Akutelle Version Beta: n.a. (mehr Infos weiter unten)
Hier werde in Zukunft die Updates vorstellen...
#1.5.5.13
System
fix - Install-Process becouse of renaming Logitech Media Server to Lyrion Media Server
Installer
fix - Fav issue becouse of missing mysqueezebox.com Favorite
Known issues Version 9.x
Radio and Soptify-Search don't work any more.
#1.5.5.12
System
fix - LMS could not be installed ( LMS download page has been changed AGAIN )
fix - Squeezelite failed at compile process
new - Tunein-Fix will be installed with LMS update
#1.5.5.11
System
#1.5.5.10
System
fix - LMS could not be installed (LMS download page has been changed)
#1.5.5.9
KNXd
fix - install missing xxd Package for DietPi to en-/decode HEX for Title/Artist/Volume etc.
WebUI
fix - External Zones - ESP32 was shown as Sonos in WebUI
#1.5.5.8
System
new - Setup Soundcard-Master-Volume at boot, some Mainboard Soundcard loss the settings after shutdown
new - ACPI Support, some Mainboards need the special support files, otherwise the Power Button will not work.
#1.5.5.7
System
#1.5.5.7
System
new -> PowerManger Support for Loxone-Trigger-Card (tested with Mainboard Asus Z87M Plus)
This update opens the way to install the MS4H on the otg. MusicServer-Hardware (please use a new SSD >256GB an keep the org. HDD)
fix -> Minor issues
fix -> Minor issues
Installer
fix -> Error network.txt permissions
new -> Install needed packages for Trigger-Card (only if Hardware is X86)
#1.5.5.6_beta
System
new -> PowerManger Support for Loxone-Trigger-Card, first proof
#1.5.5.5
System
remove -> PowerManger Support for Loxone-Trigger-Card, not as easy as it looks
improve -> Soundcard Volume read/set for org. Loxone MusicServer Hardware
#1.5.5.4
System
new -> PowerManger Support for Loxone-Trigger-Card of the org. Loxone MusicServer (WebUI -> Settings -> Services -> PowerManager -> Amp All)
fix -> again... files in opt/music_server/init/ have not been processed with autostart/autostop command
Full Changelog >>>
