  • ager
    • 15.11.2017
    • 48
    Hi guys. I have LoxBerry V1.2.5.5 and Sonos4lox: v3.5.5 all working great thanks for great job.
    Is there any way how to use SD card of loxberry or some USB key (USB storage) in Raspi3 loxberry as a storage for me mp3 songs for Sonos playlist please?
    I have tried to save them in loxberry /opt/loxberry/data/plugins/sonos4lox/tts/mp3 but if I tried create sonos Playlist, Sonos have no permission to acces this data....
    I would like to somewhere (not in PC and I dont have NAS currently) save some of my mp3 songs and want to play them in Sonos by push button.
    many thanks for help
    • Liver_64
      Liver_64 kommentierte
      Upgrade to newest Version, Jump to Plugin and Save, and then select your storage from the list
    • ager
      ager kommentierte
      @Scrati
      Yes of course I have added but there is no way to add folders from loxberry. Or I am doing something wrong?
      @Liver_64
      I did upgrade to 3.59 but you mean now I can add music library folder in sonos to /opt/loxberry/data/plugins/sonos4lox/tts/mp3 and from there to add songs to sonos playlist please?
    • Liver_64
      You need to add the loxberry folder to Sonos, initiate an new screening and then they should be there. User must be loxberry and PW
  • JeeyBee
    • 13.01.2019
    • 30
    Ich habe nun auf Debug-Level auch keine Fehler feststellen können. Habe denselben Effekt wie mbednar. Alle mp3-Files sind 36B und nicht abspielbar. Gong ertönt jeweils, aber TTS werden nicht abgespielt (Uhr, Wetter sowie alle dynamisch erzeugten Texte). :-( Kann ich irgendwie wieder auf die Version 3.5.8?
    • Liver_64
      du hast eine PN
    • JeeyBee
      JeeyBee kommentierte
      Für alle, welche dasselbe Problem haben wie ich. Oliver hat sich das Problem bei mir angeschaut, hat was mit der VoiceRSS-Anbindung zu tun. Aktueller Workaround umstellen auf "RespVoice"
  • ager
    • 15.11.2017
    • 48
    Liver_64
    I have tried to add look for pictures but access denied. User and password are correct as I am using same credential to acces webinterface of loxberry...what is wrong please?
    • Liver_64
      you do something wrong or use incorrect credentials, i have data folder added month ago and it works
    • ager
      ager kommentierte
      I have tried now to open new browser (firefox) because I am using chrome, and fill in IP address of loxberry, it ask me for credential and I fill in and login to loxberry webpage so credential is ok. So I dont understand what I am doing wrong? How to find out please?
    • Liver_64
      try the same in Sonos App using IP
  • ager
    • 15.11.2017
    • 48
    I have tried by phone in sonos app by IP same result look for picture
    • Liver_64
      Notepadd++ is perfect. You'll find "smb.conf" in loxberry\system\samba, scroll down to [loxberry] and add ntlm auth = yes and to [plugindata] as well. Once saved restart your LoxBerry and try again
      It‘s the smb.conf you found and yes you have to add this line to this file after client max protocol
    • Pilaarbijter
      Pilaarbijter kommentierte
      I'm having the same problem as Ager with only one difference: i can't add the loxberry folder from the sonos app (windows) because it's not showing up. I allready enabled a network share (via loxberry's network disk) to my loxberry's ip-adress, so am I missing something?
      Zuletzt geändert von Pilaarbijter; 29.09.2021, 09:36.
  • JeeyBee
    • 13.01.2019
    • 30
    Danke nochmals!
    • Liver_64
      • 07.09.2015
      • 599
      Es gibt derzeit wohl bei dem ein oder anderen Probleme mit VoiceRSS. Das Problem ist der API key der anscheinend irgendwann abläuft. Lösung: auf VoiceRSS einloggen und einen neuen API key generieren.
      • GünWün
        • 28.04.2016
        • 272
        Hallöchen zusammen,
        ich habe folgendes Problem mit dem PlugIn
        Version Sonos4lox: v3.5.9
        LoxBerry V1.4.0.3
        Ich habe einen virtuellen Eingang angelegt als "Taste"
        und einen Taster als Objekttyp Taster.
        Als Befehl wird
        /plugins/sonos4lox/index.php?zone=kueche&action=nextradio&volume=10
        übergeben.
        Funktioniert leider nicht ganz, da der Befehl doppelt verschickt wird.
        In meinem Fall sind 2 Sender als Favorit hinterlegt. WDR2 und Radio Hochstift.
        Beispiel:
        WDR2 läuft.
        ich drücke in der LoxoneApp auf den Taster
        es wird kurz Radio Hochstift angespielt und dann wieder WDR2
        Wenn Radio Hochstift zuerst dran ist das gleiche Spiel - kurz WDR2 - dann wieder Radio Hochstift.
        Setze ich den Befehl über den Browser ab dann ist alles OK.
        Jemand eine Idee?
        Danke schön
        1x MiniServer, 12x Touch Tree, 24x Stellantrieb Tree, 3x Relay Extension, 1x Dimmer Extension, 2x Extension
        1. Test im Haus 21.09.2017, geplanter Einzug 07.10
        Rasperry Pi 3 mit Loxberry für Sonos und Weatherground im Test
        Endlich auch mit Internet :-) - hat ja nur 10 Monate gedauert
        • Liver_64
          siehe Troubleshooting im Wiki hinsichtlich Befehle 2x
        • GünWün
          GünWün kommentierte
          Hi Liver_64 es ist ja keine T2S. Es geht um nextradio.
        • Liver_64
          richtig, aber es geht um Befehle die 2x gesendet werden weil einer der beiden tick Boxen falsch ist. Hast du es kontrolliert bei dir?
          Ist bei mir auf 3 LB's nicht reproduzierbar, ansonsten ist mir auch kein anderer User bekannt der Probleme hat
      • lighthouse123456
        • 28.01.2016
        • 48
        Hallo sonos4loxone Experten….
        Ich bin seit 4 Wochen daran und versuche vergebens das Plugin zum Laufen zu bringen. Ich habe alles getestet und probiert aber ohne Erfolg: @ Olli: ich habe die komplette Anleitung studiert und auch die Wiki FAQ / Troubleshooting durchgelesen, doch ohne Erfolg
        Vorab mein System:
        LoxBerry Version: v3.5.1
        Sonos Version: 10.0.1
        genutzte Syntax: ? (hier weiß ich nicht was gefragt ist)
        Loxone Config:7.4.4.14
        Keine Sonos Bridge
        Alle Player (play 1) ohne Gruppe : Kueche / Wohnzimmer / Wohnzimmer 2
        IP Adresse/port MServer: 192.168.0.77/80
        IP Adresse/Port Loxberry: 192.168.0.11/80
        UDP Port im Plugin : 6060 (warum 6060?, Da Olli das Beispiel genannt hat, ich habe noch keine Ahnung warum J )
        Erstes Ziel ist es, die Sonos Befehle über die Config (APP) steuern zu können. Nach Erfolg von Step 1 möchte ich TTS implementieren.
        Mein gescheitertes Vorhaben: wenn ich den Virtuellen Eingang in der App ansteure, dann soll der play 1 in der Küche play / pause mache.
        Befehl laut Wiki: plugins/sonos4lox/index.php/?zone=kueche&action=toggle
        Status Quo:
        Befehl über den Browser funktioniert
        http://192.168.0.11/ plugins/sonos4lox/index.php/?zone=kueche&action=toggle
        Jedoch mit dieser Einstellung in der Config funktioniert es nicht über die APP
        • Eingerichtet des Virtuellen Eingang
        Virtuellen Eingang als Digitaleingang (siehe Bild)Befehle ein: plugins/sonos4lox/index.php/?zone=kueche&action=toggle
        Als Digitalausgang verwenden: kein Hacken
        • Kein UDP Log in der Config (alles Leer)
        Fragen:
        1) Olli schrieb, dass „1/ MS ist mit Standardport 80 konfiguriert, ihre sendet UDP an 6060 --> Portforwarding Rule = UDP 6060 and 80“
        -> habe ich so in der Fritzbox eingestellt:
Ansichten: 993
Größe: 33,2 KB
        Ist das korrekt?
        2) Welche Einstellung ist noch falsch/fehlt, dass ich per Config die Player ansteuern kann?
        3) Muss ich ein virtuellen UPD Eingang anlegen?
        Danke für Eure Unterstützung
        @ Olli, ich hoffe dass Du mir helfen kannst ...
        Viele Grüße vom Bodensee
        Olaf
Ansichten: 518
Größe: 139,4 KB
ID: 190112Klicke auf die Grafik für eine vergrößerte Ansicht
Ansichten: 537
Größe: 194,7 KB
ID: 190110Klicke auf die Grafik für eine vergrößerte Ansicht
Ansichten: 543
Größe: 67,0 KB
ID: 190109Klicke auf die Grafik für eine vergrößerte Ansicht
Ansichten: 524
Größe: 22,9 KB
        • lighthouse123456
          lighthouse123456 kommentierte
          danke für die Schnelle Antwort.. Doch "POST" birngt auch keinen Erfolg :-(
          Zuletzt geändert von lighthouse123456; 12.02.2019, 22:05.
        • Mischiback
          Mischiback kommentierte
          Habe bei mir UDP gar nicht konfiguriert, daran kann es eigentlich nicht liegen. Schau nochmal genau nach, ob sich irgendwo ein Leerzeichen versteckt, ein "/" fehlt oder mach den Haken bei "Digitalausgang verwenden" wieder rein. Sorry, aber ich musste mit den Einstellungen auch etwas "spielen" bis es funktioniert hat. Warum auch immer scheint es bei den Meisten auch anders zu funktionieren.. Bei mir war es das "POST" Problem.
        • Liver_64
          du hast Post. Abgesehen davon kann man mit einem Eingang nichts steuern, sondern NUR mit virtuellen Ausgängen, und die müssen digital sein, es sei denn du willst einen Wert aus dem MS mitansagen lassen
      • Clubsport
        • 11.01.2018
        • 602
        Hi Olaf,
        dann sollte dir doch auch auffallen, dass wenn du die IP deines Loxberry nimmst, und den Befehl direkt dahinter tippen würdest, da steht:
        .....11plugins....
        Und bei deinem funktionierenden Browser Befehl:
        .....11/plugins....
        Beginne am Besten jeden Befehl mit /
        Grüße, Martin
        • lighthouse123456
          Es funktioiert: Folgendes geändert: "/" eingefügt + Digital gesetzt!
          Fehlern von Anderen finden ist meisten einfacher, als den Eigenen zu finden ! DANKE EUCH
        • Clubsport
          Clubsport kommentierte
          Ja das stimmt Freut mich!
      • andineu
        • 16.09.2015
        • 29
        Hi Zusammen
        Ich habe ein Frage zum sonos plugin
        hab soweit alles installiert und kann auch play pause laut leise Funktionen verwenden
        http://192.168.2.45/plugins/sonos4lo...n&action=pause
        Die Text to speach Funktion geht aber nicht. Ich habe im explorer den Befehl eingeben.
        http://192.168.2.45/plugins/sonos4lo...allo&volume=25
        leider ohne Erfolg ...
        auch wenn ich den Play Befehl danach ausführe höre ich nix .....
        vielen dank führ eure Hilfe
        Ich verwende Voice RSS Key habe ich und account ist aktive ..
        Gruss Andi
        Zuletzt geändert von andineu; 12.02.2019, 22:48.
      • Liver_64
        • 07.09.2015
        • 599
        gewöhnt euch doch bitte bitte endlich mal an ins Log zu schauen bevor man was postet! Mind. die Hälfte aller Posts hier sind hinfällig wenn man da mal reinschaut
        • Liver_64
          • 07.09.2015
          • 599
          Korrektur zur Wiederherstellung der Gruppen nach T2S. Die Datei runterladen und als "Restore_T2S.php" in webfrontend/html/plugins/sonos4lox kopieren.
          • andineu
            • 16.09.2015
            • 29
            Hi Liver Danke für das Feedback.
            Ich hab in dem log geschaut aber bin nicht schal daraus geworden.
            Ich hab ein paar Punkte gefunden wo Fehler dran stand und auch Debug ....Benutze Loxberry erst seit kurzem daher noch nicht so fit
            kannst du mir bitte einen tip geben was ich posten soll dann mache ich das gleich nachher. Ich schaue gleich mal noch ob ich was finde wie die Log Funktion zu nuten is.
            Vielen Dank Gruss Andi
            • Liver_64
              im tab Logfile Aktueller Log-Level auf "Debug" stellen, Befehl(e) ausführen und anschließend auf das letzte LogFile der Gruppe"Gruppe 'Sonos PHP'" klicken damit es sich in einem neuen Fenster öffnet, unten rechts ist einen Button "Download" und dann schickst du es per PN oder postest es hier
          • andineu
            • 16.09.2015
            • 29
            Super mache ich
            • Seebach11
              • 24.09.2018
              • 30
              Hallo zusammen. Handelt es sich hier um einen Bug oder ist das nur bei mir so: Wenn ich eine MP3 als Groupmessage abspiele, geht die Lautstärke nur auf derjenigen Zone wieder auf den ursprünglichen Zustand zurück, die als erste nach "member=" aufgeführt ist. Also im nachfolgenden Beispiel wäre das die Zone "essen". Alle anderen Zonen bleiben auf der höheren TS2Vol-Lautstärke stehen. Beispiel: http://192.168.1.129/plugins/sonos4l...be&messageid=1
              • Liver_64
                Geht allen so, Änderung kommt demnächst, muss nur noch ein paar Tests machen
                Zuletzt geändert von Liver_64; 13.02.2019, 21:20.
