Help With Config
  • Juras
    • 10.09.2016
    • 36
    #31
    sorry hismastersvoice
    i am runing ubuntu server (16.04.03) as virtual machine (VMware fusion). I don't use any sound card, every player is external one.
    i am able to manage devices from LMS - that is working, but i don't understand how to config lox mini server - tried to copy example config, but I dont get any responce to MS.
    Zuletzt geändert von Juras; 03.12.2017, 20:54.
      • 7328
      #32
      As often written I don't support any VM Machines.
      I don't use it so I can't help.
      ​​​​​​I think the scripts can't read the settings. The questions is is every thing willing well or is it only the failure in the webui?
      • Juras
        • 10.09.2016
        • 36
        #33
        i hope, its only problem with reading - as you can you see - MS4L can read status
        can you please help me how to setup lox MS to send and read datas to MS4L?
          • 7328
          #34
          for shure, the Status can not be read from every UPnP Device, but that is a problem from the Device not from MS4L
          The idea from MS4L wasnt to build a Music-Network with only external devices. External devices are only additional to the internal.
          What is your Problem? There is a help-site (only in german) www.music-server.net/help
          I think with google-translator you find what you need.
            @hismastersvoice,
            Oh, i thought your read it ... anyway i ll give you all the relevant info needed.
            Gygabite gax58udr3
            Intel i7 8 cores
            16 gb ddr
            Using Onboard network card
            2 usb sound cards csl - configured 48k in settings
            Onboard card disabled
              Just a note.. I have just tried installing this and had the same error..
              My problem was in /opt/music_server/soundcard_cfg/multicard/multi.cfg
              it put the channels as 8th...
              See my edit below, the players now start on an english install:
              ## MULTICARD CREATED BY MUSICSERVER4LOX
              pcm.card_0 {
                  type dmix
                  ipc_key 2047
                  slave {
                      pcm "hw:1"
                      rate 48000
                      period_time 0
                      period_size 1024
                      buffer_size 8192
                      # channels 8th
                      channels 8
                  bindings {
                      0 0
                      1 1
                      2 2
                      3 3
                      4 4
                      5 5
                      6 6
                      7 7
              pcm.multi {
                      type multi
                      slaves.a {
                              pcm "card_0"
                              channels 8
                              # channels 8th
                      bindings.0.slave a
                      bindings.0.channel 0
                      bindings.1.slave a
                      bindings.1.channel 1
                      bindings.2.slave a
                      bindings.2.channel 2
                      bindings.3.slave a
                      bindings.3.channel 3
                      bindings.4.slave a
                      bindings.4.channel 4
                      bindings.5.slave a
                      bindings.5.channel 5
                      bindings.6.slave a
                      bindings.6.channel 6
                      bindings.7.slave a
                      bindings.7.channel 7
              • nico louis
                nico louis kommentierte
                +1, i knew it was strange the '8th' channel discription but would never have found the error without this post, many thanks
