Da ich mich bisher aber nur theoretisch damit befasst habe, und nicht selbst probiert, kann ich dir leider auch nicht weiterhelfen. Vielleicht hat das schon jemand anderer probiert.
LoxBerry Plugin SqueezeLite
Soweit ich weiß, basiert der BT-Treiber auf PulseAudio, d.h. wenn es gehen würde, müsstest du pulse als Ausgang wählen.
Hilfe für die Menschen der Ukraine: https://www.loxforum.com/forum/proje...Cr-die-ukraine -
after you have enabled "Alternative binaries", you have to reboot LoxBerry.
Then, you can enable the GPIOs.
Is this working?
Otherwise, I have to check that on my Pi.
Regards, ChristianHilfe für die Menschen der Ukraine: https://www.loxforum.com/forum/proje...Cr-die-ukraineKommentar
Hello,
I tested it again.
I have active alternatives binaries and reboot.
If I select GPIO and save it does not work.
But if I do reboot again, the LMS zone is lost and it does not even work from the UDP loxone.
If the GPIO off and rebbot zone starts to work.
I have installed version 0.4.1
Thanks for help3 BilderKommentar
I saw in the log, that squeezelite did not start anymore with GPIO:
Code:Unable to determine hardware version. I see: Hardware : BCM2835 - expecting BCM2708 or BCM2709. If this is a genuine Raspberry Pi then please report this to projects@drogon.net. If this is not a Raspberry Pi then you are on your own as wiringPi is designed to support the Raspberry Pi ONLY.
Could you try this download: https://github.com/christianTF/LoxBe...hive/0.4.2.zip
Install, reboot, and try again!
0.4.2 The problem with the lost zone has been resolved.
The second problem was with me.
I did not use the "Speichern und neu starten" but "Speichern".
Thank you all works
What is the right update plugin procedure? Do not lose my settings?Kommentar
No, simply go to the Plugins page and install the new version. The settings are saved.Hilfe für die Menschen der Ukraine: https://www.loxforum.com/forum/proje...Cr-die-ukraineKommentar
Thanks for the info. Possibly there is a bug.Hilfe für die Menschen der Ukraine: https://www.loxforum.com/forum/proje...Cr-die-ukraineKommentar
Hi Smotek7
indeed, there was a bug in backing up the config. I have fixed it and updated the archive. As nothing else changed, you don't need to update again.
Guten Abend,
ich versuche mit dem Squezzelite Plugin eine sinnvolle Verbindung zwischen meinem Miniserver und meinem Squeezeboxen herzustellen.
Mittlerweile habe ich die das Plugin soweit am Laufen, bekomme bei "Eingänge und Ausgänge" aber leider ein " Fehler 500 :-( Internal Server Error"
Apache Error Logfiles sind leer. Verwende die 0.4.2.
Jemand einen Tipp?
Danke und Gruß
PatrickKommentar
Hallo Patrick,
das Apache Log liegt unter /opt/loxberry/system/apache2/error.log
Bist du auf einem Raspberry?
Hi Christian,
ok, ich hatte im System Logs Verzeichnis gesucht.
Unter /opt/loxberry/system/apache2/ gibt es leider kein error.log (siehe Screen).
Ich bin auf Eurem Hyper-V Image unterwegs. Loxberry hat 0.2.3.
Danke für Deine Hilfe!
Patrick
1 BildKommentar
Sorry,
/opt/loxberry/logs/system/apache2/error.log
Schau mal dort - das Plugin selbst ändert sich durch den neuen LB ja nicht.
Es kann auch ein Image-Problem mit HyperV sein.Hilfe für die Menschen der Ukraine: https://www.loxforum.com/forum/proje...Cr-die-ukraineKommentar
