Update Thread...
Das ist ein wichtiges Thema.
    • 7282
    #31
    #V1.2.0_beta
    Events
    fix -> ResponsiveVoice didn't work
    fix -> missed language-variables for one/minus one
    fix -> stop for type playfav works now
    fix -> external Zones play Event with repeat (endless), if repeat was set before at music playing
    fix -> autoplay set now explicit stop if autoplay is not 1
    new -> new Event for single Zones. Works independent for each event/zone, so it's possible to have alarm-clock etc for each Zone separate. Events are stoppable by pause/stop the zone.
    new -> category's &cat=bell / alarm / fire-alarm / clock so we can handle the Events from Music-Block in Config
    new -> Event-Creator for Single-Zone
    new -> risevol implemented in Event-Generator
    new -> change standard-event-setting from MiniServer with URL
    new -> The title will be played at the same position as it had been played before the event. (in special fro external zones)
    MiniServer
    new -> support of https-connection for MiniServer V2
    Statistic
    new -> add configured Speaker-Set (Stereo/Down-mix/Total-Speaker)
    Raspi
    fix -> GPIO not always working
    fix -> minor issues at start-sequence
    fix -> wrong Binary ARM<->X86
    WebUI
    update -> language files
    fix -> add missed variables
    new -> User-settings with password-hash to use functions from outside the WebUI
    Netshare
    new -> Samba Version choosable, e.g. for older NAS or FritzBox >V7.20
    fix -> Apache-Crash when not all form has data at saving
    Install-Script
    new-> always install latest LMS Version
    new-> Setup all packages for MSG
    Update
    new -> Update now automatically reads the latest-version of the LMS, no code changes for further LMS versions e.g. 8.2,8.3,9.0.....
    System
    change -> LMS 8.x is now standard, 7.9.x is not supported anymore
    new -> Folder /tmp (ram-drive) gets automatic cleaned after period
    new -> Start/Stop for own script, put your own executable scripts into /opt/music_server/init/start or .../stop and they get executes on system start or system stop (files has to be executable 0755)
    new -> reboot/shutdown or services control via URL (https://music-server.net/help/Reboot...erMiniSer.html)
    WARNING!! The old power.php is not reachable from outside any longer, if used in MiniServer please switch to the new set.php
    MusicServerGateway
    new -> MSG V1.2 Beta
    most of the functions are now integrated
    dev -> What don´t work or is under development
    Spotify actual only with one user (first User in Plugin Spotty)
    create own Playlist are not implemented
    create Global-Favs from Spotify are not working
      • 7282
      #32
      #V1.2.1_beta
      PowerManager
      new -> Volume-Reset, choosable if only reset if Volume is higher than min.Vol or also when its lower than min.vol
      MSG
      fix -> Sync has a delay in some zones.
      fix -> Spotify search not work if only one Spotty User is set
      fix -> RoomFav set back to first RoomFav if zone is stopped instead of paused
      new -> Transfer Playback (Wiedergabe Übernehmen) implemented !!Read manual!! Use same setting for Spotty like shown in manual.
      new -> save Spotify-Playlist etc. as Fav / RoomFav
      new -> Volume-Boost for MSG-sayFav (amplification in dB)
      Language
      new -> Spanish has been added. Thanks to @madito
      update -> all languages are updated
      Event
      new -> TTS Standard Signal, so you can use the signal option also for MSG-Events
      new -> Announcement Standard Signal sends a signal 1-3 before playing the announcement
      new -> Announcement Volume Boost, increase the volume by the given value (amplification in dB).
      ............Recodings are quieter than normal TTS, so you can bring the volume values better together Value 10 works best for me Android/iOS
      fix -> change the auto generated filename with better prefix to handle all processes better
      fix -> ResponsiveVoice don't work in some cases
      WebUI
      new -> set system to Beta / Relase from WebUI ->setup ->musicserver
      T5-Receiver
      change -> sayFav-Volume-Boost now amplifies now in dB, so maybe you have to adjust the value.
      System
      change -> stop-process change the order for stopping the services
      Zuletzt geändert von hismastersvoice; 02.01.2021, 15:35.
        • 7282
        #33
        #V1.2.1.1_beta
        fix -> LMS-Server not reachable after update to 1.2.1_beta (you only have to install if in Dashboard the server connection failed)
          • 7282
          #34
          #V1.2.1.5_beta
          MSG
          new -> Show hidden Radio Categories Sports and Talk (select in MSG-Settings)
          new -> create own Playlists
          fix -> MusicZone-Block value Vd (min. Volume) works now imitatively if Zone is not playing
          System
          fix -> Volume-Reset at boot is waiting until LMS is reachable
          new -> add MSG-Config and Port-Scanner to Support-Data
          fix -> MSG don't start if no zones in config.json is set
          fix -> Update Log-Files was not saved after update-process
          fix -> not all player start after Squeezelite update if Spotify-Connect was used.
          #V1.2.1.4_beta
          System
          fix -> sayFav amplification works only if T5-Receiver / sayFav was > 0
          update -> polish language updates. Thanks to @TomekWaw
          fix -> hostname domain didn't allow dots
          fix -> Update was not shown all the time
          update -> Support-Data show more information Raspberry included now
          new -> if volume-reset is set, the volume get additionally reset at boot process.
          MSG
          fix -> if mp3 has no cover-artwork, the cover of the last played file was shown instead of empty cover
          #V1.2.1.2_beta
          System
          fix -> set.php don`t work, so shutdown/reboot etc didn't had any function
            • 7282
            #35
            #V1.2.1.8_beta
            MSG
            new -> own Icons for Spotify, that it fit to the rest of the Loxone-Icons
            System
            change -> Volume-Reset is now executed after Zone-Power-Off not as before after Amp-Power-Off
            fix -> Amp-Group All was not working
            WebUI
            fix -> minor optical improvements
            new -> Set description for Sound-card-channels, for a better identifying in Zone-Setup
            Zuletzt geändert von hismastersvoice; 19.01.2021, 22:30.
              • 7282
              #36
              #V1.2.3.2_beta
              System
              change -> Support-Data show again MSG Config, (was removed because of showing plain-password), Now password is exchanged by xxxxx before shown in Support-Data-File
              new -> Raspberry, possibility to deactivate the GPIO Service in PowerManger, needed if you use e.g. HifiBerry Amp2
              MSG
              new -> Filter options for Spotify Menu in WebUI -> MusicServerGateway
              new -> more Filter options for Radio in WebUI -> MusicServerGateway
              new -> User multiple Spotify Users -> Important read manual! (Add Users to MSG-Config)
              fix -> sayFav didn't say Fav-Names with German "Umlauts"
              WebUI
              new -> MiniServer User/password check
              improve -> minor optical improvements
              change -> KNX-Connect, KNXd configuration shows now direct the /etc/knxd.cfg and saves to it. Because of complexity it is not possible to build a simple form to config it.
              new -> RoomFav Editor (->Tools ->LoxHelper), you can rearrange or change Name, Stream-URL, Image-URL of Room-Favs
              improve -> Handling of disconnected external Zones
                • 7282
                #37
                #V1.2.3.3_beta
                System
                fix -> config is not read if update from <= v1.0.12 on Virtual Machines
                  • 7282
                  #38
                  #V1.3.0.0
                  First release with the new MusicServerGateway Thanks to @gagi
                  -> Full integration into Loxone App
                  -> Full integration of Config Music-Zone Block
                  -> Fav handling Global/Room-Fav
                  -> Multiple Spotify Users
                  -> Features from AudioServer like Announcement (Durchsage) that the org. MusicServer never got
                  Full support for Raspberry
                  -> Support for Raspi 3/B/+ up to 2 Soundcards
                  -> Support for Raspi 4 up to 2 Soundcards via USB-C and Power via GPIO Pin (direct USB onyl 1 Soundcard (Firmware issue of the Raspi 4))
                  -> GPIO Support (can be switched off for the use of HifiBerry etc.)
                  Include all features of the Beta Versions.
                  WebUI
                  fix -> Room-Fav Editor not always show images of Favorites
                  new -> Page-Load time is shown (bottom right)
                    • 7282
                    #39
                    #V1.3.1.0
                    System
                    new -> Debain 11 Bullseye support (Bullseys is still in testing-phase, so use only if you have some Linux knowledge)
                    fix-> Config Value are not written correct if update from very old version
                    WebUI
                    new-> LMS/GLabal Favorites Editor (Tools->LoxHelper->Favorites Editor)
                    new-> Config Check (Help-Config-Checker), Checks if all config-values are exist or config-files are readable
                    Events
                    new-> for type "fav" added the option "roomfav" (&roomfav=0 or 1), to use room-favorites(1) or global-favorites(0)
                      • 7282
                      #40
                      #V1.3.1.1
                      System
                      fix-> Config Value are not written correct if update from very old version (fist fix not working in cases)
                        • 7282
                        #41
                        #V1.3.1.8
                        System
                        new-> Config-Checker is now able to create and repair Config-Files, and also set missing variables with standard values.
                        new-> Config-Checker is running automatically after an update of the MS4H
                        new-> EQ 15-Band can be choose again in Zone Settings, EQ 10-Band of the MSG than not longer active and EQ can onyl set in WebUI. (THX to @buki)
                        Backup
                        new-> Config-Check after restoring "MS4H Settings"
                        new-> At restoring "MS4H Settings" the Version is not longer overwritten.
                        ...........So now your are able to restore older settings (> v1.0.0.0) to a newer Version (>= v1.3.1.8).
                        ...........The Config-Check will set all missed settings values.
                          • 7282
                          #42
                          #v1.3.2.1
                          System
                          fix-> error messages at start-process if WOL is not supported by NIC.
                          improve -> small changes for Debian 11 (Bullseye) support
                          MSG
                          new-> Radio Category "Presents" now also choosable in Radio-Filter
                          fix-> RoomMode in Config 8 shows now the RoomFavs
                            • 7282
                            #43
                            #v1.3.2.2
                            System
                            fix-> WOL works not on all systems any more
                            WebUI
                            fix-> MS4H Update-Button was not green if Update was available
                              • 7282
                              #44
                              #v1.3.2.3
                              System
                              fix-> Network check if NIC is UP before setting LMS (needed because change in Debain-System-Files)
                              fix-> Network set DNS Server better handling
                              improve-> Config-Checker is now able to check and repair NPM-Packages for the MSG
                              Wenn euer System im Dashboard nach einem Neustart des MS4H zeigt das der LMS nicht erreichbar ist obwohl er es zuvor noch war ist das Update zwingend nötig.
                              Danke an hme0354 für das testen!
                                • 7282
                                #45
                                #v1.3.2.4
                                System
                                fix-> mstools crash
                                if you have already updated to 1.3.2.3 use the Terminal-Patch
                                ( cd / && sudo wget http://music-server.net/download/patch_1.3.2.3.sh && sudo bash patch_1.3.2.3.sh )
