LOGITECH MEDIA SERVER webinterface failed
  • nico louis
    • 19.05.2019
    • 13
    Hi all
    I installed music4lox already a couple of times and did work every time. But in my latest intallation the LMS webinterface failed.
    So i have a fresh laptop, nothing on, installed ubuntu server from the website, did not update. v16.04.6
    i installed it in deutch and did configure as the help.
    i got the script and installed it from music-server.net
    then i can login to the ms4L but in status it already tells me that the webinterface link is broken to LMS (Version: 7.9.2~1565679430)
    in the log of lms is something:
    warning read_dir /var/lib/squeezeboxserver/cache/templates - opendir no such file or directory at usr/share/perl5/slim/web/template/skinmanager.pm
    do i mis something?
    i already reinstalled everything 3 times but exactly same outcome.
    any help would be appriciated
    kind regards
    Zuletzt geändert von nico louis; 14.08.2019, 14:21.
  • nico louis
    • 19.05.2019
    • 13
    squeezebox/server.log
    2019-08-14 13:56:35 squeezeboxserver_safe started.
    [19-08-14 13:56:35.9696] main::init (387) Starting Logitech Media Server (v7.9.2, 1565679430, Tue Aug 13 09:18:46 CEST 2019) perl 5.022001 - x86_64-linux-gnu-thread-multi
    [19-08-14 13:56:36.2639] Slim::Utils::SQLiteHelper:ostConnect (374) Optimizing DB because of missing or empty sqlite_stat1 table
    [19-08-14 13:56:36.2716] Slim::Schema::forceCommit (2144) Warning: Trying to commit transactions before DB is initialized!
    [19-08-14 13:56:36.2981] Carp::croak (166) Warning: read_dir '/var/lib/squeezeboxserver/cache/templates' - opendir: No such file or directory at /usr/share/perl5/Slim/Web/Template/SkinManage$
    2019-08-14 13:56:40 Logitech Media Server died. Restarting.
    [19-08-14 13:56:40.9156] main::init (387) Starting Logitech Media Server (v7.9.2, 1565679430, Tue Aug 13 09:18:46 CEST 2019) perl 5.022001 - x86_64-linux-gnu-thread-multi
    [19-08-14 13:56:40.9787] Slim::Utils::SQLiteHelper:ostConnect (374) Optimizing DB because of missing or empty sqlite_stat1 table
    [19-08-14 13:56:40.9900] Slim::Schema::forceCommit (2144) Warning: Trying to commit transactions before DB is initialized!
    [19-08-14 13:56:41.0302] Slim::Utils::SQLiteHelper:ostConnect (374) Optimizing DB because of missing or empty sqlite_stat1 table
    [19-08-14 13:56:41.0422] Slim::Schema::forceCommit (2144) Warning: Trying to commit transactions before DB is initialized!
    [19-08-14 13:56:41.0683] Carp::croak (166) Warning: read_dir '/var/lib/squeezeboxserver/cache/templates' - opendir: No such file or directory at /usr/share/perl5/Slim/Web/Template/SkinManage$
    2019-08-14 13:56:45 Logitech Media Server died. Restarting.
    [19-08-14 13:56:45.9099] main::init (387) Starting Logitech Media Server (v7.9.2, 1565679430, Tue Aug 13 09:18:46 CEST 2019) perl 5.022001 - x86_64-linux-gnu-thread-multi
    [19-08-14 13:56:45.9704] Slim::Utils::SQLiteHelper:ostConnect (374) Optimizing DB because of missing or empty sqlite_stat1 table
    [19-08-14 13:56:45.9974] Slim::Schema::forceCommit (2144) Warning: Trying to commit transactions before DB is initialized!
    [19-08-14 13:56:46.0454] Slim::Utils::SQLiteHelper:ostConnect (374) Optimizing DB because of missing or empty sqlite_stat1 table
    [19-08-14 13:56:46.0530] Slim::Schema::forceCommit (2144) Warning: Trying to commit transactions before DB is initialized!
    [19-08-14 13:56:46.0821] Carp::croak (166) Warning: read_dir '/var/lib/squeezeboxserver/cache/templates' - opendir: No such file or directory at /usr/share/perl5/Slim/Web/Template/SkinManage$
    • nico louis
      • 19.05.2019
      • 13
      had to create the file myself
      mkdir folder name
      su-
      chmod 777
      did solve it
      • nico louis
        • 19.05.2019
        • 13
        it looks like my squeezelite user can't get into the home folder so i think it is a global user permission setting somehow
          • 7238
          Your Problem is fixed in the last Verion of LMS
          Fix #276 - don't try to read cache folder before it's been created
