  • ledchab
    • 10.02.2016
    • 426
    #661
    Moin Moin,
    20210128_083011_421_datatoloxone.log
    20210128_083002_817_grabber_weatherflow.log
    Zuletzt geändert von ledchab; 28.01.2021, 12:37.
      • 4759
      #662
      nufke Maybe some Timezone issue.... I had a lot of them with the other grabbers :-D
      ledchab Can you please check the Timezone of your Miniserver and the Timezone of the LoxBerry? And please check that on both the clock is correct.
      • ledchab
        ledchab kommentierte
        bin nicht @home
        Loxberry Zeit und Zone stimmt
        Miniserver sollte auch stimmen - zeigt in der App die richtige Zeit an
      • nufke
        nufke kommentierte
        ledchab Are we talking about a timezone shift/offset of 1 or 2 hours or missing data for 1 or 2 hours? I would appreciate if you can compare the forecast data as shown in the Weatherflow app with the data shown in the weather4lox page (<yourloxberryip>/plugins/weather4lox/webpage.html).
        Zuletzt geändert von nufke; 28.01.2021, 12:30.
    • ledchab
      • 10.02.2016
      • 426
      #663
      we are talking about a 2 hour timeshift
      from url clock says actual time
      but forecast starts from 15:00
Name: Bildschirmfoto 2021-01-28 um 13.50.46.png
Ansichten: 705
Größe: 54,6 KB
      from App time 15:00
      forecast from 15:00
Name: Bildschirmfoto 2021-01-28 um 13.49.13.png
Ansichten: 655
Größe: 34,0 KB
        • 4759
        #664
        ledchab Thanks. But I think we need an additional set of data. Please grab weather data once again and again please send both log files in debug mode. Additional, im the Emulator tab of the plguin, please click on "test" (button is maybe named different - cannot remember :-)) and also post the emulator data here.
        It is important that we have all data of the same time, so please first grab the weather data and then send logfiles and emulator data of the same time.
        • nufke
          nufke kommentierte
          On top of that, I would also prefer a screengrab of the forecast as shown in your Weatherflow app at the same time.
          I am not sure if we are facing a timeshift here, I think we simply miss the first forecast hour. Therefore you need to compare the temperatures at the following hours and compare with the Weatherflow app, to see if there is actually a time offset for all data.
        • ledchab
          what means emulator data? screenshot or is there a log file?
          It's an ASCII Textfile, which opens in your browser. Copy and Paste it in any editor and save it as a file. Or paste it here directly between code-tags. both is possible.
      • ledchab
        • 10.02.2016
        • 426
        #665
        here we go
        [ATTACH]n288566[/ATTACH]
        [ATTACH]n288567[/ATTACH]
        [ATTACH]n288568[/ATTACH]
Name: Bildschirmfoto 2021-01-28 um 14.47.27.png
Ansichten: 670
Größe: 157,1 KB
          But before you had a two hour gab, right?
        • nufke
          nufke kommentierte
          Can you share the Weatherflow app screengrap and the emulator data?
          It is known that the Loxone app is not regularly updating its weatherforecast, so you need to look to the weather4lox weather webpage or the raw data.
        • ledchab
          Prof.Mobilux yes before 2 hours
          nufke yes Loxone update every hour so i´ve always checked after hour changed
      • bluemevo
        • 27.01.2019
        • 63
        #666
        Ich hab gerade die aktuelle Loxone Beta 11.3.1.27 getestet. Der Wetterservice Emulator funktioniert damit leider nicht mehr
        In den Logs hab ich keine Fehler - bis vor dem Update hat der Wetterservice noch funktioniert.
        Logs stell ich auf Wunsch gern zur Verfügung.
          Miniserver-Widget am LoxBerry / Button Miniserver Logdatei
        • StoRmtec
          StoRmtec kommentierte
          Das ich auch mein Fehler was ich geschrieben habe das es mit der neuen Config Alpha nicht mehr geht. Das man bekommt User Authetification fehler
        • TGeissler
          TGeissler kommentierte
          Kann ich so nachstellen dass es nicht mehr geht!
      • bluemevo
        • 27.01.2019
        • 63
        #667
        Für mehr, schick mir gern eine PN, da stehen ziemliche viele Sachen drin, die ich nur sehr ungern aus der Hand geb.
        def.log
        • ledchab
          • 10.02.2016
          • 426
          #668
          nufke
          [ATTACH]n288761[/ATTACH]
Name: Bildschirmfoto 2021-01-29 um 21.15.19.png
Ansichten: 609
Größe: 128,3 KB
          • nufke
            nufke kommentierte
            In my view, all looks good... The Loxone app shows the current (live) observation of your local Weatherflow weatherstation full screen and as first entry in the list, and takes this from the first line from the emulator data (you recognize this with the temperature notation with 1 decimal accuracy). The items in the Loxone app forecast (horizontal scroll part) are idential to the forecast list from the Weatherflow app as you've shown above (notation is in degrees without decimals, so x.0 notation in the emulation data and in Loxone app).
            Note that the current forecast data from Weatherflow is NOT used, since we use the current weatherstation data. So it could happen that you see some differences due to this. Please let me know if that explains the differences you see, or if I overlook something here.
            Zuletzt geändert von nufke; 29.01.2021, 21:16.
        • ledchab
          • 10.02.2016
          • 426
          #669
          that's what we talking about?
          emulator screen in App shows the wrong time (grabbing time from Miniserver?)
          Klicke auf die Grafik für eine vergrößerte Ansicht  Name: Bildschirmfoto 2021-01-29 um 22.20.37.png Ansichten: 0 Größe: 120,8 KB ID: 288772
          actual time is 22:23
          the top line says 23:00 - so it is in the future should be 22:00 - when i switch to other service there is 22:00
          it is not a really problem for me - so i just marked it as little confusing ;-)
          • ledchab
            do you see the UTC+1 anywhere in the weatherflow data?
            i found no setup for timezone - it think they do it automatically by location
          • ledchab
            the weather is not getting any better either ;-)
            so the battery is still low and the station is not really useful for me in the moment
          • nufke
            nufke kommentierte
            The UTC+1 calculation in the emulation data is calculated based on the response from the weatherflow API based on your stationID, so this looks OK. Indeed there is no setting in the weatherflow app or account to change your timezone. Perhaps this was a question when installing the weatherflow hub, but I do not recall this anymore.
            The weather4lox integration is only of use for the weatherscreen and forecast in the Loxone app, and not something I recommend for home automation, since you probably query only each 5 minutes or so. Instedd, you need to use the local Tempest UDP data directly to grab instant data for temperature, illuminance, precipitation, lightning detection, etc.
            FYI Weatherflow team is working on a "power booster" to extend battery lifetime. More info on the weatherflow community forum.
          • 3665
          #670
          Update installiert 11.3.1.27 und am MSV2 geht der Wetterservice nicht.
          Am MSGov1 im gleichen Netz mit 11.3.1.27 funktioniert der Wetterservice.
          • madito
            madito kommentierte
            It has stopped working for me too.
          • 4759
          #671
          An alle mit Beta, wo der Emulator nicht mehr funktioniert: Seid ihr auf dem Miniserver V1 oder V2? Ist das eine öffentliche Beta, die ich irgendwo herunterladen kann?
            Das ist die Beta 5 die du hier laden kannst
            Hier finden Sie aktuelle Downloads. Laden Sie unsere Software kostenlos herunter. Mit unserer Software lässt sich Ihr Miniserver individuell programmieren.
            Auf V2 geht er nicht mehr das sehe ich, den V1 kann ich heute Abend mal versuchen wie es da ist.
            Könnte es sein das sie jetzt irgendwas mit SSL machen?
          • StoRmtec
            Gen2 funktioniert es nicht mehr.
            Evtl mit diesem Change das es zu tun hat vl.
            R12-T762 Miniserver Gen2 now uses Zeroconf Ipv4 Link-Local Addressing.
            If DHCP configuration is activated, the Miniserver will not fall back to 192.168.1.77 if no IP address is assigned from a DHCP server.
        • Gerrit
          • 940
          #672
          Kann Emulator Probleme ebenfalls mit der aktuellsten Beta 11.13.1.29 auf Miniserver 1 und Miniserver 2 bestätigen.
          Habe beide DNS Server bei beiden Miniservern auf den Loxberry gestellt. Zudem mit dig den DNS Server vom Loxberry erfolgreich getestet. Mehrere Neustarts der Miniserver ändern nichts dran und forecast gibt weiterhin korrektes Ergebnis zurück.
            • 4759
            #673
            Moin Leute,
            ich kann das Verhalten bestätigen. Ich habe jetzt nicht allzu viel Zeit dort investiert, aber es scheint so, dass in der Beta die konfigurierten Nameserver nicht verwendet werden. Man sieht zum einen, dass der Miniserver für weather.loxone.com die gecachete IP-Adresse verwendet, weil er die korrekte IP-Adresse nicht bzw. den Hostnamen nicht auflösen kann. Und man sieht im Mitschnitt des Netzwerkverkehrs, dass der Miniserver trotz lokal konfiguriertem Nameserver immer wieder mit dem Google DNS-Server 8.8.8.8 spricht.
            Ob das nun Absicht oder ein Bug ist, kann ich nicht sagen.
              simon_hh kommentierte
              na n Bug wird es nicht sein bei über 2500 Plugin Nutzern. Vielleicht sollte das aus der Statistik ausgeblendet werden.
              Schon probiert den DNS, als auch den Alternativen DNS in der config auf den loxberry einzustellen? Oder ist der google DNS irgendwo hard gecodet hinterlegt?
              Na klar, ich habe beide DNS in der Config geändert. So schlau war ich auch ;-)
            • 3665
            #674
            Vielen Dank für deine schnelle Analyse.
            Warten wir mal ab.
            • hme0354
              • 06.07.2019
              • 970
              #675
              interessant wäre zu wissen ob der loxone wetterservice funktioniert
                Wieso? Der bekommt von Google doch die richtige IP.
              • hme0354
                hme0354 kommentierte
                war ja nur eine Frage, könnte ja überhaupt ein Bug sein beim V2. Hat sich aber nicht bestätigt. Ein Kumpel von dasrockt hat den Wetterservice mit aktueller Beta. Da geht alles
