es gehören vor reinstall zwei Bindestriche:
sudo apt-get install --reinstall mosquitto LG
fhem_vitoconnect_HK1-Zeitsteuerung_Heizung | {"fri":[{"position":0,"end":"08:30","mode":"normal","st art ":"04:30"},{"mode":"normal","end":"23:00","sta rt": "15:30","position":1}],"sun":[{"position":0,"mode":"normal","end":"23:00","st art ":"04:30"}],"thu":[{"position":0,"start":"04:30","end":"08:30","mo de" :"normal"},{"position":1,"end":"23:00","mode":" nor mal","start":"15:30"}],"sat":[{"start":"04:30","mode":"normal","end":"23:00", "po sition":0}],"wed":[{"mode":"normal","end":"08:30","start":"04:30", "po sition":0},{"start":"15:30","end":"23:00","mode":" normal","position":1}],"mon":[{"position":0,"end":"08:30","mode":"normal","st art ":"04:30"},{"start":"15:30","mode":"normal","e nd": "23:00","position":1}],"tue":[{"end":"08:30","mode":"normal","start":"04:30", "po sition":0},{"position":1,"end":"23:00","mode":"nor mal","start":"15:30"}]} |
perl -e 'use JSON; print JSON->backend' perl -e 'use JSON;decode_json("0.8");'
perl -e 'use JSON;print JSON->backend' Ausgabe: JSON::Backend::XS
perl -e 'use JSON;decode_json("0.8");' Ausgabe: "" (leer/nichts)
loxberry@loxberry:~/bin/plugins/mqttgateway $ perl -e 'use JSON;decode_json("TEST");' malformed JSON string, neither tag, array, object, number, string or atom, at character offset 0 (before "TEST") at -e line 1.
loxberry@loxberry:~/bin/plugins/mqttgateway $ perl -e 'use JSON;decode_json("0.8");' loxberry@loxberry:~/bin/plugins/mqttgateway $
loxberry@loxberry:~ $ perl -e 'use JSON;decode_json(0.1);' malformed JSON string, neither tag, array, object, number, string or atom, at character offset 0 (before "(end of string)") at -e line 1.
