MS4H V1.2.0_beta - the next big thing ;)
  • Davejje
    • 24.11.2017
    • 173
    #76
    Zitat von hismastersvoice
    Davejje
    So...?
Ansichten: 538
Größe: 113,4 KB
ID: 286227Klicke auf die Grafik für eine vergrößerte Ansicht
Ansichten: 534
Größe: 195,2 KB
Ansichten: 521
Größe: 107,6 KB
    Weltklasse wie ich meine
    • czgaston
      • 22.09.2018
      • 14
      #77
      Good day,
      I have a problem with the second sound card. When I work with one, everything is fine. Today I connected another sound card and the zones stopped working.
      I also tried to remove the zones and gradually add them and it didn't help.
      When I remove the second sound card, everything is fine again.
      Proxmox 6.3.3 - Debian 10.4
        Normal this should work.
        If not I think you have to delete the players, save sound card settings again and setup the players.
      • czgaston
        czgaston kommentierte
        I'm trying it with one zone now. I also tried shuffling the order of the cards in MS4H and nothing.
        I also tried another sound card if the new card is not damaged and nothing.
        The cards are the same manufacturer and type cannot be in this problem?
        Zuletzt geändert von czgaston; 17.01.2021, 18:37.
        show the output of
        dmesg
    • czgaston
      • 22.09.2018
      • 14
      #78
      Inside the attachment
      • 7227
      #79
      #V1.2.2.0_beta
      MSG
      new -> own Icons for Spotify, that it fit to the rest of the Loxone-Icons
      new -> Multi-user for Spotify
      Attention!! You have to change a Setting in Spotty-Plugin (https://music-server.net/help/SpottySpotify.html)
      System
      change -> Volume-Reset is now executed after Zone-Power-Off not as before after Amp-Power-Off
      fix -> Amp-Group All was not working
      WebUI
      fix -> minor optical improvements
      new -> Set description for Sound-card-channels, for a better identifying in Zone-Setup
      • Kuredu
        • 30.08.2015
        • 40
        #80
        Hat noch jemand Probleme seit dem Update auf 1.2.2.0 mit dem MSG. Loxone kann keine Verbindung zum Music Server aufbauen Offline?
          Geh auf die Konsole...
          sc msg stop
          cd /opt/music_server/msg
          DEBUG=* ./msg1.sh
          Screenshot machen
          Zuletzt geändert von hismastersvoice; 18.01.2021, 22:00.
      • Kuredu
        • 30.08.2015
        • 40
        #81
        Anbei der Scrennshot
          • 7227
          #82
          Dieses Modul raubt mir noch den letzten Nerv.
          sudo rm -rf /opt/music_server/msg/node_modules
          cd /opt/music_server/msg/service
          sudo npm install
          cd ..
          DEBUG=* ./msg1.sh
          Screenshot
            • 7227
            #83
            Werde das Update 1.2.2.0_beta nochmal zurück ziehen.
            Habe gerade festgestellt das er beim wechseln der Spotify Accounts in der App noch zu Problemen kommt.
            Downgrade wenn nötig über die Konsole
            mstools update_ms_beta 1.2.1.5_beta
            • Kuredu
              • 30.08.2015
              • 40
              #84
              Mit dem Downgrade funktioniert es nun wieder. Anbei der Screenshot vor dem Downgrade.
              Zuletzt geändert von Kuredu; 19.01.2021, 11:55.
              • Davejje
                • 24.11.2017
                • 173
                #85
                Klingt gut. Ich sehe das Update einfach nicht in der Weboberfläche? Könnte es wahr sein, dass es aufgrund der oben genannten Probleme zurückgezogen wurde?
                • hme0354
                  hme0354 kommentierte
                  siehe post #83
              • Davejje
                • 24.11.2017
                • 173
                #86
                Nicht gesehen
                  • 7227
                  #87
                  Ich werde heute Abende ein zwischen update 1.2.1.8_beta machen.
                  Wird bis auf multi Spotify-User alles drin sein was auf der Liste ist.
                  Ich war so begeistert das man Spotify User wechseln kann, das ich zu voreilig das ganze mit eingebaut habe.
                  Aber die fixe usw. werden wenigstens drin sein, und Spotify User kommt dann hinterher.
                    • 7227
                    #88
                    #V1.2.1.8_beta
                    MSG
                    System
                    WebUI
                    ______________________________________
                    Die Einstellung für Spotty muss für das Menü so aussehen.
                    Für den Fall das ihr sie bei 1.2.2.0 geändert hattet.
Ansichten: 490
Größe: 39,4 KB
                    • Apollon_09
                      • 01.11.2016
                      • 17
                      #89
                      Moin zusammen.
                      Bei 1.2.18 bleibt der Musicserver in der Loxone
                      -Visu ebenfalls offline.
                      Sent from my iPhone using Tapatalk
                      • Gagi
                        Gagi kommentierte
                        Läuft der MSG bzw. hilft evtl. ein Neustart ?
                        Überschüttet mich nicht mit so vielen Infos über euer System
                        Aktuell sind 20 User auf 1.2.1.8_beta, bis jetzt bist du der erste der diesen Fehler hat.
                        Also brauch ich mehr Infos.
                        In Beitrag 83.1 habe ich beschrieben wie du beim MSG debuggen kannst.
                        Bitte Screenshot wenn es eine Fehlermeldung gibt.
                    • Davejje
                      • 24.11.2017
                      • 173
                      #90
                      Nach dem letzten Update stoße ich manchmal auf Probleme. Es ist mit Namen, wenn ich versuche, einen Radiosender zu starten, wird es ordentlich ins Spiel gebracht. Es scheint daher, dass es abgespielt wird, aber es kommt kein Ton aus den Lautsprechern. Wenn ich dann mit einer der Überschriften zurück beginne oder das nächste Mal drücke, ertönt ein akustisches Geräusch. Selbst wenn ich die Lautstärke hin und her bewege, funktioniert dies auch. Spotify funktioniert sofort. Ist dies ein Problem in der neuesten Version oder liegt dies am Stream?
                        Ist das eine Google-Translator Übersetzung?
                        Ich verstehe nicht wirklich was du willst.
                        Vielleicht sollten wir es auf englisch versuchen?
                        Ohne Infos über dein System, Software Versionen und um welche Radio-Sender es geht kann ich nicht helfen.
                      • Davejje
                        Davejje kommentierte
                        Yes it is a translation from dutch to german.
                        I have some problems with the music server. When i try to strat a radio channel the player shows me that het stream is playing but ther is no sound.
                        After i hit the butten next or previous in the Loxone visu, it will give me some sound on the speakers. In this way it stays on the same stream!
                        I have it by all of my radio streams. for example: Radio 538, NPO 3 FM, Sky Radio These are Dutch radio channels
                        I use a VM ware on a Qnap Nas
                        Music Server : 1.2.1.8
                        LMS: 8.2.0~1611497793
                        Sqeezelit: 1.9.8-1323
                        Debug log:
                         MSG:ZONE-1 REQUESTING ZONE STATE FROM LMS +0ms
                          MSG:ZONE-1:LMS REQUEST:  bb:bb:a3:b9:ea:3b mixer volume ? +0ms
                          MSG:ZONE-1:LMS REQUEST:  bb:bb:a3:b9:ea:3b playerpref playDelay ? +0ms
                          MSG:ZONE-2 REQUESTING ZONE STATE FROM LMS +0ms
                          MSG:ZONE-2:LMS REQUEST:  bb:bb:47:af:a8:fb mixer volume ? +0ms
                          MSG:ZONE-2:LMS REQUEST:  bb:bb:47:af:a8:fb playerpref playDelay ? +0ms
                          MSG:ZONE-3 [ERROR] No MAC configured for zone 3 +0ms
                          MSG:ZONE-4 REQUESTING ZONE STATE FROM LMS +0ms
                          MSG:ZONE-4:LMS REQUEST:  02:54:00:f4:34:9e mixer volume ? +0ms
                          MSG:ZONE-4:LMS REQUEST:  02:54:00:f4:34:9e playerpref playDelay ? +0ms
                          MSG:ZONE-5 REQUESTING ZONE STATE FROM LMS +0ms
                          MSG:ZONE-5:LMS REQUEST:  03:54:00:f4:34:9e mixer volume ? +0ms
                          MSG:ZONE-5:LMS REQUEST:  03:54:00:f4:34:9e playerpref playDelay ? +0ms
                          MSG:ZONE-6 REQUESTING ZONE STATE FROM LMS +0ms
                          MSG:ZONE-6:LMS REQUEST:  04:54:00:f4:34:9e mixer volume ? +0ms
                          MSG:ZONE-6:LMS REQUEST:  04:54:00:f4:34:9e playerpref playDelay ? +0ms
                          MSG:ZONE-7 REQUESTING ZONE STATE FROM LMS +0ms
                          MSG:ZONE-7:LMS REQUEST:  05:54:00:f4:34:9e mixer volume ? +0ms
                          MSG:ZONE-7:LMS REQUEST:  05:54:00:f4:34:9e playerpref playDelay ? +0ms
                          MSG:ZONE-8 REQUESTING ZONE STATE FROM LMS +0ms
                          MSG:ZONE-8:LMS REQUEST:  06:54:00:f4:34:9e mixer volume ? +0ms
                          MSG:ZONE-8:LMS REQUEST:  06:54:00:f4:34:9e playerpref playDelay ? +0ms
                          MSG:ZONE-9 REQUESTING ZONE STATE FROM LMS +0ms
                          MSG:ZONE-9:LMS REQUEST:  01:54:00:f4:34:9e mixer volume ? +0ms
                          MSG:ZONE-9:LMS REQUEST:  01:54:00:f4:34:9e playerpref playDelay ? +0ms
                        events.js:174
                              throw er; // Unhandled 'error' event
                        Error: listen EADDRINUSE: address already in use :::7090
                            at Server.setupListenHandle [as _listen2] (net.js:1280:14)
                            at listenInCluster (net.js:1328:12)
                            at Server.listen (net.js:1415:7)
                            at Object.<anonymous> (/opt/music_server/msg/service/index.js:65:4)
                            at Module._compile (internal/modules/cjs/loader.js:778:30)
                            at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
                            at Module.load (internal/modules/cjs/loader.js:653:32)
                            at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
                            at Function.Module._load (internal/modules/cjs/loader.js:585:3)
                            at Function.Module.runMain (internal/modules/cjs/loader.js:831:12)
                            at startup (internal/bootstrap/node.js:283:19)
                            at bootstrapNodeJSCore (internal/bootstrap/node.js:623:3)
                        Emitted 'error' event at:
                            at emitErrorNT (net.js:1307:8)
                            at process._tickCallback (internal/process/next_tick.js:63:19)
                            at Function.Module.runMain (internal/modules/cjs/loader.js:834:11)
                        Zuletzt geändert von Davejje; 25.01.2021, 08:17.
