MS4H - Support
Das ist ein wichtiges Thema.
  • c4yc0
    • 08.02.2024
    • 16
    #331
    I think the problem is back. I'm on the 1.5.5.15_beta version and since about yesterday miniserver shows music server with the red dot. The log says
    2025-01-08T15:40:25.492Z MSG USER MAP [ '[redacted]' ]
    2025-01-08T15:40:25.493Z MSG:MS REQUEST: jdev/sps/enablebinstatusupdate
    2025-01-08T15:40:26.002Z MSG:MS Calling callback for event: {
    uuid: '1c3edd2b-008c-5142-ffffba1e5675f352',
    uuidIcon: '00000000-0000-0000-0000000000000000',
    text: '{}',
    toString: [Function: textEvToString]
    2025-01-08T15:40:26.005Z MSG Incoming settings update: current Timestamp: undefined
    2025-01-08T15:40:26.005Z MSG Updated settings keys: []
    2025-01-08T15:40:26.006Z MSG no settings object in settings update: Using first user
    2025-01-08T15:40:26.006Z MSG Update from user: admin
    2025-01-08T15:40:26.006Z MSG:MS REQUEST: jdev/sps/getusersettings
    2025-01-08T15:40:26.083Z MSG new Account Settings undefined
    2025-01-08T15:40:26.083Z MSG:MS REQUEST: jdev/sys/date
    2025-01-08T15:40:26.095Z MSG:MS REQUEST: jdev/sys/time
    2025-01-08T15:40:26.151Z MSG new TS for settings update 505582826
    /opt/music_server/msg/service/music-server/index.js:330
    for(let [key, value] of Object.entries(accounts)) {
    TypeError: Cannot convert undefined or null to object
    at Function.entries ()
    at /opt/music_server/msg/service/music-server/index.js:330:40
    at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
      For sure, MSG was not changed in 1.5.5.16.
    • c4yc0
      c4yc0 kommentierte
      Were you able to re-create the error?
      I don't have any error at my systems
  • c4yc0
    • 08.02.2024
    • 16
    #332
    Right, I forgot to mention, it's the newest: 15.3.12.13
    • c4yc0
      • 08.02.2024
      • 16
      #333
      OK, I don't know what I'm doing here but the temporary workaround for this issue is to add
      if (accounts) { // Check if accounts exists
      in line 329 - just before the attempt to iterate on the accounts variable. For some reason it's null or undefined. This if prevents that and at the same time some settings are not fetched from the miniserver. Not sure what are these...
      then you need to close this if - in the line 329 add
      } else {
      console.log(this._lc, "No accounts provided");
      After that basic music UI in Loxone works. I haven't checked what does not work. A proper fix is needed - this one is just a workaround so my wife doesn't get mad of not functional volume buttons
      • Robin22
        • 05.11.2023
        • 3
        #334
        nach der Installation (und auch nach mehreren Neuinstallationen) habe ich ein Problem mit dem Internetradio in der Loxone App. Jedes Mal, wenn ich versuche, darauf zuzugreifen, lädt es nur kurz und zeigt dann die Meldung „Keine Einträge“ an.
        Ich habe bereits mehrfach die Plugins für die Internetradios ausgetauscht und neu installiert. Auch das gesamte System sowie den Loxone Miniserver habe ich unzählige Male neu gestartet, leider ohne Erfolg.
        Interessanterweise funktioniert das Internetradio, wenn ich über den Lyrion Music Server direkt auf das Plugin zugreife – dort gibt es keinerlei Probleme.
        Der Miniserver ist korrekt eingetragen und wird als „reachable“ angezeigt. Aktuell nutze ich die LX Version 15.3.12.13.
        Version vom MS4H 1.5.5.15_beta
        Habe ich eventuell etwas falsch konfiguriert, oder gibt es bekannte Probleme mit dieser Version? Ich freue mich über jeden Hinweis und bedanke mich im Voraus für eure Unterstützung!
        Zuletzt geändert von Robin22; 15.01.2025, 20:28.
        • delphin150
          delphin150 kommentierte
          ich habe leider genau das gleiche Problem. Alle Versuche waren bei mir bisher erfolglos. Konntest du in der Zwischenzeit irgendetwas neues herausfinden?
          @gagi
          Kannst du dir das nochmal anschauen.
        • Gagi
          Gagi kommentierte
          Hi, kannst du mir evtl. eine MSG log-Datei zu dem Problem schicken. Anhand der Bilder ist es etwas schwer zu erkennen.
          Wenn du dir die Radio-Stationen die du haben willst als Favoriten speicherst kannst du weiterhin Radio hören und von der App aus den Sender wechseln. Problem hier ist nur die Anzeige der Lokalen Radio Liste.
      • Leigh
        • 705
        #335
        Gibt es aktuell ein Problem mit dem Squeezelite?
        Update scheint zu scheitern, am Ende wird die Installierte Version "leer" angezeigt, die Online-Version mit 2.0.0-1518.
        Das Update wird als "erfolgreich" gemeldet, aber es tut nicht.
        Bei einer Kompletten Neuinstallation mit aktuellstem Bullseye, das gleiche.
        SD-Karten-Backup eingespielt, Version 1.9.9-1403 läuft.
        Ein Update meide ich aktuell.
        Ciao, Leigh
        • Meininger
          • 30.11.2015
          • 60
          #336
          aktuell scheint es so zu sein, dass wenn man ein Update auf Lyrion Music Server Version 9.1.0~1737438872 macht, dieser nicht mehr startet, somit scheit mein MS4H gerade nicht nutzbar zu sein. Werde versuchen eine ältere Version zu Installieren und berichte wieder.
          Gruß Sascha
          • duncan
            • 321
            #337
            yes ive noticed the same that the lyrion music server service doesnt work - you dont need to roll back, just to re-enable the lyrion service
            if you telnet into the music server you can run "sudo systemctl status lyrionmusicserver" to get the current status - mine had the service disabled after the latest update
            run sudo systemctl start lyrionmusicserve.service to start the service and test
            if this works, then run sudo systemctl enable lyrionmusicserver.service to enable auto start at boot
              I don't recommends this...
              After you do t his the MS4H has no control anymore over the LMS.
              Will have a look this days what happens.
              An update of the LMS is under normal condition not required.
              Lyrio.n has change the update system.
              Nightly stable and nightly development
              So I think I have to got to stable.
            • Leigh
              Leigh kommentierte
              I noticed exactly the same phenomenon and had a recent backup of the SD card which I had created because of the Squeezelite problem!
              I am currently refraining from any updates!
          • Clubsport
            • 11.01.2018
            • 602
            #338
            Habe hier seit diversen Tagen dasselbe Problem, jemand eine Idee woran das liegt...?!?!
            • smooty1970
              • 18.12.2019
              • 17
              #339
              Auch bei mir weder Neuinstallation o. ä. erfolgreich.... :-(
                • 7321
                #340
                installer und update sollten mit 1.5.5.16 wieder laufen.
                Solltet ihr auf Beta sein, bitte auf release zurück stellen.
                • Meininger
                  Meininger kommentierte
                  Dankeschön! Läuft wieder wie neu! ;-)
              • Danzrh
                • 21.05.2022
                • 45
                #341
                Bei mir startet nach dem Upgrade der LMS nicht mehr. Die Services scheinen nicht zu starten, siehe Screenshot. Hat jemand eine Idee, was ich probieren kann? Vielen Dank!
              • Danzrh
                • 21.05.2022
                • 45
                #342
                Drei mal Update Log:
                Musik-Server | UPDATE
                Version to install: 1.5.5.16
                Server / Player / PM /SQ2LOX STOP
                OK...
                Download Files
                Unzip Files
                Pre-Update-Script
                not used...
                Copy Files...
                Set Directory-Permissions
                Set File-Permissions
                Create Soft-Links...
                After-Update-Script
                not used...
                MusicServer cleanup
                Server / Player / PM /SQ2LOX RESTART
                OK...
                SUCCESSFULLY UPDATED!
                Squeezeboxserver | UPDATE
                Version online: 9.1.0~1737785333
                Server / Player STOP
                OK...
                Download LMS in progress...
                Download LogitechMediaServer... 9.1.0~1737785333
                Install LMS
                (Reading database ... 65867 files and directories currently installed.)
                Preparing to unpack lyrionmusicserver_9.1.0~1737785333_all.deb ...
                Unpacking lyrionmusicserver (9.1.0~1737785333) over (9.1.0~1737635067) ...
                Setting up lyrionmusicserver (9.1.0~1737785333) ...
                TuneIn Jingle Fix
                Server / Player RESTART
                OK...
                Squeezelite | UPDATE
                Version online: 2.0.0-1518
                Player STOP
                OK...
                Download Squeezelite
                Compile Squeezelite
                cc -Wall -fPIC -O2 -fcommon -std=gnu99 main.c -c -o main.o
                cc -Wall -fPIC -O2 -fcommon -std=gnu99 slimproto.c -c -o slimproto.o
                cc -Wall -fPIC -O2 -fcommon -std=gnu99 buffer.c -c -o buffer.o
                cc -Wall -fPIC -O2 -fcommon -std=gnu99 stream.c -c -o stream.o
                cc -Wall -fPIC -O2 -fcommon -std=gnu99 utils.c -c -o utils.o
                cc -Wall -fPIC -O2 -fcommon -std=gnu99 output.c -c -o output.o
                cc -Wall -fPIC -O2 -fcommon -std=gnu99 output_alsa.c -c -o output_alsa.o
                cc -Wall -fPIC -O2 -fcommon -std=gnu99 output_pa.c -c -o output_pa.o
                cc -Wall -fPIC -O2 -fcommon -std=gnu99 output_stdout.c -c -o output_stdout.o
                cc -Wall -fPIC -O2 -fcommon -std=gnu99 output_pack.c -c -o output_pack.o
                cc -Wall -fPIC -O2 -fcommon -std=gnu99 output_pulse.c -c -o output_pulse.o
                cc -Wall -fPIC -O2 -fcommon -std=gnu99 decode.c -c -o decode.o
                cc -Wall -fPIC -O2 -fcommon -std=gnu99 flac.c -c -o flac.o
                cc -Wall -fPIC -O2 -fcommon -std=gnu99 pcm.c -c -o pcm.o
                cc -Wall -fPIC -O2 -fcommon -std=gnu99 vorbis.c -c -o vorbis.o
                cc -Wall -fPIC -O2 -fcommon -std=gnu99 faad.c -c -o faad.o
                cc -Wall -fPIC -O2 -fcommon -std=gnu99 mad.c -c -o mad.o
                cc -Wall -fPIC -O2 -fcommon -std=gnu99 mpg.c -c -o mpg.o
                cc main.o slimproto.o buffer.o stream.o utils.o output.o output_alsa.o output_pa.o output_stdout.o output_pack.o output_pulse.o decode.o flac.o pcm.o vorbis.o faad.o mad.o mpg.o -lpthread -lm -lrt -ldl -lasound -o squeezelite
                Set Files
                OK...
                • Danzrh
                  Danzrh kommentierte
                  Ok, lesson learned, updates einzeln ausführen und jeweils neu starten.
                  Beim Update kommt in der Tat eine Fehlermeldung:
                  music@MS4H:~$ mstools pms_latest
                  LMS Base Version: 9.1.0
                  music@MS4H:~$ mstools update_lms
                  OK...
                  --2025-01-25 18:00:21-- https://downloads.lms-community.org/...785333_all.deb
                  Resolving downloads.lms-community.org (downloads.lms-community.org)... 104.21.64.1, 104.21.96.1, 104.21.80.1, ...
                  Connecting to downloads.lms-community.org (downloads.lms-community.org)|104.21.64.1|:443... connected.
                  HTTP request sent, awaiting response... 200 OK
                  Length: 60695780 (58M) [application/vnd.debian.binary-package]
                  lyrionmusicserver_9.1.0~1737785333_all.deb: Permission denied
                  Cannot write to 'lyrionmusicserver_9.1.0~1737785333_all.deb' (Permission denied).
                  Install LMS
                  dpkg: error: cannot access archive 'lyrionmusicserver_9.1.0~1737785333_all.deb': No such file or directory
                  Dann ist dein System nicht sauber auf 1.5.5.16 upgedatet.
                  Mir ist im log des MS4H Update folgendes aufgefallen.
                  Pre-Update-Script
                  not used...
                  After-Update-Script
                  not used...
                  Da stimmt was nicht.
                • Danzrh
                  Danzrh kommentierte
                  Läuft wieder, alle mstools update_... Befehle mit sudo ausgeführt.
                  Danke!
              • Kverb
                • 05.05.2022
                • 27
                #343
                Thanks for the quick update after LMS wouldn't autostart again, my MS4H was up and running quickly after two days of missing doorbell rings ;-)
                Just a tiny remark that I noticed: "#" is a valid character in Loxone user passwords but it is not accepted by MS4H.
                Best regards,
                Kjell
                • tollertenya
                  • 20.10.2019
                  • 138
                  #344
                  - gelöscht - erstmal Update nach 1.5.5.17 gemacht
                  Zuletzt geändert von tollertenya; 28.01.2025, 06:11.
                  • tollertenya
                    • 20.10.2019
                    • 138
                    #345
                    ich habe seit 3 Tagen und meinem Update auf 1.5.16 bzw. gestern auf 1.5.5.17 das Problem das jeden Morgen sich die Dienste beendet haben. Ich kann diese dann ganz normal über die Weboberfläche starten aber am nächsten Morgen sind sie wieder gestoppt.
                    Mein letztes Update Log:
                    Version to install: 1.5.5.17
                    OK...
                    Download Files
                    Unzip Files
                    Pre-Update-Script
                    [7mMusik-Server | UPDATE [0m
                    OS not supported !!
                    Copy Files...
                    .../etc/...
                    .../opt/...
                    .../www/...
                    After-Update-Script
                    MusicServer cleanup
                    OK...
                    Version online: 8.4.0~1675760665
                    OK...
                    Install LMS
                    (Reading database ... 55103 files and directories currently installed.)
                    Preparing to unpack logitechmediaserver_8.4.0~1675760665_all.deb ...
                    Unpacking logitechmediaserver (8.4.0~1675760665) over (8.4.0~1675097179) ...
                    Setting up logitechmediaserver (8.4.0~1675760665) ...
                    OK...
