Netzwerk intern: ...FAILED Internet: ...FAILED
  • tnagpal.
    • 11.05.2019
    • 90
    Hello,
    I am running 0.59 on a fresh install of Ubuntu LTS. Hardware is Qotom Q555G6 i5-7300U + Startech 7.1 external USB sound card.
    Three problems:
    1. I would like to use it with Spotify and have installed the Spotty plugin. When I try and authorize my account, it almost does so but then fails.
    2. The web interface seems to crash quite a bit as I will often get a reset connection.
    3. I have "Netzwerk intern failed; Internet failed" errors.
    I would appreciate any help on solving any of these three issues.
Name: Annotation 2019-06-17 183413.png
Ansichten: 479
Größe: 67,7 KB
  • duncan
    • 312
    did you see the instructions to use an app to get it up and running?
    • tnagpal.
      • 11.05.2019
      • 90
      Thanks. I tried setting it up this way and it shows no Spotify Connect players available.
Name: Annotation 2019-06-18 092715.png
Ansichten: 298
Größe: 57,5 KB
      • tnagpal.
        • 11.05.2019
        • 90
        I am also getting constant network connection reset errors and the whole system seems to go down. It is a clean install of Ubuntu LTS and MS4L and that is it. I might just try LTS and leave it running to see what happens.
          • 7225
          Ubuntu 16? 18?
          At first you have to look why the network is not working well.
          I think that is your main problem.
          Zuletzt geändert von hismastersvoice; 19.06.2019, 18:22.
        • tnagpal.
          • 11.05.2019
          • 90
          Any tips on what logs would be helpful for figuring out the MS4L errors and why it reports no network?
          • tnagpal.
            • 11.05.2019
            • 90
            OK - still getting Network Failed errors, no idea why. I am able to access the web interface, so the network is working as far as I can tell.
            I set up an internal zone using channels 0 and 1 of the soundcard. I also set up an internal player.
            Then I go to MS4L Player Control and the Zone 1 isn't started and when I click start, it loads, but doesn't seem to start the process.
            • tnagpal.
              • 11.05.2019
              • 90
              I am including some pics from the interface since I may have something misconfigured. I am able to ssh into the device and ping common internet sites, so the WAN indication doesn't match what is going on:
              Part 1/2
Name: Screen Shot 2019-06-28 at 08.01.25.png
Ansichten: 453
Größe: 87,0 KB
ID: 205194Klicke auf die Grafik für eine vergrößerte Ansicht
Name: Screen Shot 2019-06-28 at 08.01.11.png
Ansichten: 422
Größe: 83,6 KB
ID: 205195Klicke auf die Grafik für eine vergrößerte Ansicht
Name: Screen Shot 2019-06-28 at 08.02.04.png
Ansichten: 467
Größe: 23,8 KB
ID: 205196Klicke auf die Grafik für eine vergrößerte Ansicht
Name: Screen Shot 2019-06-28 at 08.03.48.png
Ansichten: 436
Größe: 100,2 KB
ID: 205197Klicke auf die Grafik für eine vergrößerte Ansicht
Name: Screen Shot 2019-06-28 at 08.05.02.png
Ansichten: 430
Größe: 43,5 KB
              • tnagpal.
                • 11.05.2019
                • 90
                Part 2/2
Name: Screen Shot 2019-06-28 at 08.05.29.png
Ansichten: 439
Größe: 96,6 KB
ID: 205200Klicke auf die Grafik für eine vergrößerte Ansicht
Name: Screen Shot 2019-06-28 at 08.05.45.png
Ansichten: 429
Größe: 104,4 KB
ID: 205201Klicke auf die Grafik für eine vergrößerte Ansicht
Name: Screen Shot 2019-06-28 at 08.06.29.png
Ansichten: 443
Größe: 32,5 KB
ID: 205202Klicke auf die Grafik für eine vergrößerte Ansicht
Name: Screen Shot 2019-06-28 at 08.07.26.png
Ansichten: 388
Größe: 65,0 KB
                • tnagpal.
                  • 11.05.2019
                  • 90
                  OK - so I got the network error messages to go away and it all looks good, has a static IP.
                  Now... I can't get the Player to start. I click on Start and nothing happens. I go to the LMS settings page and it shows "No player found".
                  Still getting pretty hard crashes of the system. I go to the direct keyboard and it is at the login prompt but when I login, I never get to the prompt. It just hangs
                    • 7225
                    Nice to hear that the network is running...
                    The player don´t start becouse the soundcard is not working or is not configurated.
                    But at first, build a stable system before you try to fix other things.
                    I can´t support you with questions of the OS, I can´t say anything about your hardware.
                    • tnagpal.
                      • 11.05.2019
                      • 90
                      Well did a clean Ubuntu install on the Qotom MiniPC I had earmarked for this and it was still crashing. I might have to run some diagnostics on the actual system.
                      Did another attempt in a VM on my Supermicro server and it went very smoothly. Now if only it was a docker so I wasn't running an entire Ubuntu VM just for MS4L!
