Update Thread...
Das ist ein wichtiges Thema.
    • 7225
    #1.5.3.1_beta
    System
    new -> system-control 2, faster response to MS4H-System-Commands (sc) speedup by 50-60% (boot at slow systems e.g. Raspi 3B is up to ~2-3 sec. faster)
    new -> Amp-Off on reboot/shutdown, if the system is shut down by set-Command or WebUI, all Player and Amps switch to off (VI/URL/UDP/cRelay/GPIO/KNX/GPIO-MS4H-Plugin...)
    new -> Watchdog, checks all configured Services every 30 seconds if they run, if not the watchdog restarts the services. Can be temporary disable in the WebUI.
    new -> Support for Raspbian/DietPi Bullseye 64Bit (Raspberry/RockPi4), DietPi for X86 64Bit will follow soon
    improve -> Code / Variable cleanup
    WebUI
    new -> support for Raspbian/DietPi Bullseye 64Bit (include 15-Band mbeq Equalizer)
    improve -> PowerManager, before saving new data, all old amp-connections will switch to off.
    #1.5.1.9
    System
    fix -> PowerManger2, URL don't work if special character was in the URL.
      • 7225
      #1.5.3.6_beta
      System
      info -> Theoretically it shold work now with ever Hardware that DietPi 32/64/x86_64Bit Bullseys works with. (LAN not WIFI!)
      new -> Support for DietPi ARM 32Bit and X86_64Bit
      new -> Dashboard supports new DietPi / Raspbian Verions
      new -> Support-Data supports new DietPi / Raspbian Versions
      fix -> DietPi apt is very slow (WebUI Update takes 30 Sec. on Raspi3 etc)
      fix -> minor issues in System-Update
      fix -> PowerManager2, cRelay don't switch all the time all relays to on/off if all Zones go to play/stop at the same time.
      improve -> System Controller (sc), fix minor issues, clean code
      WebUI
      new -> Support for new DietPi/Raspbian Verions
      improve -> better Version of mbeq 15-Band for ARM 64Bit Systems (Thanks to @buki)
      Install-Script / Install-Script-Beta
      new -> Support for DietPi 32/64/x86_64Bit
      new -> better handling of package install
      new -> include crelay for 32/64/x86_64Bit
      new -> include mbeq 15-Band for 32/64/x86_64Bit (Thanks to @buki)
        • 7225
        #1.5.3.7_beta
        System
        fix -> mbeq 15-Band Equalizer files was not able to copy at arm64 Systems
          • 7225
          Achtung!!
          install_beta.sh ist nicht mehr aktiv, für das installieren der Beta ist es es install.sh b
          (Anleitung wurde angepasste
          LINK)
          #1.5.3.10_beta
          System
          fix -> Network - If DHCP is set, the hosts file was writen incorrect
          fix -> Squeeze Controller - knxd starts if autostart is 0
          new -> downgrade form console possible (read manual careful)
          new -> T5 Receiver with some new Commands (see Manual)
          new -> Set User Permissions for WaveIn Plugin THX @Pentium789
          WebUI
          fix -> Hostname was not shown in Dashboard and Network-Settings
          fix -> IP/DNS etc was not shown in Network-Settings after saving with DHCP
          MSG
          new -> Support for "Off/Aus" Command in Loxone Config (On/Ein sends the WOL Command and was already integrated)
          Install-Script
          new -> insatll.sh for Release/Beta/Test Versions (read manual careful), also older Version can be installed now. Better failure handling.
          Zuletzt geändert von hismastersvoice; 24.04.2022, 22:22.
            • 7225
            #1.5.4.0_beta
            System
            improve -> Services KNX and MusicServerGateway are not longer set to Autostart after installation. Loxone User mostly don't need KNX, KNX-User don't need MSG
            imporve -> better network support on diffent systems
            improve -> Read of IP for System and Network-Settings
            MSG-Config
            fix -> Spotify Family don't switch Account reliably whiule using Looxne App
            Update-Skripts
            new -> add user music to group audio and squeezeboxserver for better Plugin-Support
            Install-Script
            new -> shows now download-speed
              • 7225
              #1.5.4.1_beta
              WebUI
              fix -> Squeeze-Connect missing values fixed
                • 7225
                #1.5.5.0
                Release Version includes all Beta Features since 1.5.1.9
                **Support for DietPi X86_64Bit + ARM 32/64Bit / Raspbian 64Bit (Debian 10/11 64Bit and Raspbian 32Bit is still supported)
                **Better Support for multiple Spotify-Users (User-Switch in Loxone-App)
                **15 Band EQ for all supported systems
                **KNX-Support improvements
                **Watchdog for Services
                **Install-Script improvements
                **Bug fixing...
                  • 7225
                  #1.5.5.1
                  System
                  fix -> VolumeReset was overwritten with 0 in the WebUI if MSG is managing it
                  PowerManger
                  fix -> DNS queries every second under certain constellations​
                    • 7225
                    #1.5.5.2
                    Event
                    fix -> Overlay set volume to 0 if player was before event in stop mode (don't play audio-stream)
                    fix-> RiseVolume does not work if the rise factor has more than one decimal place. eg: Volume from 1-10 in 300 Seconds = Factor 0,03 was interpreted as 0,0 and don't rise.
                    System
                    fix -> Hostname was not set anymore at reboot after network changes
                    new -> new DNS Server will also set in resolv.conf after network changes and reboot​
                      • 2551
                      Ich hab noch ein Haken bei beta drin... daher wird mir diese Version nicht angeboten. Sollte ich den Haken rausnehmen oder ist betatechnisch etwas in Planung wie seinerzeit im Juli (wäre gerne bereit die Beta zu testen, falls da was verfügbar wäre)?
                        Denke vor dem Winter wird es keine neue Beta geben.
                        Es wird aber vor der Beta noch Alphas geben, ich werde dich dann kontaktieren
                    • logol01
                      • 03.03.2018
                      • 831
                      ich laufe auf 1.5.4.1_beta.
                      Bekomme aber das Update vom LMS nicht in.
                      Version installiert:8.4.0~1669201856 Version online:8.4.0~1669444906
                      ich klicke auf update... Dann läuft das Log durch.
                      wie folgt:
                      Squeezeboxserver | UPDATE
                      Version online: 8.4.0~1669444906
                      Server / Player STOP
                      OK...
                      Download LMS in progress...
                      Install LMS
                      (Reading database ... 61642 files and directories currently installed.)
                      Preparing to unpack logitechmediaserver_8.4.0~1669201856_all.deb ...
                      Unpacking logitechmediaserver (8.4.0~1669201856) over (8.4.0~1669201856) ...
                      Setting up logitechmediaserver (8.4.0~1669201856) ...
                      Processing triggers for systemd (241-7~deb10u8) ...
                      Server / Player RESTART
                      OK...
                      SUCCESSFULLY UPDATED!
                      Der "Update" Button ist aber weiterhin aktiv..... - auch nach Aktualisieren.....
                      scheint also, dass es gar keine Version xxx906 gibt - oder?
                      Was mache ich falsch?
                      VG
                      Logol01
                      • Loxtom577
                        Loxtom577 kommentierte
                        Bei mir das gleiche.
                        Bin beim MS4H auf 1.5.2.2
                        System und Squeezelite sind aktuell.
                        Ich denke das liegt am Updateserver des LMS.
                      • 7225
                      #1.5.5.3
                      MSG
                      new -> first preparation for AudioServer AppUI e.g. MSG is able to set the NodeJS Version for AudioServerUI (to include the AudioServer UI in the near future)
                      System
                      new -> Autorestart, to restart periodically the MS4H-Services, only the MSG or to reboot. (WebUI -> Setup -> MS4H)
                      fix -> minnor issues
                      WebUI
                      new -> show NodeJS Version in Dashboard
                      Zuletzt geändert von hismastersvoice; 15.12.2022, 20:59.
                      • kofi1990
                        kofi1990 kommentierte
                        "(to include the AudioServer UI in the near future)" genial
                      • 7225
                      #1.5.5.4
                      System
                      new -> PowerManger Support for Loxone-Trigger-Card of the org. Loxone MusicServer (WebUI -> Settings -> Services -> PowerManager -> Amp All)
                      fix -> again... files in opt/music_server/init/ have not been processed with autostart/autostop command​
                        • 7225
                        #1.5.5.5
                        System
                        remove -> PowerManger Support for Loxone-Trigger-Card, not as easy as it looks
                        improve -> Soundcard Volume read/set for org. Loxone MusicServer Hardware
                          • 18.09.2015
                          • 2659
                          oberaffengeil
                          habe nun ne SSD in dem originalen 8 Zonen Musikserver und mittels dietpi den MS4H installiert.
                          Endlich alles schnell
                          endlich spotify sauber eingebunden.
                          ich teste nun weiter, was es alles so gibt und inwieweit hier synchron mit externen LS das auch läuft (mir nicht wirklich wichtig).
                          ABER DIETER. geiles Ding. DANKE!!!
                          hätte ich schon viel früher mal mit machen sollen.
                            Danke....
                            AirPlay läuft synchron mit externen Zonen, UPnP nicht.
