Plugin: Lox2MQTT
  • mariokrupik
    • 23.12.2015
    • 46
    #31
    I am having troubles getting the Plugin to work.
    I installed the Plugin months ago, but never really used it.
    Today I wanted to get it set up, but the Plugin always stays with the Message "Lox2MQTT not running", the Log in the Logfiles Tab is mostly empty.
    The only message I can see in the log is this one:
    HTML-Code:
    2023-12-29T10:35:52: TypeError: Cannot read property 'split' of undefined
    2023-12-29T10:35:52: at new DateSpan (/opt/loxberry/bin/plugins/lox2mqtt/node_modules/node-lox-structure-file/lib/Structure/DateSpan.js:3:29)
    2023-12-29T10:35:52: at Factory.create_from_json (/opt/loxberry/bin/plugins/lox2mqtt/node_modules/node-lox-structure-file/lib/Factory.js:33:13)
    2023-12-29T10:35:52: at Object.create_from_json (/opt/loxberry/bin/plugins/lox2mqtt/node_modules/node-lox-structure-file/lib/Factory.js:108:24)
    2023-12-29T10:35:52: at new Adaptor (/opt/loxberry/bin/plugins/lox2mqtt/lib/Adaptor.js:7:30)
    2023-12-29T10:35:52: at API. (/opt/loxberry/bin/plugins/lox2mqtt/lib/MsClient.js:54:24)
    2023-12-29T10:35:52: at API.emit (events.js:326:22)
    2023-12-29T10:35:52: at Object.callback (/opt/loxberry/bin/plugins/lox2mqtt/node_modules/node-lox-ws-api/lib/API.js:281:18)
    2023-12-29T10:35:52: at API._message_file (/opt/loxberry/bin/plugins/lox2mqtt/node_modules/node-lox-ws-api/lib/API.js:227:18)
    2023-12-29T10:35:52: at Connection. (/opt/loxberry/bin/plugins/lox2mqtt/node_modules/node-lox-ws-api/lib/API.js:123:14)
    2023-12-29T10:35:52: at Connection.emit (events.js:314:20)​
    I removed the Plugin and reinstalled it, tried with manual entry of the Miniserver User credentials, but the Plugin keeps staying in this mode.
    • nufke
      • 10.11.2018
      • 63
      #32
      Looks like an issue in the underlying websocket library. Can you check the values heatPeriodStart and coolPeriodStart in your loxapp3.json file? Perhaps these are empty, which might cause an issue. Even if you do not use these dates (seems deprecated by Loxone), just add a dummy date in your LoxoneConfig.
      Alternatively, share your loxapp3.json in a PM and I will study this further.
      • nufke
        • 10.11.2018
        • 63
        #33
        Quick update of all users of Lox2MQTT. I released v0.6.3 with the following updates:
        • I removed the dependency to the external library node-lox-structure-file, as it caused multiple issues in the past (as reported in this forum). This external library is not well maintained, and thus not following the changes made in the latest Loxone releases. As we do not need to manage a full structure dataset, we could drop this dependency.
        • This release offers the option to enable/disable a Miniserver from Lox2MQTT communication. Especially in Gateway-Client configurations, the main communication will happen via the Gateway Miniserver, and there is no need to establish a separate communication for each Client.
        • Meininger
          • 30.11.2015
          • 60
          #34
          Hello,
          I think in version 0.7.0 there is a problem with the topic name, which is no longer taken from the plugin settings and is always "loxone". Or I'm doing something wrong, but I've only had the problem since the update.
          Greetings Sascha
          • nufke
            • 10.11.2018
            • 63
            #35
            Thanks for reporting the issue. Fixed in v0.7.1
            • poklutom
              • 24.11.2020
              • 13
              #36
              Hello,
              I am using LoxBerry V3.0.0.6 and Lox2MQTT v0.7.1. The connection is working just after plugin installation. After Loxberry restart the status plugin is: "Lox2MQTT not running".
              I am running Miniserver V2 (is not running on port 80) and V1 is running as Gateway-Client.
              The value of "heatPeriodStart" = "10-01" and "coolPeriodStart" = "05-01",
              • nufke
                • 10.11.2018
                • 63
                #37
                I need more info to assess what the issue is. Please enable debug at the plugin install page and share the results. Thanks.
                • poklutom
                  • 24.11.2020
                  • 13
                  #38
                  I set debug level at the plugin install page but when I go to plugin Logfiles tab, it is empty. I tried also restart Loxberry. If you need any specific log file, send me the name and location and I will try to find it.
                  • nufke
                    • 10.11.2018
                    • 63
                    #39
                    If the log page is empty, the might be no log file, which is a bit strange. Please check if a log is located at /opt/loxberry/log/plugins/lox2mqtt
                    You can also check the config file in /opt/loxberry/config/plugins/lox2mqtt and see if both miniservers are listed.
                    Alternatively, login to your loxberry via ssh and start the plugin stand-alone
                    cd /opt/loxberry/bin/plugins/lox2mqtt
                    node lox2mqtt.js
                    Report the error if any.
                    • poklutom
                      • 24.11.2020
                      • 13
                      #40
                      First of all thank you for all your effort with this really helpfull plugin and all your support.
                      The folder is empty.
                      I tried in menatime to uninstall the plugin and install again and before restart I set DEBUG level. Before the restart I have seen logfiles at "Logfiles" tab. But the tab and folder are empty after Loxberry restart.
                      There is only main miniserver. But I din't have configured 2nd miniserver at all in LoxBerry so I expect it sohuld not be any problem.
                      "miniserver": {
                      "1": {
                      "enabled": true,
                      "mqtt_topic_ms": "loxone",
                      "publish_structure": false,
                      "publish_states": false,
                      "retain_message": false,
                      "subscribe": false,
                      "other_user": false,
                      "user": null,
                      "pass": null
                      Force starting​
                      The plugin is started by node lox2mqqt.js
                      Log started by:
                      INFO: Start logger
                      INFO: Lox2MQTT undefined started
                      INFO: Lox2MQTT - register Miniserver 1
                      INFO: WebSocketAPI 10.0.1.55:1234 - try to connect to Miniserver as user admin...
                      INFO: MQTT Client - connect: {"cmd":"connack","retain":false,"qos":0,"dup":f als e,"length":2,"topic":null,"payload":null,"sessio nP resent":false,"returnCode":0}
                      INFO: WebSocketAPI 10.0.1.55:1234 - connect
                      DEBUG: WebSocketAPI 10.0.1.55:1234 - send message: jdev/sys/keyexchang​....................................
                      Any idea why is not started automatically?
                      • nufke
                        • 10.11.2018
                        • 63
                        #41
                        This is a bit strange...not sure why the version is not seen. Looks like a nodeJS package installation issue.
                        Can you run the node package manager at the same bin location to see if all nodeJS packages are available and properly installed?
                        npm i
                        npm list
                        you should see something like this:
                        ​lox2mqtt@0.7.1 /opt/loxberry/bin/plugins/lox2mqtt
                        ├── base-64@1.0.0
                        ├── loxberry-logger@0.0.1 (git+ssh://git@github.com/nufke/loxberry-logger.git#9d    ...)
                        ├── mqtt@4.3.8
                        ├── node-lox-ws-api@0.4.5-bugfix (git+ssh://git@github.com/codm/node-lox-ws-api. ...)
                        ├── pm2@5.3.1
                        └── vows@0.8.3
                        You can also try to start the plugin using the process manager PM2 (this is normally done at startup)
                        npm run start
                        > lox2mqtt@0.7.1 start
                        > PM2_HOME=$(pwd)/.pm2 pm2 start ecosystem.custom.config.js --watch
                        [PM2] Applying action restartProcessId on app [Lox2MQTT](ids: [ 0 ])
                        [PM2] [Lox2MQTT](0) ✓
                        │ id │ name │ mode │ ↺ │ status │ cpu │ memory │
                        │ 0 │ Lox2MQTT │ fork │ 44 │ online │ 0% │ 14.9mb │
                        • poklutom
                          • 24.11.2020
                          • 13
                          #42
                          npm i
                          added 3 packages, and audited 232 packages in 4s
                          22 packages are looking for funding
                            run `npm fund` for details
                          found 0 vulnerabilities
                          npm list
                          ├── base-64@1.0.0
                          ├── loxberry-logger@0.0.1 (git+ssh://git@github.com/nufke/loxberry-logger.git#9d1a7f0c29165caf851e4bc6d96673d823523329)
                          ├── mqtt@4.3.8
                          ├── node-lox-ws-api@0.4.5-bugfix (git+ssh://git@github.com/codm/node-lox-ws-api.git#598344a2259fef59a695dfd2494982d5cc52e9b9)
                          ├── pm2@5.3.1
                          └── vows@0.8.3
                          npm run start
                          [PM2] Spawning PM2 daemon with pm2_home=/opt/loxberry/bin/plugins/lox2mqtt/.pm2
                          [PM2] PM2 Successfully daemonized
                          [PM2][WARN] Applications Lox2MQTT not running, starting...
                          [PM2] App [Lox2MQTT] launched (1 instances)
                          │ id │ name        │ namespace   │ version │ mode    │ pid      │ uptime │ ↺    │ status    │ cpu      │ mem      │ user     │ watching │
                          │ 0  │ Lox2MQTT    │ default     │ 0.7.1   │ fork    │ 12328    │ 0s     │ 0    │ online    │ 0%       │ 37.1mb   │ loxberry │ enabled  │
                          Logfile:
                          2024-02-19T22:07:50: INFO: Start logger
                          2024-02-19T22:07:50: INFO: Lox2MQTT 0.7.1 started
                          2024-02-19T22:07:50: INFO: Lox2MQTT - register Miniserver 1​
                          • nufke
                            • 10.11.2018
                            • 63
                            #43
                            this looks good, lox2mqtt keeps running?
                            • poklutom
                              • 24.11.2020
                              • 13
                              #44
                              YES
                              Any idea about the reason?
                              I have fresh LoxBerry installation.
                              The list of installed plugins: Docker, FOSHKplugin, Lox2MQQT, Miniserver Backup, RPi-Monitor, Weather 4 Loxone
                              • nufke
                                • 10.11.2018
                                • 63
                                #45
                                Not sure what caused this, I suspect a combination of topics. I will try to reproduce the issue using a fresh DietPi + LoxBerry image on a VM.
                                Which platform/OS are you using?
