Update Thread...
Das ist ein wichtiges Thema.
    • 7317
    Update Thread...
    Akutelle Version Release: 1.5.5.12 (mehr Infos weiter unten)
    Akutelle Version Beta: n.a. (mehr Infos weiter unten)
    Hier werde in Zukunft die Updates vorstellen...
    #1.5.5.13
    System
    fix - Install-Process becouse of renaming Logitech Media Server to Lyrion Media Server
    Installer
    fix - Fav issue becouse of missing mysqueezebox.com Favorite
    Known issues Version 9.x
    Radio and Soptify-Search don't work any more.​
    #1.5.5.12
    System
    fix - LMS could not be installed ( LMS download page has been changed AGAIN )
    fix - Squeezelite failed at compile process
    new - Tunein-Fix will be installed with LMS update
    #1.5.5.11
    System
    fix - LMS could not be installed ( LMS download page has been changed AGAIN )​
    #1.5.5.10
    System
    fix - LMS could not be installed (LMS download page has been changed)
    #1.5.5.9
    KNXd
    fix - install missing xxd Package for DietPi to en-/decode HEX for Title/Artist/Volume etc.
    WebUI
    fix - External Zones - ESP32 was shown as Sonos in WebUI
    #1.5.5.8
    System
    new - Setup Soundcard-Master-Volume at boot, some Mainboard Soundcard loss the settings after shutdown
    new - ACPI Support, some Mainboards need the special support files, otherwise the Power Button will not work.​
    #1.5.5.7
    System
    #1.5.5.7
    System
    new -> PowerManger Support for Loxone-Trigger-Card (tested with Mainboard Asus Z87M Plus)
    This update opens the way to install the MS4H on the otg. MusicServer-Hardware (please use a new SSD >256GB an keep the org. HDD)
    fix -> Minor issues​
    fix -> Minor issues
    Installer
    fix -> Error network.txt permissions
    new -> Install needed packages for Trigger-Card (only if Hardware is X86)
    #1.5.5.6_beta
    System
    new -> PowerManger Support for Loxone-Trigger-Card, first proof
    #1.5.5.5
    System
    remove -> PowerManger Support for Loxone-Trigger-Card, not as easy as it looks
    improve -> Soundcard Volume read/set for org. Loxone MusicServer Hardware
    #1.5.5.4
    System
    new -> PowerManger Support for Loxone-Trigger-Card of the org. Loxone MusicServer (WebUI -> Settings -> Services -> PowerManager -> Amp All)
    fix -> again... files in opt/music_server/init/ have not been processed with autostart/autostop command​
    Full Changelog >>>
    Zuletzt geändert von hismastersvoice; 04.04.2024, 18:37.
    • 7317
    • fix - Evnet sync funktioniert nun wieder.
    • fix - Nutzung Disk in Status stimmt jetzt
    • neu - FollowMe-Event, hier kann per URL eine Playliste von einem Player auf einen anderen kopiert werden.
    • neu - Fitz-Call-Monitor Name(wenn im Telefonbuch) und Nummer sowie Name/Nummer auf der angefufen wird werden weiter gegeben.
      Daraus kann man sich mit dem Statusbaustein eine TTS erzeugen lassen. zB Anruf auf Geschäftnummer von Max Mustermann....
    • neu - Backup & Restore
    • neu - SQ2Lox sendet jetzt nur Daten an den MiniServer wenn sich etwas verändert.
      Um den MiniServer und den LMS zu schonen wurde der Wert Zeit herausgenommen. Solltet ihr diesen Wert genutzt haben bitte die VTIs in den Playersettings anpassen!
      Es wird in den Settings des SQ2LOX nun auch keine Looptime mehr benötigt, diese wird automatisch gelöscht
    Heute mal ein etwas größeres Update...
    Achtung!!!
    SQ2LOX hat sich geändert bitte alle Player-Settings anpassen.
    VTI Titel/Artist Time gibt es nicht mehr. Wenn ihr das genutzt habt bitte den Wert nun in VTI Titel/Artist eintragen
    Hilfe-Seite wurde angepasst.
    Ich habe versucht so viel Prüfungen in das Update Script einzubauen das alles geprüft wird.
      • 7317
      • neu - CallerMonitor "anonym" eingefügt wenn keine Nummer übergeben wird
      • neu - CallerMonitor Option Sprechgeschwindigkeit bei Nummern, bei den Settings 0= Nummer wird schnell gesprochen 1= Nummer wird mit mini-pausen gesprochen
      • neu - SQ2Lox kpl. neu geschrieben Werte werden sofort übergeben, sehr viel CPU schonender als bisher. Danke an Christian Fenzl für die Inspiration
      • fix - PowerManger PM Amplifer Startup - Fehler bei TTS/Klingel behoben
      • neu - TTS/CTS/Klingel haben die Option timeout=x bekommen, so kann der Timeout in die URL aufgenommen werden und je nach Anwendung eingestellt werden
      • neu - PowerManager - Nach abschalten des Amplifer können die jeweiligen Player intern und extern auf Wunsch auf eine Standard-Lautstärke zurückgesetzt werden
        So kann man umgehen das z.B. nach einem Stopp der Player wieder mit dem Volume der Party von Vorabend startet. Danke an Matti für die Ispiration und das testen
      • neu - PowerManager/SQ2Lox - Die beiden Dienste können jetzt per URL neu gestartet werden, so werden nach einem reboot des MiniServer alle Infos zwischen MiniServer und MusikServer abgeglichen. ip/system/power.php?todo=restart_sq2lox und ip/system/power.php?todo=restart_pm
      • neu - Weather2TTS - Hiermit kann man eine Wettervorhersage für den Tag bzw. Folgetag/Tageszeit und Astro generieren und per TTS wiedergeben
        Danke an Liver_64 für die Inspiration
      • neu - TravelTime2TTS - Mit Hilfe von Google Distance Matrix kann man sich die Fahrzeit zu einem Ziel (zB Arbeit) ausgeben lassen. Verkehrslage kann berücksichtigt werden.
      • neu - PowerManager kann jetzt auch URLs für interne und externe Zonen schalten und nicht nur VIs. Danke an graffito für die Inspiration
      • fix - Sound-Files in Klingeltone funktionieren wieder
      Achtung!!!
      Es wird beim update ein chmod Fehler angezeigt, dieser kann missachtet werden. Der Fehler wird im Nachgang automatisch behoben.
      Im Update-Skript war ein Fehler der bei zukünftigen Updates jetzt nicht mehr erscheint.
        • 7317
        • fix - Player in Control->Player nach update verschwundnen
          _
        • neu - TTS/CTS/Traverltime/Weather2TTS kann nun mit Amazon Polly genutzt werden (besser Qualität aber nicht kostenlos, sehr günstig)
          VoiceRSS und Polly können parallel genutzt werden, evtl. wenn keine so hohe Qualität benötigt wird. URL-Paramter ttsporv=voicerss o. ttsporv=polly
          Es können wie immer im Webinterface Standart-Werte vergeben werden.
          _
        • neu - CTS nutzt nun die Standard-Einstellungen von TTS, so wird das WebUI übersichtlicher bei TTS
          _
        • neu - Weather2TTS hat Parameter für todo="sunset" (Sonnenaufgang) und todo=moonphase (Mondphase) bekommen
        Amazon Polly Konto kann unter https://aws.amazon.com/de/polly/ erstellt werden.
        • Ihr braucht eine Keditkarte
        • Wählt den Basic - Tarif der ist ohne monatliche Grundgebühren
        • In eurem Konto (recht oben euer Name) könnt ihr unter My Security Credentials -> Access Keys (Access Key ID and Secret Access Key) einen Key erstellen.
          Wichtig der Secret Key wird nur einmal angezeigt, also gleich kopieren.
          • 7317
          • fix - sq2lox holt jetzt sauber die IP und den CLI-Port aus der Config, was unter Umständen nicht immer der Fall warr
          • fix - amazon polly, pip wird nun standardmäßig installiert bzw. upgedatet
          Zuletzt geändert von hismastersvoice; 16.03.2017, 08:48.
          • PrutsR
            • 19.09.2015
            • 4
            Hier ein Neuling aus Niederlande.
            Vielen Dank für Ihre Arbeit !!
            aber einen kleinen Fehler, denke ich.
            tt2tts.php im Parameter "Model"
            Dieser Parameter erscheint nicht im Google-API-Dokumentation.
            Geht man von der default parameter in tt2tts.php. ich glaube dass es "Mode" sein muss.
              • 7317
              PrutsR
              danke für den Hinweis, da hab ich mich wohl von traffic_model täuschen lassen, es heiß natürlich mode...
              Wird in der nächsten Version gefixt. Zum Glück ignoriert er das und zieht default somit funktioniert es wenigstens.
                • 7317
                • neu - All in One Event - Alle Events können nun über /event/event.php?type=xxxx aufgerufen werden
                  tts = Text2Speech
                  cts = Clock2Speech
                  tt2t = TravelTime2SpeecH
                  w2t = Weather2Speech
                  ring = Klingel / Alarm Wecker
                  Alle anderen Parameter können wie gewohnt aus den anderen Events genutzt werden. &zone=...&vol=... usw
                  Wichtig!! Alle bisherigen Events funktionieren nach wie vor, nur ohne Warteschlange und Prio-Option. Neue Funktionen werden aber nur noch für das All in One geschrieben.
                • neu - Warteschlange (queuing) Werden mehr als ein Event vom MiniServer gesendet, werden diese nach ein andere gespielt.
                  Alarm/Wecker/Klingel (ring) haben Vorrang und beendet ein Event das evtl. gerade läuft.
                  Wollt ihr diese Priorität auch für zB "tts" nutzen könnt ihr zu URL &prio=1 hinzufügen. Dann beendet auch dieses das Event das gerade läuft.
                • neu - Spenden-Seite
                • neu - Squeeze2Lox - Es kann jetzt bei jedem Player ein VTI für synchronisierte Zonen angegeben werden.
                  Dann wird in der Visu zB in einem virtuellen Status-Baustein die gesyncten Zonen angezeit zB Kueche, WC, Bad
                  Ist eine Zone nicht gesynct wird -- angezeigt.
                • fix - TravelTime2Speech - kleine Fehler behoben
                • fix - Weather2Speech - kleine Fehler behoben
                Hilfe wurde angepasst...
                Zuletzt geändert von hismastersvoice; 15.04.2017, 06:19.
                  • 7317
                  • neu - Email kpl. überarbeitet Settings->Email
                    Jetzt muss SMTP usw angegeben werden. Alte Variante war nicht immer erfolgreich beim versenden der Emails an eure Email-Adresse.
                  • neu - Update Mailer - Unter Settings->Email kann der Update-Mailer aktiviert werden.
                    Es wird einmal täglich geprüft ob es Updates gibt und ggf. eine Mail an euch gesendet.
                  • neu - Netz-Laufwerk einbinden - Settings->Netzwerk->Netz-Laufwerk einbinden.
                    Es kann eine externe Freigabe in den Musik-Ordner eingebunden werden.
                    Es wird ein Ordner NAS erzeugt. Ihr könnt diesen Ordner auch direkt als Musik-Quelle für den LMS einbinden.
                  • neu - Event TravelTime - Hier kann jetzt einen eigener Text mit Platzhaltern eingesetzt werden.
                    So könnt Ihr die Textausgabe noch individueller gestalteten.
                    !Andere Events wie Weather2TTS /CTS werden folgen. Wenn ich im laufe der Woche mehr Zeit habe.!
                    • 7317
                    • neu - Event - Weather2TTS können jetzt die Texte angepasst werden
                    • neu - Event - neuer Parameter "risevol" damit könnt ihr die Lautstärke anwachsen lassen Werte Start / Ziel 7 Zeit zB &risevol=10,30,60
                      Es würde also in 60 Sekunden von 10 auf 30 erhöht. Das Skript berechnet die Erhöhungsstufen (im Beispiel alle 3 Sekunden)
                    • fix - Event - alte events angepasst das Warteschlange nicht gestört wird.
                    • fix - UpdateMailer - es wird keine Mail mehr versendet wenn die Online-Version-Nummer leer ist
                    • neu - UpdateMailer - wöchentlich oder täglich möglich
                    Zuletzt geändert von hismastersvoice; 01.05.2017, 08:12.
                      • 7317
                      • neu - Event - Play fav (Favoriten) mit risevol &type=fav&fav=1...
                        Es können nun angelegt Favoriten per URL gestartet werden, dabei kann man diverse Parameter nutzen zones/vol/risevol.
                        Ich nutze das als Wecker und lasse eine Favoriten spielen und dabei mit risevol die Lautstärke langsam erhöhen.
                      • opt - Event - Löschen nach x Tagen optimiert
                        Die Dateien bekommen bei erneutem abspielen einen neuen TimeStamp, also werden wirklich nur alte Dateien gelöscht die seit x Tagen nicht mehr "benutzt" wurden.
                        So müssen Dateien die auch nur alle paar Tage genutzt werden nicht neu geladen werden.
                      • neu - Index-Seite Ist jetzt eine (kurze) Status-Übersicht
                      • neu - Index-Seite Die News werden jetzt aus dem Netz geladen, so werdet ihr auf der Indexseite über Neuigkeiten informiert.
                      Zuletzt geändert von hismastersvoice; 01.05.2017, 19:44.
                        • 7317
                        • neu - Event-Overlay Das Event wird über die aktuelle Wiedergabe gelegt ähnlich Auto-Navi. Die Lautstärke der aktuellen Wiedergabe wird zuvor auf x-Prozent (overlay_drop=xx) der Event-Lautstärke gesenkt. Externe Zonen mit Squeezelite werden wie bisher behandelt, und fast synchron (ein paar Millisekunden) zu den internen. UPnP Zonen haben das gleiche Delay wie bisher auch schon. RiseVol geht bei Overlay nicht, macht auch keinen Sinn. Das alte System läuft weiter (overlay=0). Standardwerte können im Webinterface hinterlegt werden.
                        • fix - Event Warteschlange Wurde ein Event (hart) abgebrochen (nicht durch stop=1), wurde die Warteschlange nicht gelöscht und das nächste Event wurde nicht mehr abgespielt. Ist das File nun älter als das Timeout für die Warteschlange (Standard 120 Sek.) wird es gelöscht.
                        • fix - Event Klingel/Wecker... Werte aus dem Webinterface wurde bei Klingel/Wecker... von TTS und nicht aus den Klingel-Settings gelesen.
                        • fix - Event Allgemein Ablauf des alten (nicht Overlay) Events optimiert um Synchronität mit externen Zonen (Squeezelite) zu verbessern.
                        • fix - interne Player MAC-Adressen werden bei der Anlage neuer Player jetzt aus der MAC-Adresse des PC generiert, so wird der Fehler behoben das die Player sich bei mysqueezebox.com nicht angemeldet haben und ggf. Spotify oder Deezer nicht funktioniert haben.
                          • 7317
                          • fix - Player starten nach Update auf 0.4.8 nicht mehr
                          Es wurde bei speziellen Konstellationen eine Datei für das "Overlay" in Event nicht richtig erzeugt. Sollte mit diesem Fix behoben sein.
                          Sorry für die Unannehmlichkeiten...
                          Zuletzt geändert von hismastersvoice; 20.05.2017, 21:37.
                            • 7317
                            Nach langer Abstinenz wieder ein kleines Update..
                            0.5.0
                            fix - TTS-Overlay
                            Bei Ausgabe mit Overlay wurden nicht alle Zonen eingebunden.
                            fix - TTS-VoieRSS
                            MP3s wurde in einzelfällen nicht gespeichert
                            new - Soundkarten
                            Anstatt 6 können jetzt 7 Soundkarten eingerichtet werden. Wunsch User: Labmaster
                            WICHTIG!
                            Wenn ihr nach dem Update auf Soundkarten bearbeiten geht wird ein leeres DropDown angezeigt.
                            Bitte einmal die Anzahl der Karten wieder auswählen und neu speichern. Die Werte gehen beim Update nicht verloren,
                            aber die Anzahl kann erst nach erneutem speichern wieder gelesen werden. Das ist nur ein optischer Fehler die Funktion ist weiter
                            uneingeschränkt.
                            Auf einem meiner Test-Server hat nach dem Update der LMS nicht mehr gestartet da er nicht aktuell war.
                            Also kann es sein das ihr nach dem MS4L Update auch den LMS updaten müsst.
                            Zuletzt geändert von hismastersvoice; 25.01.2018, 11:19.
                              • 7317
                              new - T5 Receiver
                              Damit lässt sich der Loxone Tasten-Standard in der Config mit wenigen Bausteinen erzeugen.
                              Anleitung unter music-server.net/help Webinterface > Settings > Allgemein > T5 Receiver
                              fix - ein paar kleine Anpassungen bei Netzwerk-Settings
