Plugin: LoxBerry Poolex (Poolstar) Wärmepumpen
Nein, "running" betrifft das Plugin. Wenn die Bridge läuft, ist der Wert 1, sonst 0. "hvac_mode" ist quasi Power: 1 heisst WP ist eingeschaltet, 0 heisst "aus". Den kannst Du auch schreiben.🇺🇦 Hilfe für die Menschen der Ukraine: https://www.loxforum.com/forum/proje...Cr-die-ukraine
Hello again. Thank you for your reaction and answer.
I would like to ask you if is possible to add another model of pool heat pump to your plugin. I hope it can be hepful for another users of Fairland pool heating pump.
I already prepared a "device file" (please find attached) called fairland.json.
I tried to get a status with values and this is a result of data:
Polling local devices... ................. - [On] - DPS: {'1': True, '102': 23, '103': True, '104': 100, '105': 'warm', '106': 31, '107': 18, '108': 40, '115': 0, '116': 0, '117': True}
Thank you for your help
Have a nice weekend
MarekAngehängte DateienKommentar
I can add this one. But I currently working on a Tuya Plugin which supports all kind of devices and grep this "mapping/translation" files by it's own from the Tuya servers. This new plugin will work with all tuya devices.🇺🇦 Hilfe für die Menschen der Ukraine: https://www.loxforum.com/forum/proje...Cr-die-ukraine
This is great news!!! :-) Thank you again very much for your work!
Any idea when your new plugin will be available?
If it's not such a big and difficult job for you, I would appreciate if you add the Fairland model to your existing plugin.
I would like to use this functionality for this summer season.
Another option (if you would be so kind) is to instruct me how to add manyually (myself) to your current version. I tried that, but didn't know what (which files) needed to be edited.
Thank you very much
MarekKommentar
Hallo!
Diese Bridge ist echt genial!! Danke dafür...
Vlt ist diese Erkenntnisse auch andere auch interessant, oder jemand hatte dieses Verhalten schon...
1. Zeit zwischen Loxone und MQTT berücksichtigen
Die Bridge läuft... (siehe violette Markierung)
Der Timestamp im MQTT ist aktueller als der Wert in der Loxone...
In meinem Fall sieht man den Fehler in der Loxone (rot- Wert 256) und im MQTT ist der Wert 0 (kein Fehler)
Unterschied bei der Aktualisierung 487 Sekunden --> bischen mehr als 8min.
Kann man eine Aktualisierung irgendwie anstoßen? (Warum: die WP läuft schon, und die Loxone versucht noch den Fehler zu beheben)
2. Was der Wert poolex_set_command macht, ist mir noch nicht ganz klar.
3. Wann läuft die Poolex Silverline FI?
Ich glaub wenn poolex_status_dps_hvac##_mode = 1 & kein Fehler vorhanden ist...
beste Grüße FRECHKommentar
Die Aktualisierung erfolgt sofort und permanent ohne Verzögerung. Aber nur, wenn sich eine erst ändert. Daher geht es auch nicht das anzustoßen.
zu 2: an das topic werden die Kommandos gesendet.
zu 3: korrekt🇺🇦 Hilfe für die Menschen der Ukraine: https://www.loxforum.com/forum/proje...Cr-die-ukraine
Ich starte meinen Loxberry täglich neu.
Beim Neustarten startet bei mir die Bridge nicht automatisch. (Ich denke, dass ist so gedacht.)
Kann man den Neustart durch einen Befehl von der Loxone anstossen?
Danke und beste GrüßeZuletzt geändert von FRECH; 27.05.2023, 23:46.Kommentar
Felda1974 Please try the latest Master: https://github.com/mschlenstedt/LoxB...heads/main.zip
You should be able to select Fairland in the Type Dropdown. Can you please give me the exact Type/serie of your Fairland for which the JSON is valid for? Thanks.🇺🇦 Hilfe für die Menschen der Ukraine: https://www.loxforum.com/forum/proje...Cr-die-ukraine
@Prof.Mobilux Thank you!!! :-) I succesully instaled.
I used "JSON definition" from your recommended source: https://github.com/make-all/tuya-loc..._heatpump.yaml
In MQTT gateway I can see a combination of names and raw. - see a printscreen.
It looks correct.
As I wrote you before, I use Fairland Rapid Inverter RIC33 - IPHCR33.
But it will be the same for a whole serie.
Marek
Ok, Perfect. The status_raw shows the ID while status should show the mapped name.🇺🇦 Hilfe für die Menschen der Ukraine: https://www.loxforum.com/forum/proje...Cr-die-ukraine
Damit sollte nach Reboot die Bridge automatisch gestartet werden.🇺🇦 Hilfe für die Menschen der Ukraine: https://www.loxforum.com/forum/proje...Cr-die-ukraine
Was mir noch aufgefallen ist...
In der Loxone wird angezeigt, dass die Bridge läuft, obwohl sie nicht läuft: (Grundsätzlich hat das funktioniert. Ich werde das mit der neuen Version weiter beobachten.)
Ist das vlt auch bei wem anderen so?
Danke und LG
Musst Du mal beobachten - bei mir funktioniert es:
Servus Prof.Mobilux!
Ich hätte nun auch noch eine Frage (oder zwei):#
Kann ich die Bridge auch via Loxone neu starten? Ich schalte die Poolex mittels Energiemanager per Schütz ein/aus (da es da dein Plugin noch nicht gab), da nimmt sich die Bridge immer das Leben und deswegen würde ich sie mit dem EM mitstarten. Oder sollte sie ohnehin ein Keep-alive haben (wäre natürlich noch schöner)?
Und werden die Fehlermeldungen nur im Fehlerfall mitgesendet? Bei dir sieht man Error (9) auf 0. Bei mir gibt es den nicht.
Vielen Dank nochmal,
PatrickKommentar
