No connection to web interface
  • yavel
    • 21.01.2021
    • 26
    • Versions of MS4H: 1.5.5.1
    • Hardware: Pi 4
    • Operation system: DietPI
    Hello,
    Due to some problems with a previous SD card, I reinstalled MS4H on a new 32Gb SD card.
    I installed DietPI and followed all instructions of installing MS4H. The LMS worked and was set-up. After I saw that I could connect to the MS4H web interface, I plugged out the Pi4 and plugged it in again somewhere else. From now on, I can't connect anymore to the web interface. The LMS does work and I'm able to play music. The ip address is the same and is recognized by my modem.
    I just can't connect to the web interface anymore.
    Is this a known issue? Does somebody know what to do?
    Thank you very much in advance.
    Best regards
    • 7321
    Not a known issue...
    I belive the Apache webserver ist not runinning anymore.
    In Console (ssh) you can check...
    sc autorestart
    If this is not working...
    sudo systemctl status apache2
    If there are errors you can reinstall
    sudo apt remove apache2
    sudo apt install apache2
    • yavel
      • 21.01.2021
      • 26
      Hello Hismastersvoice,
      Thank you very much for your help.
      sudo systemctl status apache2 showed an error, so I did the 2 next steps and now it works!
      Best regards
