doorbell doesnt stop ringing
  • duncan
    • 320
    ms4h is working fine, but if i use the Be input of a music zone then sometimes it plays the sound once, sometimes it plays it continuously for around 20-30 seconds
    the event playback Te is set to 3 seconds. once the boorbell stops then the music resumes as expected
    it happens in different zones at different times
    any ideas? ive very random so difficult to pin down
    • 7319
    30 second's are the standard timeout of event, so I guess that it runs until timeout.
    Are the issue at internal and external zones?
    Did you set Te by hand to 3 second, normal is lowest value 8 seconds.
    I use the 8 seconds for my tests.
    What file you play for doorbell?
    • duncan
      • 320
      the issues affect internal and external zones randomly
      i get the same problems using any doorbell sound
      each music zone is set to 3 seconds on my system for some reason
      i tried setting all zones to 8 seconds - now works normally again
      thanks for the guidance
        • 7319
        The 8 seconds are an Loxone Musicserver block issue.bi don't know why they set the minimum to 8 seconds
