18:48:07.151 INFO: Running update script for v2.2.0.5...
18:48:07.171 INFO: Executing /opt/loxberry/sbin/loxberryupdate/update_v2.2.0.5.pl release=v2.2.1.1 logfilename=/opt/loxberry/log/system/loxberryupdate/20210901_184804_735_update.log cron= updatedir=/tmp/loxberryupdate/mschlenstedt-Loxberry-cb9c89a
OK: Update script /opt/loxberry/sbin/loxberryupdate/update_v2.2.0.5.pl started.
INFO: Checking for /boot/cmdline.txt and /boot/config.txt...
INFO: Files exist. Fine. Nothing to do.
OK: Update script /opt/loxberry/sbin/loxberryupdate/update_v2.2.0.5.pl finished.
18:48:07.394 INFO: exec_perl_script /opt/loxberry/sbin/loxberryupdate/update_v2.2.0.5.pl release=v2.2.1.1 logfilename=/opt/loxberry/log/system/loxberryupdate/20210901_184804_735_update.log cron= updatedir=/tmp/loxberryupdate/mschlenstedt-Loxberry-cb9c89a with user - errcode 0
18:48:07.395 INFO: Script version: v2.2.1.1
18:48:07.395 INFO: Running update script for v2.2.1.1...
18:48:07.415 INFO: Executing /opt/loxberry/sbin/loxberryupdate/update_v2.2.1.1.pl release=v2.2.1.1 logfilename=/opt/loxberry/log/system/loxberryupdate/20210901_184804_735_update.log cron= updatedir=/tmp/loxberryupdate/mschlenstedt-Loxberry-cb9c89a
OK: Update script /opt/loxberry/sbin/loxberryupdate/update_v2.2.1.1.pl started.
INFO: Updating f*cking changed YARN key. What the f*ck they are doing?!...
INFO: Enabling Emergency Webserver...
OK: /system/daemons/system/05-emergencywebserver installed.
OK: /opt/loxberry/system/daemons/system/05-emergencywebserver owner changed to root.
OK: /system/cron/cron.hourly installed.
OK: /opt/loxberry/system/cron/cron.hourly owner changed to root.
INFO: Updating LoxBerry cron folders execution behaviour...
OK: /system/cron/cron.d/lbdefaults installed.
OK: /opt/loxberry/system/cron/cron.d/lbdefaults owner changed to root.
INFO: Installing pre-requisites for LoxBerry RAMDISK File Analyzer...
OK: Configuring dpkg successfully.
INFO: Clean up apt-databases and update
OK: Apt packages autoremoved successfully.
ERROR: Error updating apt database - Error 100
Get:1 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster InRelease [15.0 kB]
Hit:2 http://ftp.agdsn.de/pub/mirrors/raspbian/raspbian buster InRelease
Hit:3 https://deb.nodesource.com/node_12.x buster InRelease
Get:4 http://ftp.gwdg.de/pub/linux/debian/raspbian/raspbian buster InRelease [15.0 kB]
Get:5 https://dl.yarnpkg.com/debian stable InRelease [17.1 kB]
Reading package lists...
OK: Apt cache cleaned successfully.
OK: Packages libsys-filesystem-perl libipc-run3-perl libhash-merge-perl successfully installed
ERROR: Update script /opt/loxberry/sbin/loxberryupdate/update_v2.2.1.1.pl finished with errors.
18:48:26.811 INFO: exec_perl_script /opt/loxberry/sbin/loxberryupdate/update_v2.2.1.1.pl release=v2.2.1.1 logfilename=/opt/loxberry/log/system/loxberryupdate/20210901_184804_735_update.log cron= updatedir=/tmp/loxberryupdate/mschlenstedt-Loxberry-cb9c89a with user - errcode 1
18:48:26.812 ERROR: Update-Script update_v2.2.1.1 returned errorcode 1. Despite errors loxberryupdate.pl will continue.
18:48:26.812 INFO: Setting update script update_v2.2.1.1 as failed in general configuration.
18:48:26.812 INFO: Updating update script fail state in general configuration...
18:48:26.814 WARNING: LoxBerry Update was SUCCESSFULL, but skipped at least 1 warnings or errors. Check the log.
18:48:26.814 CRITICAL: LoxBerry Update exited or terminated with an error. Errorcode: 1
LoxBerry Update processing finished.
01.09.2021 18:48:26 TASK FINISHED
