[Wunderground4Loxone] Ankündigung neues Major Release 4.0
    • 4744
    #136
    Zitat von beantje
    yes, and dont see the info from the weather station i choose, ( i toke some differt one aswel and stil no info )
    Please check that you set "Wetterdaten abrufen:" to "An" and also "Cloud Weather Emulator:" to "An". It's really time for an english plugin translation! ;-)
    You can also check that you have current data by clicking on "Vorschau" at the bottom of the page. That should show the current weather conditions on a webpage.
      It's al set to an,
      If I click vorschau i Just get The info from ure last german info not my own,
      And its old its from 21/04/ So it seems likes it dont update from underground,
      But i get no error on underground.
      Very strange!,
      Verstuurd vanaf mijn SM-G935F met Tapatalk
        • 4744
        #138
        Please check the logfile and post it here (use the code tag from the forum):
        http://IP-LOXBERRY/admin/system/tools/logfile.cgi?logfile=plugins/wu4lox/wu4lox.log&header=html&format=html
        (Note: please xxxx your Wunderground API key here)
          2017-07-04 21:50:01 INFO: Starting /opt/loxberry/system/cron/cron.10min/wu4lox Version 3.0.4
          2017-07-04 21:50:01 INFO: Fetching Data for 51.139923,3.336645
          2017-07-04 21:50:01 INFO: URL: http://api.wunderground.com/api/Xxxx...,3.336645.json
          2017-07-04 21:50:02 INFO: Saving new Data for Timestamp Tue, 04 Jul 2017 21:49:54 +0200 to database.
          2017-07-04 21:50:02 OK: Current Data and Forecasts saved successfully.
          2017-07-04 21:51:01 INFO: Starting /opt/loxberry/system/cron/cron.03min/wu4lox Version 3.0.4
          2017-07-04 21:51:01 INFO: Fetching Data for 51.139923,3.336645
          2017-07-04 21:51:01 INFO: URL: http://api.wunderground.com/api/Xxxx...,3.336645.json
          2017-07-04 21:51:02 INFO: Saving new Data for Timestamp Tue, 04 Jul 2017 21:50:41 +0200 to database.
          2017-07-04 21:51:02 OK: Current Data and Forecasts saved successfully.
          Here The fore cast
            • 4744
            #140
            Maybe there's a bug when using coordinates instead of a station name. Could you please try to use the station name: IVLAANDE16
              2017-07-05 05:45:01 INFO: Fetching Data for pws:IVLAANDE16
              2017-07-05 05:45:01 INFO: URL: http://api.wunderground.com/api/xxxx...VLAANDE16.json
              2017-07-05 05:45:01 INFO: Saving new Data for Timestamp Wed, 05 Jul 2017 05:41:51 +0200 to database.
              2017-07-05 05:45:01 OK: Current Data and
              Stil The same,
              This is strange!
                • 4744
                #142
                Strange... Maybe a misspelled API key? Please try to open the URL in your browser. Do you get any data?
                  Getting data...
                    • 4744
                    #144
                    I just made a clean loxberry installation, installed the plugin and tested your weather station. Works without problems. I don't know what the problem is with your installation. You may could check if all the internal database files exist in /var/run/shm/wu4lox. You can use the Windows Explorer or ssh to check this. The files a ASCII Textfiles, so you can open them with a standard text editor. You should see the following files in that folder: current.dat dailyforecast.dat hourlyforecast.dat wu4lox.log
                      wel i dont have much on it so i wanted to start clean with image for vmware, but now i dont get network to work so i have to fix this first... thanks for ure help
                        I GOT iT BACK WORKING, dont know how... i changed 3min to 5min and added a folder EN in map templates,
                        Zuletzt geändert von Gast; 08.07.2017, 11:56.
                        • StoRmtec
                          • 348
                          #147
                          Werden die Sonnestrahldaten auch von Wunderground abgerufen? Weil bei mir steht immer 0-20%
                            • 6318
                            #148
                            Da stellt sich erst einmal die Frage, ob die von Dir ausgewählte Station überhaupt diese Werte bereitstellt.
                            • StoRmtec
                              StoRmtec kommentierte
                              Das kommt drauf an LUX und UV kann meine diese werden auch in Wunderground angezeigt
                            • 4744
                            #149
                            Lux reicht nicht - das ist nur die Helligkeit. Du benötigst eine Station, die die Globalstrahlung in W/m² misst. Auf Wunderground wird das als "Solar" bezeichnet, z. B. hier: https://www.wunderground.com/persona...ID=ISACHSEN394
                            Wenn dort bei Wunderground nichts steht, dann ist der Wert 0 und steht bei "0-20%". Wobei ich mal nachschauen muss, wie ich überhaupt die Umrechnung von W/m² auf % mache. Vielleicht fehlt da auch noch etwas. Aber Fakt ist: Du brauchst die Globalstrahlung, sonst geht es nicht.
                            • StoRmtec
                              Also das übermittelt meine auch IOBERSTE144 wäre meine Station
                              Du hast ja auch eine WH2600: Die übermittelt die Globalstrahlung (über die große Solarzelle oben). Dann muss ich mal schauen ob da etwas mit der Umrechnung zwischen W/m² und % nicht hinhaut., Ich melde mich.
                          • ckerfurt
                            • 07.11.2016
                            • 69
                            #150
                            Hallo Prof.Mobilux,
                            Wunderground 4 Loxone v4.0 Beta läuft auf Loxberry v0.2.3 fehlerfrei.
                            Danke für die Arbeit.
                            Christoph
                            🌍 cunnect.de​
