doorbell plays several times
  • duncan
    • 364
    i have ms4h 1.3.1.8 up and working great, but have a problem of the doorbell sound playing 4-5 times
    when i use a virtual output directly to ms4h eg "/event/event.php?type=ring&cat=bell&zone=all&zone_ext=1,2 ,3,4,5,7&autoplay=1&sync=1&overlay=1&overlay_drop= 10&prio=1" it plays once only, but many zones dont restart the music after, they just stay silent
    if i use the door controller connected to the Be input of an audio overview block so that the doorbell plays via the music zones then the doorbell plays 4 or 5 times before going back to the music
    the Qb output of the door controller is set to 0.02 seconds
    loxone online help talks about the music server zones having a Te parameter:
    EVENTS
    All Events begin on the rising edge and will continue until a falling edge is detected.
    This applies to:
    • Alarm
    • Fire Alarm
    • Doorbell
    • Alarm Clock
    If the event file is shorter than the event cycle the song/sound will be repeated until the event ends (falling edge detected).
    If the track is shorter than the parameter Te the file will loop until Te has been reached.
    i cant find Te in the server, audio zones, audio overview or anywhere else...any ideas?
    • 7663
    Te is not existing in the config any more, but look here LINK
    The minimum of a Track has to be 8 sec. or change the config-file.
    overlay only reduce the volume of the playing (internal) Zones (external Zones we load File and relaod Playlist after playing)
    So it could not be silent after playing.
    You have a scpe in 1,2 ,3,4,5,7, please check, I'm not sure if this could be a problem.
    Use the Event-Generator in WebUI.
    It is playing as long you set the time is in the block of door bell or switch on the connection to the intercom.
    • duncan
      • 364
      thanks for the quick reply
      found the link - if i connect Qa output to something it will stop the 8sec issue?
      Zuletzt geändert von duncan; 12.03.2021, 19:54.
