LoxBerry Plugin SqueezeLite
    • 11217
    Soweit ich weiß, basiert der BT-Treiber auf PulseAudio, d.h. wenn es gehen würde, müsstest du pulse als Ausgang wählen.
    Da ich mich bisher aber nur theoretisch damit befasst habe, und nicht selbst probiert, kann ich dir leider auch nicht weiterhelfen. Vielleicht hat das schon jemand anderer probiert.
    • Smotek7
      • 09.12.2017
      • 16
      Hello Christian,
      I will try to activate the GPIO in Squeezelite.
      If I enter GPIO for zone and restart in LMS I lose zone.
      What is the right process and setup?
      I do not speak German, I use a translator.
      Well thank you
        • 11217
        after you have enabled "Alternative binaries", you have to reboot LoxBerry.
        Then, you can enable the GPIOs.
        Is this working?
        Otherwise, I have to check that on my Pi.
        Regards, Christian
        • Smotek7
          • 09.12.2017
          • 16
          Hello,
          I tested it again.
          I have active alternatives binaries and reboot.
          If I select GPIO and save it does not work.
          But if I do reboot again, the LMS zone is lost and it does not even work from the UDP loxone.
          If the GPIO off and rebbot zone starts to work.
          I have installed version 0.4.1
          Thanks for help
            • 11217
            I saw in the log, that squeezelite did not start anymore with GPIO:
            Unable to determine hardware version. I see: Hardware    : BCM2835
             - expecting BCM2708 or BCM2709.
            If this is a genuine Raspberry Pi then please report this
            to projects@drogon.net. If this is not a Raspberry Pi then you
            are on your own as wiringPi is designed to support the
            Raspberry Pi ONLY.
            Prof.Mobilux meanwhile has pushed a new Squeezelite binary, and this one seems to work.
            Could you try this download: https://github.com/christianTF/LoxBe...hive/0.4.2.zip
            Install, reboot, and try again!
            Christian
            • Smotek7
              • 09.12.2017
              • 16
              0.4.2 The problem with the lost zone has been resolved.
              The second problem was with me.
              I did not use the "Speichern und neu starten" but "Speichern".
              Thank you all works
              What is the right update plugin procedure? Do not lose my settings?
                • 11217
                No, simply go to the Plugins page and install the new version. The settings are saved.
                • Smotek7
                  • 09.12.2017
                  • 16
                  Maybe I did something wrong, the settings were lost.
                  I had to enter again.
                    • 11217
                    Thanks for the info. Possibly there is a bug.
                      • 11217
                      Hi Smotek7
                      indeed, there was a bug in backing up the config. I have fixed it and updated the archive. As nothing else changed, you don't need to update again.
                      Regards, Christian
                      • Smotek7
                        • 09.12.2017
                        • 16
                        I did update again and the data was not deleted.
                        It is OK.
                        Thank you
                        • paddler
                          • 01.01.2018
                          • 5
                          Guten Abend,
                          ich versuche mit dem Squezzelite Plugin eine sinnvolle Verbindung zwischen meinem Miniserver und meinem Squeezeboxen herzustellen.
                          Mittlerweile habe ich die das Plugin soweit am Laufen, bekomme bei "Eingänge und Ausgänge" aber leider ein " Fehler 500 :-( Internal Server Error"
                          Apache Error Logfiles sind leer. Verwende die 0.4.2.
                          Jemand einen Tipp?
                          Danke und Gruß
                          Patrick
                            • 11217
                            Hallo Patrick,
                            das Apache Log liegt unter /opt/loxberry/system/apache2/error.log
                            Bist du auf einem Raspberry?
                            • paddler
                              • 01.01.2018
                              • 5
                              Hi Christian,
                              ok, ich hatte im System Logs Verzeichnis gesucht.
                              Unter /opt/loxberry/system/apache2/ gibt es leider kein error.log (siehe Screen).
                              Ich bin auf Eurem Hyper-V Image unterwegs. Loxberry hat 0.2.3.
                              Danke für Deine Hilfe!
                              Patrick
                              • paddler
                                paddler kommentierte
                                Ich lese gerade Eure Neujahres Grüße.
                                Macht es für mich Sinn, einfach auf eine große neue Version von LoxBerry zu warten?
                              • 11217
                              Sorry,
                              /opt/loxberry/logs/system/apache2/error.log
                              Schau mal dort - das Plugin selbst ändert sich durch den neuen LB ja nicht.
                              Es kann auch ein Image-Problem mit HyperV sein.
