More than 8 channels
There is from my knowledge no support from Alsa to this interface.
Therefore no support from my side.
Kein Support per PN! -
I think ALSA can see it... I am going to try and get at least 8 channels working. You can see the devices on the support data and it appears in ALSA.
Angehängte DateienKommentar
It is easy to implement more than 8 channels...
But I don´t support it.
1. i can´t check if it works
2. it is an absolute exotic hardware
you can try and report...
goto /var/www/settings/set_soundcard.php
at line 183 put
<option>24</option>
and save
in the webui you can set 24 channels for your soundcard and save.
the script behind will create the soundcard files for alsa.
create a new zone an use channel number higher that >7 and try if it worksKein Support per PN!Kommentar
