\\r
[CODE]
/bin/bash
echo -e -n ...
[CODE]
und rufst dein Script auf:
... off command ./script.sh
Du kannst mit $1 auch einen Parameter abfragen, und somit direkt vom MS unterschiedliche Parameter mitgeben.
lg Christian
\\r
#!/bin/bash var1="<" var2="$1" var3="\r" command=$var1$var2$var3 echo -e $command > /dev/ttyUSB0
Zone1 off command ./SerialSend.sh 11PR01
SEND via UDP to MS1: "ZeitabfrageM":23 ####### New Connection ### 118-6-12 19:23:17 LOCAL TIME ###### Remote: 10.0.0.10 New guest connection accepted from 10.0.0.10. No MS defined. Setting to msnr=1 Calling exec_command exec_command Commandline: date +%S 1. Parameter (Name) is ZeitabfrageS 2. Parameter is udp (will return udp string) 3. Parameter is command (will run following command) Miniserver used is 1 (Loxone) Exit Code: 0 Output: 17 SEND via UDP to MS1: "ZeitabfrageS":17 ###################### Any-Plugin V0.1.4 ###################### Global variables from LoxBerry::System Homedir: /opt/loxberry Plugindir: anyplugin YOUR commands: /opt/loxberry/data/plugins/anyplugin/commands Restricted IPs (0): Any-Plugin mode is UNSECURE ERROR: It seems that this port is already occupied - Another instance running? QUITTING with error: Invalid argument (Address already in use) server waiting for tcp client connection on port 9095 Created udp out socket to 10.0.0.10 on port 9096
