Help With Config
    Help With Config
    Hi all,
    Just so u know, i am using old i7 pc with 2 tb hard drive , and 128 gb ram Ubunto 16.04 server
    I have many problems setting up music4lox and I really need help !
    1. I am getting an error in the status page :
    • Netzwerk intern (LAN) -FAiled
    what does this means and why is it giving the error ?
    2. when i am trying to set the internal player it crashes and then i am not able to connect the server until I hard reset the computer (server ).
    Any Ideas ?
    Zuletzt geändert von Gast; 15.09.2017, 12:41.
    • 7615
    1. Network faild
    Do you have more than one nic?
    Is your Router/Gateway in a nother ip-range?
    2. difficult to say.
    Can you send me a Screenshot of your settings from the player
    Normal the player has nothing to do with the network by himself, the Player works without network.
      Hi ! Thanks for replying!
      First of all though it still does not work , I want to thank you for making this possible for the community , this is not taken for granted and very very appreciated.
      1. So, no I dont have more than one network card . this is my network Router --> Time Cpsule ( in bridge mode) , Mini server and music server are connected directly to the router
      2. my Router ip is : 10.0.0.138 , music server is 10.0.0.140 so i guess it is in the same range .
      3. when i try to use iPeng it does not recognize any players ( it does recognize the server "musik-server")
      4. Another thing which is very weird, so for example when i tried to save the name of the zone in the player settings , it crashes the server and then i can not connect to it again until i restart it manually
      Thanks in advance,
      A
      • jobe_grz
        • 116
        For the network error - could you post the output of ifconfig - just to see your network settings.
        In the case of server crashing (I assume it is not really crashing, but not reachable any more for some reason) - could you post the logfile /var/log/apache/error.log (not sure if the path is 100% correct, maybe the directory is named apache2).
        Please also post the output of ifconfig after crash.
          Hey , yeah you are right it is unreachable
          i attached both files one of the network and one of the last lines of the log file,
          One more thing, i don't see any players available in 10.0.0.140
          thanks in advance, let me know what to do next
          • jobe_grz
            jobe_grz kommentierte
            Please post the full log, not only a screenshot of the last lines. Do you have local access to the server (Monitor and keyboard to show the ifconfig output after the system is not reachable anymore?)
          currently i do not have a screen but i am going to get tomorrow one in order to post the screenshot offline.
          this is the error log file :
          thanks
            • 7615
            In the Log is shown that no config file is loaded.
            So the system don´t know about the players.
            It looks like there went something wrong at the installation.
            Go to Update an install the 0.4.9 again with klicking the update button.
            All rights of the files will set again at this process.
            • jobe_grz
              No it just complains that sq_zone_00.cfg can not be found which is referenced in line 62 in config file. But something else seems to be wrong. There are a lot of index errors, so probably a clean install could do it.
            just clicked the update after 10 sec got ERR_CONNECTION_REFUSED
              • 7615
              What else is installed on you system?
              Don´t understand what happend on your system.
              It look like the installation faild completly.
                ok , i think i will format the drive and install ubunto again and install the musik server again and see if there is any change, i will update you thanks
                  Look @ the installation process of Ubuntu 16.04 LTS and Musik-Server if you have any Errors.
                I will , though it was flawless, maybe too flawless
                  So everything was re-installed , Step by Step like the manual.
                  Still have the same problem with Network Internal failed.
                  Players do not want to start...
                  any idea ?
                  • jobe_grz
                    When you try to store an internal player config. Do you get some message like: "Die Datei sq_zone_01.cfg wurde geschrieben? Or is the system unavailable right after you click save? Or any other message when trying to save an internal player?
                • jobe_grz
                  • 116
                  Additionally you could try the following (since you do not have any player running yet):
                  edit file /var/www/settings/set_player.php and uncomment line 83:
                  // shell_exec("sudo sc player ".$zone_number_cut." stop");
                  Restart apache and try to store your internal player information.
                  Post results and log, if not working.
                  Note: This is just to see, if the stop call for the player really kills apache (which is a guess from your previous logfile). This is not a solution, but maybe points us into the right direction :-)
                    Ok , so
                    After i re insalled ubunto server & ms4lox , i still cant get the players to work, though now the system do write the cfg file ( look at attachments ) but no players seems to be running.
                    so now the "appearing problems to be" are:
                    1. getting the players to run , they just do not respond (when i press START) and therefore lms cant find any music players in network.
                    2. the other problem is that the network internal failed msg (see pic attached) is still unreseolved
                    what now ?
                    • jobe_grz
                      Players are stored now, without doing the changes above? Or did you comment out the line? Is the server still unreachable, when you change settings?
                      Zuletzt geändert von jobe_grz; 22.09.2017, 09:01.
                  • jobe_grz
                    • 116
                    The pics are nice, but do not really help to solve the problem. Since the players could be stored now, please try the following on command line:
                    sc player 1 start
                    or
                    sudo sc player 1 start
                    and post the output.
                    Please also post the output of /tmp/status.txt
                    br
                    Zuletzt geändert von jobe_grz; 22.09.2017, 08:41.
