Problems multicards on VM
  • madito
    • 03.07.2017
    • 131
    Hi!
    I have encountered a problem when virtualizing my MS4L in a physical machine (NUC) everything works correctly, but when I try to virtualize the machine in the same hardware I have a problem when trying to activate the two sound cards (to create 8 zones).
    The cards are CSL and when I configure only 1 sound card everything seems to work correctly, when I set up the second card and modify / create the zones of the card, I get a message like this in the console:
    usb error -28 = not enough bandwidth
    If I reconfigure a single card everything goes correctly.
    The cards are detected correctly and I attached some captures.
    Thank you very much in advance.
    • 7319
    1. MS4L is not build for VM. So I don't support this.
    2. The error tells you the problem, the driver limits the bandwidth. So this is not a failure of the MS4L.
