13.1.0 not seeing music-zones
  • tnagpal.
    • 11.05.2019
    • 90
    You can see from the dashboard page:
Name: Annotation 2021-02-28 084913.png
Ansichten: 374
Größe: 89,9 KB
    I can see the zones on Spotify with Spotty, so they appear to be working.
    Attached my support data. (FYI this is my production server using Deb 10, not my staging which is where I have Deb 11)
    • 7225
    Post screenshot of help-> Config check
    • tnagpal.
      • 11.05.2019
      • 90
      PHP-Code:
      Checking...MusicServer Config --> All Required Parameters are found.
      Checking...Version Config --> All Required Parameters are found.
      Checking...Statistic Config --> All Required Parameters are found.
      Checking...LMS Config --> All Required Parameters are found.
      Checking...MiniServer Config --> All Required Parameters are found.
      Checking...PowerManger Config --> Missing Variables: PM_AMP_ALL,URL_ALL_EIN,URL_ALL_AUS,UDP_ALL_IP,UDP_ ALL_PORT,UDP_ALL_EIN,UDP_ALL_AUS,KNX_ALL,CRELAY_SE RIAL,CRELAY_COUNT,CRELAY_ALL,GPIO_ALL,GROUP_1,GROU P_2,GROUP_3,GROUP_4
      Checking...Squeeze2Lox Config --> Missing Variables: MSG_RADIO_PODCASTS
      Checking...Language Config --> All Required Parameters are found.
      Checking...Folow-Me Config --> All Required Parameters are found.
      Checking...FritzCallMonitor Config --> All Required Parameters are found.
      Checking...Text2Speech Config --> Failed to read Config-File
      Checking...Ring/Alarm Config --> All Required Parameters are found.
      Checking...TavelTime Config --> All Required Parameters are found.
      Checking...Weather2Speech Config --> Missing Variables: WTTS_LAT,WTTS_LON
      Checking...Announcement Config --> All Required Parameters are found.
      Checking...Network Config --> All Required Parameters are found.
      Checking...NAS Config --> Missing Variables: NAS_SMB_VER
      Checking...Mail Config --> All Required Parameters are found.
      Checking...T5 Config --> All Required Parameters are found.
      Checking...KNX Config --> All Required Parameters are found.
      Checking...Zones internal Main-Config --> All Required Parameters are found.
      Checking...Zones external Main-Config --> All Required Parameters are found.
      Checking...Zone 1 intern Config --> Missing Variables: PM_DATEN,UDP_IP,UDP_PORT,UDP_EIN,UDP_AUS
      Checking...Zone 2 intern Config --> Missing Variables: PM_DATEN,UDP_IP,UDP_PORT,UDP_EIN,UDP_AUS
      Checking...Zone 3 intern Config --> Missing Variables: PM_DATEN,UDP_IP,UDP_PORT,UDP_EIN,UDP_AUS
      Checking...Zone 4 intern Config --> Missing Variables: PM_DATEN,UDP_IP,UDP_PORT,UDP_EIN,UDP_AUS
      Checking...Zone 5 intern Config --> Missing Variables: PM_DATEN,UDP_IP,UDP_PORT,UDP_EIN,UDP_AUS
      Checking...Zone 6 intern Config --> All Required Parameters are found.
      Checking...Zone 7 intern Config --> Missing Variables: PM_DATEN,UDP_IP,UDP_PORT,UDP_EIN,UDP_AUS
      Checking...Zone 8 intern Config --> Missing Variables: PM_DATEN,UDP_IP,UDP_PORT,UDP_EIN,UDP_AUS
      Checking...Zone 9 intern Config --> Missing Variables: PM_DATEN,UDP_IP,UDP_PORT,UDP_EIN,UDP_AUS
      Checking...Zone 10 intern Config --> Missing Variables: PM_DATEN,UDP_IP,UDP_PORT,UDP_EIN,UDP_AUS
      Checking...Zone 11 intern Config --> Missing Variables: PM_DATEN,UDP_IP,UDP_PORT,UDP_EIN,UDP_AUS
      Checking...Zone 1 extern Config --> All Required Parameters are found.
        • 7225
        Strange normaly the settings should be set with an update.
        go to... each zone an save without changing any values
        go to... PowerManger an save without changing any values
        Try again an post the result
          • 7225
          Look to Text2Speech Config file
          /opt/music_server/sq_cfg/event/sq_tts.cfg
          In this file something is wrong
            What base version you have updated from?
        • tnagpal.
          • 11.05.2019
          • 90
          I can't select other zones besides Zone 01. I tried saving that one and it doesn't show up on the front either.
Name: Screen Shot 2021-02-28 at 10.34.17.png
Ansichten: 293
Größe: 134,9 KB
          PS: My staging (Deb 11) has the same problem but I haven't set up any zones yet.
            • 7225
            What is about /opt/music_server/sq_cfg/event/sq_tts.cfg
            • tnagpal.
              • 11.05.2019
              • 90
              PHP-Code:
              TTS_AUTOPLAY="1"
              TTS_SYNC_RESTORE="0"
              TTS_VOLUME="25"
              TTS_TOKEN="11111"
              TTS_QUAL="44khz_16bit_stereo"
              TTS_LANG="de-de"
              TTS_TIMEOUT="30"
              POLLY_VOICE="Marlene"
              TTS_PROV="voicerss"
              POLLY_AKI="111111"
              POLLY_SAK="111111"
              TTS_OVERLAY="0"
              TTS_OVERLAY_DROP="20"TTS_SIGNAL="0"
              TTS_SIGNAL_ONYL_MSG="0"
                • 7225
                Please make a line brake here
                and save again.
                • tnagpal.
                  • 11.05.2019
                  • 90
                  Ok, some progress - 2 zones now appearing after a full system reboot and adding the line-break.
                  PHP-Code:
                  Checking...Text2Speech Config --> Missing Variables: TTS_FILE_DEL_DAYS,TTS_RV_KEY,TTS_RV_LANG
                  Checking...Zone 1 intern Config --> All Required Parameters are found.
                    • 7225
                    Go to /opt/music_server/sq_cfg/sq_zones.cfg and /opt/music_server/sq_cfg/sq_zones_ext.cfg
                    And put the real Numbers of Zones you have in the vars.
                    After that it should work again
                    I provide next week and update version of config check that should have a repair function.
                    • tnagpal.
                      • 11.05.2019
                      • 90
                      Thanks, that made the zones show up which is great, they are yellow or red though, so will need to figure that out. But at least getting there...
                      • tnagpal.
                        • 11.05.2019
                        • 90
                        OK, I went through them all and saved them and they are now all yellow. So now to figure out hot to get them green.
                          They don't get green... They show then play/stop, orange is standby / red = not started
