Home assistant on docker on RPI with Loxberry
  • hill2button
    • 26.12.2021
    • 9
    Hi, I am trying to run Home Assistant on the RPI4 on which Loxberry is already running.
    I installed docker through the GUI, but it was an older version of Portainer, 1.25 or something. I found some instructions online on how to upgrade to 2.14.2 of Portainer. This worked. I then followed some steps to install a Home Assistant container. This worked too, however, the container won't start:
    s6-linux-init-hpr: fatal: unable to reboot(): Operation not permitted
    s6-svscan: warning: unable to iopause: Operation not permitted
    s6-svscan: warning: executing into .s6-svscan/crash
    Some google brought me here: https://www.reddit.com/r/homebridge/...starting_loop/
    This states that I have to upgrade the host OS. But I guess this is linked to the Loxberry install. I checked the Loxberry GUI, and there are no updates available. I am currently on v2.2.1.2.
    Raspbian - 10 (buster)
    4.19.118-v7l+
    Question: can I update the OS somehow to get the home assistant container up and running without messing up Loxberry?
    Tnx!
  • hill2button
    • 26.12.2021
    • 9
    Anyone?
    • Speed
      • 12.12.2018
      • 23
      I don’t know if you already fix it, but for all others: try to update libseccomp2
      https://blog.samcater.com/fix-workar...mp2-docker-20/
      Make a backup before
      • Loxster
        • 08.10.2023
        • 22
        Hi hill2button,
        are there any news about the installation of your home assistant container? I'm curious how you actually did that. Are you so kind to point me to the mentioned instructions?
        I finally figured out how to reset the Docker's password , but now I have no clew how to install the home assistant container for my YIO remote 2, that hopefully is about to arrive shortly. I would like to build some kind of a bridge between the MS and the remote 2. Mi idea was to achieve that via home assistant.
        Unfortunately I am not experienced in docker at all.
        cheers
        Robert
        • Speed
          • 12.12.2018
          • 23
          Hi Loxster,
          here you find the manual for the docker container -> https://www.home-assistant.io/instal...tant-container
          Do you have installed also Portainer for container management?
          Best
          Alex
