loxberry/libs/perllib/LoxBerry/IO.pm line 578.
Oben was du gepostet hast steht ja was der Fehler ist inkl Link zum wiki wie man es behebt, vllt gar.nicht gelesen?
Sub: check_voltage
Title: Voltage
Logfile:
habs im Wiki auch nochmal etwas konkretisiert. Wenn etwas im Wiki unklar beschrieben ist, am besten darauf verweisen, weil das natürlich eher dafür gedacht dass man solche Probleme schon selbst ohne weitere Hinweise lösen kann
Wenn LoxBerry das sagt, dann stimmt es. Wir „schätzen“ das nicht, sondern lesen die Register der Raspberry-CPU aus.
Aus meiner Sicht ist die Installation kaputt - Strom _kann_ Schuld sein, wenn er sogar schon während des Leerlaufs underpowered ist. All die bemängelten Libs und Variablen gibt es in unserem Code - dein Pi hat sich irgendwo verrannt. Wahrscheinlich fehlen irgendwelche Files auf der SD.
Wenn du ein Backup hast:
- Strom fixen
- Backup vor dem Update wiederherstellen
- Update nochmal durchführen
Wie irgendwo beschrieben ... ein Ladegerät (auch wenn 2, 3 oder 100A draufsteht) ist kein Netzgerät.
Ich hatte das natürlich auch nicht geglaubt und hatte irgend ein Ladegerät 5V/2,2A aus der Schublade für meinen Pi in Verwendung.
Kaum hatte ich das stats4lox Plugin laufen wurde alles ressorcen-intensiver und es dauerte eine Woche bis zum abkacken vom Loxberry.
Und auf gar keinen Fall darf das Kabel außer Acht gelassen werden. Dieses muss den Strom auch transportieren können. USB ist in Verbindung mit Daten eigentlich nur bis 500mA ausgelegt und bei mindestens bis USB2 durfte das auch nicht überschritten werden. Wie es bei USB3 ist weiß ich jetzt gar nicht. Aus diesem Grund ist halt auch Augenmerk auf das Kabel zu legen
