- Versions of MS4H: 1.5.5.1
- Hardware: Pi 4
- Operation system: DietPI
Due to some problems with a previous SD card, I reinstalled MS4H on a new 32Gb SD card.
I installed DietPI and followed all instructions of installing MS4H. The LMS worked and was set-up. After I saw that I could connect to the MS4H web interface, I plugged out the Pi4 and plugged it in again somewhere else. From now on, I can't connect anymore to the web interface. The LMS does work and I'm able to play music. The ip address is the same and is recognized by my modem.
I just can't connect to the web interface anymore.
Is this a known issue? Does somebody know what to do?
Thank you very much in advance.
Best regards
