Umfrage: MusicServer4Home für den Raspberry 4
  • querex
    • 14.07.2020
    • 177
    #46
    Zitat von hismastersvoice
    After the first reboot the crelay should be changed to the ARM binary and should work
    Please go to the terminal...
    cd /opt/music_server/
    ./crelay
    If you get an error....
    Please look if there is a file named crelay_arm in the directory.
    If yes delete the crelay and rename crelay_arm to crelay.
    hismastersvoice
    Thanks for your input.
    Screenshot of the permissions and execute output:
Ansichten: 803
Größe: 125,8 KB
    Fixed it by copy the crelay file again from the source http://music-server.net/download/install.zip
    Now the relays show up in the CLI "Detected relay cards: #1 HID API compatible relay card (serial 959BI)" and web gui "Found relay card - Serial: 959BI"
    In the install.zip, seems the crelay file contains the string "arm" and the crelay_arm does not contains the string "arm" in it's content.
    Maybe the files has been swapped during ZIP creation?
      • 7328
      #47
      In the install.zip I deliver both crelay (X86) and crelay_arm (ARM). At first boot the system do a Check of the Platfrom, and if it is ARM the X86 file will be exchanged and renamed.
      So if you copy the crelay_arm to the dir, the system has done the exchange and rename to crelay after a reboot. So at the end you should have only the crelay in the dir.
      Take that on my list to watch if that happens more that one time in the future.
      • querex
        querex kommentierte
        Correct I see the rename steps in the installation script.
        But seems the files are already incorrect in the source "install.zip" file.
        install.zip files:
        - crelay => contains "arm" in it's file content
        - crelay_arm => contains not "arm" in it's file content
        Just want to let you know, maybe it's the root cause.
        Thanks, will check that.
    • Siggi
      • 02.03.2016
      • 82
      #48
      Funktioniert die Steuerung via GPIO´s schon ? Bei mir ändert sich der Zustand am GPIO nicht bei an/abschalten einer Zone.
      Kann ich Manuel die GPIO´s ansteuern ?
      Danke schonmal
      Gruß Siggi
        Ja sollten gehen.
        Da du sonst keine Infos und Screenshots lieferst kann ich nicht helfen.
    • Siggi
      • 02.03.2016
      • 82
      #49
      So habe ich es eingerichtet:
Name: Bildschirmfoto 2020-11-16 um 05.33.05.png
Ansichten: 858
Größe: 65,3 KB
Name: Bildschirmfoto 2020-11-16 um 05.37.18.png
Ansichten: 841
Größe: 26,3 KB
      Der Status des GPIO wechselt aber nicht.Um sicher zu gehen habe ich direkt das Multimeter an den GPIO angeschlossen.
      Neustart wurde danach auch durchgeführt.
      Ich wollte folgende GPIO´s benutzen: 17,27,22
      Siggi
        • 7328
        #50
        Siggi
        Trage bitte einmal einen der GPIOs in die Zone direkt ein und versuch ob es da geht.
        Habe es gestern nochmal getestet, geht bei mir soweit.
        • Siggi
          • 02.03.2016
          • 82
          #51
          Hab ich erledigt. Leider klappt das auch nicht.
          Es ist ein Raspberry Pi 3 B
Name: Bildschirmfoto 2020-11-16 um 17.10.45.png
Ansichten: 793
Größe: 101,6 KB
          Zuletzt geändert von Siggi; 16.11.2020, 16:21.
            • 7328
            #52
            Siggi
            Kannst du mal in der Konsole folgendes aufrufen...
            sudo /opt/music_server/tools/rasp_gpio.sh 27 1
            Wobei die 27 der GPIO ist und die 1 einschalten bedeutet. Mit ..27 0 kannst du wieder ausschalten.
            • Siggi
              • 02.03.2016
              • 82
              #53
              Siggi
              Das funktioniert
              • Siggi
                Siggi kommentierte
                Ja der ist an
                Dann gibt es eigentlich keinen Grund warum es nicht gehen soll.
                Schau es mir morgen nochmal genau an.
              • Siggi
                Siggi kommentierte
                Hab um sicher zu gehn nochmal neu installiert. Gleiches Problem wie vorher.
                Danke dir fürs nachschaun !
            • Siggi
              • 02.03.2016
              • 82
              #54
              @hismastersvoice
              Ich hab es heute mal auf dem Raspberry 4 installiert. Hier funktioniert die GPIO Ansteuerung ohne Probleme.
              Das Problem sollte dann also am 3er liegen.
              Siggi
                Danke. Sehr komisch. Morgen kommt ein 3er den ich bestellt habe. Dann installiere ich den MS4H darauf und suche man weiter.
              • Siggi
                Siggi kommentierte
                Ich habe mal ein bißchen gespielt mit dem 4er und den GPIO´s. Wenn ich drei AMP Gruppen anlege und auch verschiedene GPIO´s eintrage
                schalten immer alle Ein/Aus egal welche Zone man einschaltet.
                Im Code werden die GPIOs einzeln verarbeitet.
                Ich hatte das auch schon in der 1.0.12 mit 10 LEDs an den GPIOS simuliert, und die haben sauber geschaltet.
                Werde am WE mal nachsehen und ein Update bereit stellen.
            • Paulchen_Panther
              • 14.02.2019
              • 225
              #55
              Hallo hismastersvoice ,
              zuallererst mal vielen Dank für deine tolle Arbeit, echt Wahnsinn was du in deiner Freizeit für uns alle leistest!
              Hab mir jetzt den MusicServer auf einem Raspberry 3B+ aufgesetzt, mit dem ich zur Zeit spiele und der längerfristig den originalen Loxone Musicserver ersetzen soll.
              Dafür habe ich mir nun auch ein USB-Relay besorgt und angeschlossen, leider wird es bei CRelay nicht gefunden.
              Ich habe deine Eingaben aus Post #45 im Terminal ausgeführt und komme zur selben Anzeige wie der Screenshot in Post #46 von querex .
              Nun bin ich leider absoluter Laie was Linux angeht und bekomme es nicht hin die Datei einfach auszutauschen um zu sehen, ob das Relay dann gefunden wird bzw. weiß auch nicht, wie ich überprüfen könnte, ob die Version für x86 oder arm installiert ist...
              Hättest du evtl. einen Tipp für mich?
              Sonst versuche ich mein Glück mal mit GPIO
              Schöne Grüße!
              • querex
                querex kommentierte
                You can use the commands below:
                cd / opt / music_server / (remove spaces)
                grep arm crelay
                should give you a hit when it's the ARM version
                Zuletzt geändert von querex; 23.11.2020, 09:32.
              • Paulchen_Panther
                Paulchen_Panther kommentierte
                Thanks querex, will try this tonight when I'll be home again.
              • 7328
              #56
              Schöne Grüße!
              cRelay und GPIO werden gerade überarbeitet und ich werde wohl am WE ein update dafür zur Verfügung stellen.
              GPIO scheint auch nicht bei allen zu funktionieren, da habe ich schon eine neue Lösung.
              cRelay habe ich wohl die Binarys vertauscht, wird aber auch gefixt.
            • querex
              • 14.07.2020
              • 177
              #57
              Running multiple weeks on the PI 4 (4GB).
              Response from T5 button to execute the command take more time compared to my previous i7 setup (+/- 1,5 second).
              Do other people experience the same?
              After playing a radio stream for a long time (+/- 7 hours), seems there is loss on the audio stream (sounds as extreme low quality).
              Problem is gone when you turn the music off for some minutes and restart the same radio stream again.
              Problem persists when you does not turn the music off for a longer period (only 4 seconds) and start the same radio stream again.
              Problem exists on other radio streams as wel (after playing +/- 7 hours).
              Sounds like a performance / out of memory issue?
              Is there any information which I can check / export when the problem occurs in SSH terminal?
              Will continue testing tomorrow if the problem also occurs on spotify playlists for +7 hours of playing.
              Video with the audio loss after 7 hours playing.
                • 7328
                #58
                querex
                If that happens next time please do a screenshot of
                Dashboard (WebUI)
                htop (in terminal)
                Than we can have a look if there is a performance problem.
                Zuletzt geändert von hismastersvoice; 24.11.2020, 19:41.
                • querex
                  querex kommentierte
                  Thanks, will do!
              • querex
                • 14.07.2020
                • 177
                #59
                hismastersvoice 7,5h play time and ready to take the screenshots see the attachments below.
                When I stop the audio player, load average moved back to 0.30 - 0.36
                When I started the audio zone again, load average is 0.49 - 0.79
                If I'm able to test / debug something else, please let me know.
                • punctuele
                  • 23.10.2019
                  • 18
                  #60
                  Morgen geht es weiter mit der Entwicklung der Clieant... Da habe ich mir was aufgehalst
                  Config wird schon mal übertragen, und die Zonen laufen soweit nach Änderung.
                  Ich muss aber noch ein Logging einbauen das die Fehlersuche insbesondere bei Soundkarten-Fehler erleichtert.
                  Auch das löschen von Client funktioniert noch nicht wie ich will... Aber das wird schon alles
                  Anbei der kleiner Test-Parkour mit verschiedenen HATs, Raspi 3/4 Zero W, Raspi 3A+
                  Noch viel Arbeit vor mir...
                  Schickt mir doch noch was für Audio-HATs ihr schon habt, bzw. welche unterstützt werden sollten.
Ansichten: 1415
Größe: 1,57 MB
                  did you already have some testing time? :-) I'm curious about the results...
                  Is there some overview on hardware?
                  e.g. what's the minimum requirement? Is a Pi3B enough or do you need a B+ or higher?
                  And in second instance also on the amplifiers? Real amplifiers or HAT's: power consumption, ...
                  regards!
                  Smarthome: 2x Mini server Gen1, 2xDimmer extensions, 7xExtensions, 1x Relay Extension, Tree extension, Air base extension, RGBW air dimmer, NFC Keypad Tree
                  Multimedia: MS4H on PI3B with 4 zones + Russound D850 + B&W M1 speakers
                  Peripherals: Loxberry on PI3B, Youless
