Problems with LoxBerry, MQTT and Shellies
Hello I starting to set up my first Loxberry and everything has gone well until MQTT. I setting up Shelly1 and trying to connect it with my Miniserver. I set up the subscription for Shelly1 shellies/#. But I always get in the Miniserver Virtual Inputs loxberry_mqttgateway_xxxxx seven of them. I have gone trough the config many times and read trough the websides again and again but can't find anything wrong I am doing. So I was thinking if someone has gone trough similar things in MQTT and share it with me I would be very grateful.Stichworte: - -
You need to provide more information, like screenshots of what you have done.
E.g. your Shelly MQTT Config.
Currently I only can read “it does not work”.Hilfe für die Menschen der Ukraine: https://www.loxforum.com/forum/proje...Cr-die-ukraine -
use Firmware 1.10.4
reboot shelly
password OK ??Grüße AlexKommentar
And you are absolutely sure that 192.168.1.77 is the IP of LoxBerry.
Because, this is usually the default ip of the Miniserver.Hilfe für die Menschen der Ukraine: https://www.loxforum.com/forum/proje...Cr-die-ukraineKommentar
Having the same issue. Built 2 different Loxberry, 1 in a Rpi and one in an old laptop. also tried 2 diffferent shellies. verified ip's but always get the same results. just the 7 inputs from the miniserver. nothing from either shellyKommentar
One of the Kitchensd fields is the MQTT topic. Have you added a subscription for KitchenSD/# in the plugin?
You may define the topic on Shelly to shellies/Kitchensd, then it will be subscrbed by the default shellies/# subscription.Hilfe für die Menschen der Ukraine: https://www.loxforum.com/forum/proje...Cr-die-ukraineKommentar
