Plugin: MiRobot2Lox-NG - Xiaomi Vacuum Robots
  • Tom001
    • 20.05.2016
    • 320
    #271
    mit dem anderen Gerätetyp hab ich un was in der robotsdata.txt:
    MiRobot1: now_human=Tue Apr 6 22:22:06 2021 MiRobot1: now=1617740526 MiRobot1: = MiRobot1: warning:miio.viomivacuum:unknown_vacuum_state=none MiRobot1: valueerror=none is not a valid viomibintype MiRobot1: = MiRobot1: during_handling_of_the_above_exception,_another_ex ception_occurred: = MiRobot1: = MiRobot1: traceback_(most_recent_call_last): = MiRobot1: __file_"/usr/local/bin/miiocli",_line_8,_in_<module> = MiRobot1: ____sys.exit(create_cli()) = MiRobot1: __file_"/usr/local/lib/python3.7/dist-packages/miio/cli.py",_line_45,_in_create_cli = MiRobot1: ____return_cli(auto_envvar_prefix="miio") = MiRobot1: __file_"/usr/local/lib/python3.7/dist-packages/miio/click_common.py",_line_59,_in___call__ = MiRobot1: ____return_self.main(*args,_**kwargs) = MiRobot1: __file_"/usr/local/lib/python3.7/dist-packages/click/core.py",_line_717,_in_main = MiRobot1: ____rv_=_self.invoke(ctx) = MiRobot1: __file_"/usr/local/lib/python3.7/dist-packages/click/core.py",_line_1137,_in_invoke = MiRobot1: ____return__process_result(sub_ctx.command.invoke( sub_ctx)) = MiRobot1: __file_"/usr/local/lib/python3.7/dist-packages/click/core.py",_line_1137,_in_invoke = MiRobot1: ____return__process_result(sub_ctx.command.invoke( sub_ctx)) = MiRobot1: __file_"/usr/local/lib/python3.7/dist-packages/click/core.py",_line_956,_in_invoke = MiRobot1: ____return_ctx.invoke(self.callback,_**ctx.params) = MiRobot1: __file_"/usr/local/lib/python3.7/dist-packages/click/core.py",_line_555,_in_invoke = MiRobot1: ____return_callback(*args,_**kwargs) = MiRobot1: __file_"/usr/local/lib/python3.7/dist-packages/miio/click_common.py",_line_285,_in_wrap = MiRobot1: ____result_msg_=_result_msg_fmt.format(**kwargs) = MiRobot1: __file_"/usr/local/lib/python3.7/dist-packages/miio/viomivacuum.py",_line_321,_in_bin_type = MiRobot1: ____return_viomibintype(self.data["box_type"]) = MiRobot1: __file_"/usr/lib/python3.7/enum.py",_line_310,_in___call__ = MiRobot1: ____return_cls.__new__(cls,_value) = MiRobot1: __file_"/usr/lib/python3.7/enum.py",_line_564,_in___new__ = MiRobot1: ____raise_exc = MiRobot1: __file_"/usr/lib/python3.7/enum.py",_line_548,_in___new__ = MiRobot1: ____result_=_cls._missing_(value) = MiRobot1: __file_"/usr/lib/python3.7/enum.py",_line_577,_in__missing_ = MiRobot1: ____raise_valueerror("%r_is_not_a_valid_%s"_%_(val ue,_cls.__name__)) = MiRobot1: valueerror=none is not a valid viomibintype
      • 5686
      #272
      Ja, passt aber nicht. Kann ich leider nicht helfen, weil ich diesen Robot nicht habe.
      Meine Projekte:
      • Iluminatus23
        • 07.08.2016
        • 256
        #273
        Also bei mir läuft der S7 super. Konnte sogar eine Zonen Reinigung via Koordination direkt vom S50 übernehmen.
        Hab auch den gleichen Typ verwendet. Hast Du es Mal mit Robi#02 versucht?
        Mich würde eigentlich nur interessieren, wie man die einzelnen Modi ansteuert. Also Intensivwischen oder eine Combo aus Saugen und Wischen. Gibt es da Erfahrungen?
        • Tom001
          Tom001 kommentierte
          Welche Firmware hat dein Robot? Meiner hat die 4.1.2_0928
        • Iluminatus23
          Iluminatus23 kommentierte
          Habe ebenso 0928.....echt komisch
        • Tom001
          Tom001 kommentierte
          Und du verwendest die Xiaomi Home App oder die Roborock App?
      • Tom001
        • 20.05.2016
        • 320
        #274
        Auch wenn ich ihn als #02 oder #03 eintrage das selbe. Komisch ist, dass ich in der status diese Daten rauskriege:
        Output: { "msg_ver": 2, "msg_seq": 160, "state": 8, "battery": 90, "clean_time": 621, "clean_area": 12157500, "error_code": 0, "map_present": 1, "in_cleaning": 0, "in_returning": 0, "in_fresh_state": 1, "lab_status": 3, "water_box_status": 1, "fan_power": 102, "dnd_enabled": 0, "map_status": 3, "is_locating": 0, "lock_status": 0, "water_box_mode": 202, "water_box_carriage_status": 0, "mop_forbidden_enable": 0, "adbumper_status": [ 0, 0, 0 ], "water_shortage_status": 0, "dock_type": 0, "dust_collection_status": 0, "auto_dust_collection": 1, "mop_mode": 300, "debug_mode": 0 }
        Er ist effektiv erreichbar. Batterie stimmt auch. clean time und clean area scheint er aber noch vom alten übernommen zu haben. der neue hat 457min und 422m2
          Hello, do you have any idea if this plugin is compatible with this new Xiaomi ROIDMI EVE Plus vacuum cleaner?
          Thank you!
          • Tom001
            • 20.05.2016
            • 320
            #276
            Wie kann ich das miio Paket updaten von github? Es wurden in der Tat einige Änderungen für den S7 gemacht..
              • 5686
              #277
              Mit pip - wie immer bei Python.
              Meine Projekte:
              • Tom001
                • 20.05.2016
                • 320
                #278
                Das geht aber nur wenn er die aktuellen Änderungen im Projekt in ein Release packt oder?
                • renezs
                  • 01.07.2016
                  • 138
                  #279
                  wurde bei dem letzten Relaese etwas an der Funktion "Ladestation verlassen" geändert. Vor dem Update ist der Robot wenigstens ein Stück von der Laderstation weg gefahren, jetzt dreht er sich nur nur ein Stück und fährt nicht los.
                  Hat jemand einen Tipp.
                  • kudykam
                    • 19.04.2021
                    • 22
                    #280
                    With Roborck S5 max I have this debug info:
                    Output: /opt/loxberry/bin/plugins/mirobot2lox-ng/mirobo_wrapper.sh: line 61: -d: command not found
                    • Tom001
                      • 20.05.2016
                      • 320
                      #281
                      Wäre es möglich dass bei mir mal jemand mit Teamviewer draufschaut? Ich werde einfach nicht schlau. Die robotsdata.txt bleibt leer und über udp wird nichts gesendet. Ich kann aber Kommandos absetzen, dh er startet zum Saugen oder er fährt aus dem Dock und wieder zurück.
                      Ich habe nun einen neuen Loxberry aufgesetzt und der verhält sich identisch.
                      Vielen Dank!
                      • kudykam
                        • 19.04.2021
                        • 22
                        #282
                        Hallo, ich habe diesen Fehler während der Plugin-Installation:
                        Wie kann ich das beheben?
                        [SIZE=13px][COLOR=#8080ff][FONT=monospace]Installing collected packages: PyYAML, pytz, netifaces, importlib-metadata, defusedxml, cryptography, croniter, construct, click, attrs, appdirs, android-backup, python-miio[/FONT][/COLOR][/SIZE]
                        [SIZE=13px][COLOR=#8080ff][FONT=monospace]Attempting uninstall: PyYAML[/FONT][/COLOR][/SIZE]
                        [SIZE=13px][COLOR=#8080ff][FONT=monospace]Found existing installation: PyYAML 3.13[/FONT][/COLOR][/SIZE]
                        [SIZE=13px][COLOR=#8080ff][FONT=monospace]ERROR: Cannot uninstall 'PyYAML'. It is a distutils installed project and thus we cannot accurately determine which files belong to it which would lead to only a partial uninstall.[/FONT][/COLOR][/SIZE]
                        [SIZE=13px][COLOR=#8080ff][FONT=monospace]yes: standard output: Broken pipe[/FONT][/COLOR][/SIZE]
                        [SIZE=13px][COLOR=#000000][FONT=monospace][COLOR=red][B]WARNING:[/B][/COLOR] Python MIIO tools installation failed! The plugin will not work without.[/FONT][/COLOR][/SIZE]
                        [SIZE=13px][COLOR=#000000][FONT=monospace][COLOR=red][B]WARNING:[/B][/COLOR] Giving up.[/FONT][/COLOR][/SIZE]
                        [SIZE=13px][COLOR=#000000][FONT=monospace]11.05.2021 12:54:09 [COLOR=red][B]CRITICAL:[/B][/COLOR] Script fails. Installation cannot be continued.[/FONT][/COLOR][/SIZE]
                        [SIZE=13px][COLOR=#8080ff][FONT=monospace]Use of uninitialized value in concatenation (.) or string at /opt/loxberry/sbin/plugininstall.pl line 1801.[/FONT][/COLOR][/SIZE]
                        [SIZE=13px][COLOR=#8080ff][FONT=monospace]Use of uninitialized value in concatenation (.) or string at /opt/loxberry/sbin/plugininstall.pl line 1802.[/FONT][/COLOR][/SIZE]
                        • renezs
                          • 01.07.2016
                          • 138
                          #283
                          ich habe meinen Loxberry mit der aktuellen Version 2.0.4 neu aufgesetzt und da kommt jetzt bei der Plugininstallation folgende Fehlermeldung und es kann nicht installiert werden.
                          Kann mir jemand helfen
                          tkFAFCVE9K.log
                            • 5686
                            #284
                            Dieser Python-Schrott wirft mal wieder einen Fehler aus bei der Installation. Das bringt mich noch zur Verzweiflung... Das ist ja schlimmer als Perl.
                            Meine Projekte:
                            • JürgenW
                              • 19.06.2019
                              • 97
                              #285
                              Problem: Roborock S5 Max läuft nicht mit Mirobot2Lox-NG V1.2 und neuster FW 3.5.8_1410
                              Ausstattung:
                              Roborock S5Max, FW 3.5.8_1410 (miio-client 3.5.8", "model": "roborock.vacuum.s5e",)
                              LoxBerry V2.0.1.3
                              Mirobot2Lox-NG V1.0.5 oder Mirobot2Lox-NG V1.2
                              habe das Problem, dass mein neuer S5Max mit der aktuellsten Mirobot2Lox-NG nicht ansprechbar ist. Sobald ich auf die V1.0.5 gehe funktioniert die Ansteuerung und Auslesung einwandfrei (somit Token und Netzwerkeinstellung okay). Benutze diese Version auch in meiner anderen Wohnung seit langer Zeit ohne Probleme.
                              Ist das Problem bei der V1.2 bekannt? Was könnte ich noch tun um den Fehler einzugrenzen?
                              Vielen Dank
                              JW
