der Squeezelite-Player startet in MS4H nicht
Guten Tag. Bitte sagen Sie mir, warum der Squeezelite-Player in MS4H nach dem Neustart von Raspberry nicht angezeigt wird. Ich muss den Player manuell starten -
entschuldigung für die nicht vollständigen Informationen
SUPPORT DATA
MusicServer4Home
VERS=1.5.5.9
OS
DISTRO_MS4H="Dietpi_11_64"
DISTRO="Debian GNU/Linux 11 (bullseye)"
KERNEL="Linux 6.1.21-v8+ aarch64"
Hardware
DMI_MANUFACTURER="Raspberry Pi 3 Model B Plus Rev 1.3"
CPU_NAME="Cortex-A53"
CPU_USAGE="1.00503"
RAM_TOTAL="959"
RAM_USED="269"
RAM_FREE="400"
RAM_BUFFER="289"
DISK_TOTAL="14.80"
DISK_USED="3.14"
DISK_FREE="11.66"
UPWEEKS="0"
UPDAYS="0"
UPHOURS="3"
UPMINUTES="58"
Network
INERNET="1"
HOSTNAME=""
INTERN_TIME="0.148"
INTERN_LOSS="0"
INTERN_REACH="1"
GATEWAY_TIME="0.759"
GATEWAY_LOSS="0"
GATEWAY_REACH="1"
DNS_TIME=" 0.803"
DNS_LOSS="0"
DNS_REACH="1"
MINISERVER_TIME="1.32"
MINISERVER_LOSS="0"
MINISERVER_REACH="1"
Zones
Player extern: 1 DietPi-Squeezelite / b8:27:eb:05:56:bf
Logitech Media Server
LMS_VERS="8.4.0~1697903738"
LMS IP=192.168.1.106
LMS_WEB="1"
LMS PORT=9090
LMS_TEL="1"
Squeezelite
SQLITE_VERS="1.9.9-1449"
Output Devices
Output devices:
null - Discard all samples (playback) or generate zero samples (capture)
lavrate - Rate Converter Plugin Using Libav/FFmpeg Library
samplerate - Rate Converter Plugin Using Samplerate Library
speexrate - Rate Converter Plugin Using Speex Resampler
jack - JACK Audio Connection Kit
oss - Open Sound System
pulse - PulseAudio Sound Server
upmix - Plugin for channel upmix (4,6,8)
vdownmix - Plugin for channel downmix (stereo) with a simple spacialization
hw:CARD=SOUND_CARD_1,DEV=0 - Respawn, USB Audio - Direct hardware device without any conversions
plughw:CARD=SOUND_CARD_1,DEV=0 - Respawn, USB Audio - Hardware device with all software conversions
sysdefault:CARD=SOUND_CARD_1 - Respawn, USB Audio - Default Audio Device
front:CARD=SOUND_CARD_1,DEV=0 - Respawn, USB Audio - Front output / input
surround21:CARD=SOUND_CARD_1,DEV=0 - Respawn, USB Audio - 2.1 Surround output to Front and Subwoofer speakers
surround40:CARD=SOUND_CARD_1,DEV=0 - Respawn, USB Audio - 4.0 Surround output to Front and Rear speakers
surround41:CARD=SOUND_CARD_1,DEV=0 - Respawn, USB Audio - 4.1 Surround output to Front, Rear and Subwoofer speakers
surround50:CARD=SOUND_CARD_1,DEV=0 - Respawn, USB Audio - 5.0 Surround output to Front, Center and Rear speakers
surround51:CARD=SOUND_CARD_1,DEV=0 - Respawn, USB Audio - 5.1 Surround output to Front, Center, Rear and Subwoofer speakers
surround71:CARD=SOUND_CARD_1,DEV=0 - Respawn, USB Audio - 7.1 Surround output to Front, Center, Side, Rear and Woofer speakers
iec958:CARD=SOUND_CARD_1,DEV=0 - Respawn, USB Audio - IEC958 (S/PDIF) Digital Audio Output
dmix:CARD=SOUND_CARD_1,DEV=0 - Respawn, USB Audio - Direct sample mixing device
dsnoop:CARD=SOUND_CARD_1,DEV=0 - Respawn, USB Audio - Direct sample snooping device
usbstream:CARD=SOUND_CARD_1 - Respawn - USB Stream Output
Portscan
Port 22 reachable
Port 80 reachable
Port 443 not reachable
Port 7091 reachable
Port 7092 reachable
Port 9000 reachable
Port 9090 reachable
MSG Config
"plugin": "lms",
"zones": 1,
"zone_map": {"1": "b8:27:eb:05:56:bf"
"ip": "192.168.1.106",
"lms_host": "localhost",
"lms_port": 9000,
"lms_cli_port": 9090,
"macAddress": "b8:27:eb:05:56:bf",
"useSlowQueueWorkaround": true,
"cors_port": 7092,
"msApi": "LWSS V 1.4.10.06 | ~API:1.6~",
"ms": {
"host": "192.168.1.3:443",
"users": [
"{ all users and passwords were blanked }"
"sayFav": true,
"filteredRadioEntries": [ "language","search","picks" ],
"filteredSpotifyEntries": [ ],
"scripts": {
"powerOff": "wget -4 -q -O - 'http://192.168.1.106/include/set_msg.php?do=shutdown'",
"playUploadedFile": "wget -4 -q -O - 'http://192.168.1.106/include/set_msg.php?do=announcement&zone_msg={{zones}}'",
"playAlarmSound": "wget -4 -q -O - 'http://192.168.1.106/include/set_msg.php?do=event&zone_msg={{zones}}&event_name ={{name}}&event_typ={{type}}&event_volume={{volume }}'",
"playTTS": "wget -4 -q -O - 'http://192.168.1.106/include/set_msg.php?do=event&zone_msg={{zones}}&event_name ={{name}}&event_text={{text}}&event_volume={{volum e}}'",
"changeEqualizer": "wget -4 -q -O - 'http://192.168.1.106/include/set_msg.php?do=eq&zone_msg={{zones}}'",
"changeDefaultVolume": "wget -4 -q -O - 'http://192.168.1.106/include/set_msg.php?do=defaultVolume&zone_msg={{zones}}'",
"changeMaxVolume": "echo {{name}} {{zones}} {{maxVolume}}",
"addNetworkShare": "echo {{name}} {{server}} {{guest}} {{username}} {{password}} {{configBase64}}",
"sayFav": "wget -4 -q -O - 'http://192.168.1.106/include/set_msg.php?do=event&zone_msg={{zones}}&event_name ={{name}}&event_text={{fav_name}}&event_volume={{v olume}}'"
"uploadPath": "/var/www/event/tts_tmp",
"uploadPlaybackPath": "/var/www/event/tts_tmp"
Soundcard(s)
1 [SOUND_CARD_1 ]: USB-Audio - Respawn
Default-Card
## DEFAULTCARD CREATED BY MUSICSERVER4HOME
pcm.!default {
type plug
slave {
pcm "allchannel"
## ALLCHANALLCARD CREATED BY MUSICSERVER4HOME
## Um z.B. Klingel usw. auf allen Zonen auszugeben
pcm.allchannel {
type plug
slave {
pcm "multi"
channels 2
ttable.0.0 1
ttable.1.1 1
Multi-Card
## MULTICARD CREATED BY MUSICSERVER4HOME
pcm.card_0 {
type dmix
ipc_key 2047
slave {
pcm "hw:0"
rate 48000
period_time 0
period_size 1024
buffer_size 8192
channels 2
bindings {
0 0
1 1
pcm.multi {
type multi
slaves.a {
pcm "card_0"
channels 2
bindings.0.slave a
bindings.0.channel 0
bindings.1.slave a
bindings.1.channel 1
Was soll das für ein Audio Device sein "USB-Audio - Respawn"
Was genau wird eingesetzt an Hardware?Kein Support per PN!Kommentar
Vermutlich liegt es dann genau an der nicht supportenden USB-Karte.
Ich habe so einen Eintrag noch bei keiner Karte gesehen, und ich habe schon sehr viele getestet.
