Zone losing connection
  • yavel
    • 21.01.2021
    • 26
    Hello,
    I have MS4Home installed for a while. Since last week 1 zone loses connection about 1 time per day.
    The zone has Loxberry with the squeezelite player plugin installed. When it loses connection (also not popping up in LMS), loxberry keeps on working without a problem.
    After a reboot, the zone connects again. I've already turned off "Poweroff idle zones", but without result.
    Does somebody have an idea what to do here?
    Thank you.
    Best regards,
    Yavel
    • 7225
    Support Data would be helpfull
    • yavel
      • 21.01.2021
      • 26
      Hello,
      Sorry I didn't include it in the first post.
      Here you are:
      • Versions of MS4H: 1.4.1.8_beta
      • Hardware: Raspberry 4
      • Zones internal number: 0
      • External number of zones: 3 working
        Which external zone hardware: Raspberry 4 + Hifiberry Amp2 connected via UTP on internal network
      • Software Versionen: Loxberry (2.2.1.2) + Squeezelite Plugin
        • 7225
        Not sure if this is really a MS4H issue.
        ​​​​​​Do you have an second LMS installation.
        Are your Clients connected via LAN or WLAN?
        In the MS4H Client Plugin for Loxberry I give the Squeezelite players a fix Server IP so that they never can connect to another LMS.
        You can du this in Squeezelite Player Plugin via additional options -s IPOFMS4H_OR_HOSTNAME
        Please try and give feedback.
        • yavel
          • 21.01.2021
          • 26
          No, I don't have another set-up.
          Ok, I will try that. Thanks for the info.
          • yavel
            • 21.01.2021
            • 26
            I installed the MS4H client which works well for the moment.
            But now I have the problem that Loxone config shows "Devide offline". I haven't changed any parameters though... Any idea what could be the problem?
            Or which information I should provide for you to see?
