Bitte im Titel immer zuerst den Namen des Plugins hinschreiben
Hi, I've just released Syslog Server plugin.
The Syslog Server use the standard rsyslog package. It's possible to receive log entries from another system (e.g. Miniserver - instead of saving logs into Miniserver's SD card) and stored them in separate log file.
For analyzing of log files is used Adiscon LogAnalyzer
If somebody want to translate please send me final ini files.
If you have any question or enhancement requirement you can write it here or on plugin wiki. Please keep English in this thread!
I don't speak German.
Thanks
Zmata
I did a quick translation into German, which might help some people. You find it in the attachment.
Eine schnelle deutsche Übersetzung befindet sich im Anhang.
Loxone-Installation mit mehreren Extensions, Dimmer-Extension, DMX, 1-Wire (alles aktuell noch im Auslieferungszustand);
FritzBox, Netgear Plus Switch mit mehreren VLANs, Intel NUC mit VMWare ESXi 6.5 (pfSense, Loxberry, Kleinkram)
v0.0.3 released with German translation by Riesenschnabel
Thanks Riesenschnabel!
Unfortunately if I switch to German ü is not displayed correctly. In github repo it's OK. Could anybody confirm, that you see it same?
Thanks
For a quick fix you can replace the Umlaut "ü" with "ue".
Not pretty, but works.
interesting plugin.
Am i corrrect understanding the following?
This server replaces the internal logging on the sd card. so all data is written to the server?
Is this just for logs or also for statistics?
Yes you understand well. Logs are in LoxBerry instead of the Miniserver's SD card.
If you use LoxBerry on raspberry pi (so it's on SD card too), you can permanently mount remote dir (for example dir from your NAS) into Syslog Server's log dir.
It's just for logs, not for statistics.
Just for your information: LoxBerry supports now automatically mounting USB and Network Storages. There's already som LIB functions for that, but Christian Fenzl also plans to create some piece of HTML from the libs that can be included into your template.
Hi all
Is it possible that the plugin not work anymore with the newest Loxberry version 2.0.1.3?
I set all parameters like the manual but i dont get any data from my miniserver.
Zuletzt geändert von mecsolutions; 13.04.2020, 20:31.
