Help with Sound Card
    I have a big problem with the sound card, I used Delock 7.1 in LMS I installed 1 card 8 channel and sampling 44800. It mapped 4 stereo zones 1 Zone channel 0.1, 2 Zone channel 2.3 etc ..
    Then I released the internal player 4 zones - the room seems to work in the LMS, and I can run the Internet radio on each zone, but the sound card is only sounded from the FRONT and the other ports are deaf.
    I tried different settings and the result always the same. Besides, if I joined these two cards, so I did not get the individual zones at all but it does not work.
    Thanks for any help LMS is on the INTEL ATOM, 2 GB RAM.
    Martin
    • 7321
    Pls Screenshots from the Soundcard and Zone settings
      Screenshots from the Soundcard and Zone settings. Thank you very much
            • 7321
            Looks everything OK from setting side.
            Try to use 48000 instead of 44800
              dont forget to reboot after change!
            I tried 44100 did not help, then it occurred to me the whole server I installed and gave here the implicit language of German and took it so one of the sound cards works as = 4 stereo zones, but once I try to install 2 sound card, everything will do but zones do not start, but the first 4 of the first sound card works ..
              • 7321
              The Problem if you plug one card after each other the USB Nummbers change during the boot process.
              Always install all cards at the beginning otherwise you have to do the configuration process again.
                I tried to configure the sound cards completely again, but once the second sound card is configured, the previous zones will stop working and new zones will not work.
                Thank you for your help
                  • 7321
                  Both Soundcards are delock 7.1?
                    Yes
                      • 7321
                      Do you have the time on Sunday for a TeamViewer session?
                      I'll have a look to your Config to see what's wrong.
                        I'll be out of the house on weekend. Can I send or printscreen something?
                          • 7321
                          Make a zip of the folder opt/music_server/sq_cfg and send it via pn
                            Maybe I found the problem
                            [ 7759.304557] hid-generic 0003:0D8C:0102.0004: input,hidraw1: USB HID v1.00 Device [USB Sound Device ] on usb-0000:00:04.0-2/input3
                            [ 7872.378141] usb 2-2: cannot submit urb 0, error -28: not enough bandwidth
                            [ 7878.114187] usb 2-2: cannot submit urb 0, error -28: not enough bandwidth
                            [ 7884.548168] usb 2-2: cannot submit urb 0, error -28: not enough bandwidth
                            [ 7897.077994] usb 2-6: cannot submit urb 0, error -28: not enough bandwidth
                            [ 7908.530786] usb 2-6: cannot submit urb 0, error -28: not enough bandwidth
                            [ 7908.949790] usb 2-6: cannot submit urb 0, error -28: not enough bandwidth
                            [ 7909.350760] usb 2-6: cannot submit urb 0, error -28: not enough bandwidth
                            [ 7909.739745] usb 2-6: cannot submit urb 0, error -28: not enough bandwidth
                            [ 7910.123787] usb 2-6: cannot submit urb 0, error -28: not enough bandwidth
                            but I do not know how to remove the error, it turns out that my LMS is able to find only 1 sound card
