Versioning and system issues
  • tnagpal.
    • 11.05.2019
    • 90
    So I hit the update button and it says 1.0.11 installed on the update page even though the update window never quite progressed. Then I check the support data and it says I have Ubuntu installed and version 0.6.2 installed.
    I don't, I have Debian installed and at least 0.7.4.
    No change in the look of the interface or the name - so it is definitely not 1.0.11.
    • 7321
    Try to update again. Your still at old WebUI.
    clean cache of your browser
      • 7321
      I see at at support data that you use Ubuntu not Debian.
      If the Script see that your use Ubuntu the skript stops.
      There is a issue that the version is set to 1.0.11, this I have to fix.
      The support data is read out direct from the system files of the os, so I can't believe that it says ubuntu when your on Debian.
      Zuletzt geändert von hismastersvoice; 18.09.2020, 23:37.
