cant get any install to work now
  • duncan
    • 320
    ive had previous versions installed and working on the same hardware, but now cant get the current version to work despite many clean reinstalls:
    hardware is intel dell laptops (2 different versions, both previously worked fine) 1 is i5, the other is i7
    8gb ram, SSD, recommended usb sound cards (i have both logilink and cm106 versions) - both laptops work fine with windows 10
    i can reformat the SSD, install LTS16, disable the internal intel sound card using blacklist, install musicserver4lox, create zone sound cards, create virtual players - all ok
    but none of the virtual players will start manually or automatically.
    all very odd..
    any suggestions?
    check the channels, if using a translate app 8 gets translated to 8th and you have to edit the config files. What error are you getting - Im now getting broken pipe errors on my fresh install and not 100% sure why yet.
    Which its also doing for this post.
    • duncan
      • 320
      no im using the config interface in german - i dont get any error messages, just the virtual players wont start. its odd that exactly the same hardware has worked time after time with earlier installers.
        and from a shell "sc players all start" no errors?
        • duncan
          • 320
          reinstalled and configured the usb sound card to 44khz and it works normally again - very odd...
